how to update running linucnc?
- jamby
- Thank you received: 6
15 Nov 2018 23:02 #120791
by jamby
how to update running linucnc? was created by jamby
Hi
I apologize if this has been answered a hundred times before, but I can find the answer.
Is it possible to have a running instance of linuxcnc reload its configuration files without restarting linuxcnc??
Jim
Jim
- Thank you received: 1472
16 Nov 2018 00:56 #120800
Replied by Todd Zuercher on topic how to update running linucnc?
I don't think so. But you may be able to manually enact your changes.
- Thank you received: 5321
16 Nov 2018 01:15 #120801
Replied by PCW on topic how to update running linucnc?
in addition to doing it manually, you can certainly run a halcmd script to change
a set of parameters.
What are you trying to do?
- jamby
16 Nov 2018 01:24 - 16 Nov 2018 04:36 #120804
by jamby
Replied by jamby on topic how to update running linucnc?
PCW
Sorry this is the second time one question has lead into a completely different subject. The last time AndyPugh gave me some help.
I am going start another post about the issue behind this question...
Last edit: 16 Nov 2018 04:36 by jamby. Reason: attached files
Time to create page: 0.172 seconds
