- LinuxCNC
- General LinuxCNC Questions
- 5 axis - different format want to have dual X,Y stage and 1 Rotary Axis
- Millerman
20 Nov 2018 21:25 #121089
by Millerman
5 axis - different format want to have dual X,Y stage and 1 Rotary Axis was created by Millerman
I have a machine that I want to be able to use 2 different x,y stages and 1 rotary stage at the same time. How can I set this up ?
- alan_3301
- Thank you received: 22
21 Nov 2018 11:26 #121114
by alan_3301
Replied by alan_3301 on topic 5 axis - different format want to have dual X,Y stage and 1 Rotary Axis
I think you will have to describe the setup in more detail, preferably with a diagram.
Is this a hotwire foam machine or something else?
- Thank you received: 4654
21 Nov 2018 17:20 #121140
You can create a machine that takes any combination of XYZ ABC UVW axis letter commands.
Conventionally a second XY stage would use the UV G-code commands, but other options are possible.
Replied by andypugh on topic 5 axis - different format want to have dual X,Y stage and 1 Rotary Axis
The following user(s) said Thank You: Millerman
- LinuxCNC
Time to create page: 0.106 seconds
