DIY Mesanet FPGA daughtercard framework ???
- jCandlish
- Thank you received: 4
23 Nov 2018 17:02 #121257
by jCandlish
DIY Mesanet FPGA daughtercard framework ??? was created by jCandlish
Coming back after along hiatus ...
Does there exist a sample project (hardware/software) as a jumping off point for designing a custom daughter board compatible with Mesanet's 50-pin I/O offerings?
Thanks!
Thanks!
- Thank you received: 5329
23 Nov 2018 18:45 #121261
Replied by PCW on topic DIY Mesanet FPGA daughtercard framework ???
Not sure of the exact question
Do you mean is there a public daughterboard design?
Most are pretty simple and I can supply schematics if needed
None of the current 50 pin daughterboards have any firmware except
simple CPLD logic, a couple of the 25 pin daughtercards have DSPs
with firmware however, and all sserial daughtercards have firmware.
The following user(s) said Thank You: tivoi
- jCandlish
23 Nov 2018 19:01 - 23 Nov 2018 19:13 #121262
by jCandlish
Yes.
I'm wanting to move ahead with a FANUC interface daughtercard with tri-state I/O and compatible mini-centronics connectors.
Just thinking about making a prototype break-out board that would sit between a 7i80 and FANUC Beta-series amplifiers, both servo and spindle types, and also the i/o modules.
The goal being to replace the FANUC motion controller while retaining the amplifiers and existing I/O cabling.
Edit: I suppose the 7i69 would be a starting point, but it is SSerial connected.
Replied by jCandlish on topic DIY Mesanet FPGA daughtercard framework ???
Yes.
Last edit: 23 Nov 2018 19:13 by jCandlish.
23 Nov 2018 20:24 #121266
If you wanted to go this way, I _think_ you could do 2 interface channels per daughtercard:
12 PWM
4 control (2 per channel)
4 encoder (2 per channel)
4 SPI/Add for say a AD7265 simultaneous conversion A,D:
SPI-IN
SPI-CS
SPI-CLK
A-D Channel Sel
To avoid direction changes at the FPGA pin level, I would probably use open drain on the PWM pins so when PWM is disabled the pins can be input to read drive status
Open drain should be fine for high speed as long as the termination is 3.3V open circuits at 150 Ohm Thevenin equivalent
12 PWM
SPI-IN
SPI-CS
SPI-CLK
A-D Channel Sel
The following user(s) said Thank You: jCandlish
- jCandlish
23 Nov 2018 20:39 #121268
by jCandlish
Thanks. Really just spitballing at this stage.
Time to create page: 0.123 seconds
