Mesa 7i76e wiring
- Thank you received: 7470
15 Nov 2018 21:51 #120786
Replied by tommylight on topic Mesa 7i76e wiring
Also for the 7i76E you need the Stretch version of linuxcnc.
Your network should be set using the network manager, there are also provisions for setting the gateway and DNS there, without them network will not work properly.
Network setting should be like so:
IP 10.10.10.2 up to 254 ( excluding 10, and never 1 )
Netmask 255.255.255.0 or /24
gateway 10.10.10.1
Dns 10.10.10.1 ( works without this line )
gateway 10.10.10.1
The following user(s) said Thank You: Bello
- Bello
15 Nov 2018 22:22 - 15 Nov 2018 22:26 #120787
by Bello
Replied by Bello on topic Mesa 7i76e wiring
@tommylights I will try with stretch also
@PCW Are you suggesting to move w9 jumper down to enable to load the backup and retry?
Which is the best way to turn off it and rollback the change if will work?
Last edit: 15 Nov 2018 22:26 by Bello.
- Thank you received: 5321
15 Nov 2018 22:35 #120789
Replied by PCW on topic Mesa 7i76e wiring
Yes, move the jumper down and then power cycle
If the red light does not go out there may be something broken with the card or you still have power supply issues
- Bello
16 Nov 2018 13:24 - 16 Nov 2018 16:27 #120833
by Bello
I have tried with jumper w9 down but nothing is changed, exattly the same scenario, the leds on the Eth port are NOT lighting.
I have tried using another Linux distribution also (Ubuntu LTS and Stretch), with no luck.
I see always CR1 and CR2 lights so probably the last thing that I must to test is to use another 5V supply. I'm going to buy anotherone and retry, I will let you know.
Last edit: 16 Nov 2018 16:27 by Bello.
- Bello
17 Nov 2018 22:51 - 17 Nov 2018 22:52 #120926
by Bello
Thank you all guys.
I nave bought a new 5v supply with much Ah then the previous one and finally the ethernet and connettivity goes up successfully.
To have linuxcnc working i have had to switch on strech preemt RT kernel also and all till now seems be working as expected.
Last edit: 17 Nov 2018 22:52 by Bello.
Time to create page: 0.165 seconds
