- LinuxCNC
- General LinuxCNC Questions
- python script , linuxcnc cannot terminate / unable to reload .ini file
- giantstone
24 Nov 2018 04:01 #121282
by giantstone
python script , linuxcnc cannot terminate / unable to reload .ini file was created by giantstone
Hi, My machine need two sets of ini parameters, (the motor scale should be different under two different situations as measurements suggests so)
I start linuxcnc via python by the following script :
import subprocess
ini_address='/home/sam/linuxcnc/configs/qgj/'
ini_file_name = 'qgj2.ini'
bashCommand= 'linuxcnc ' +ini_address+ini_file_name
# linuxcnc /home/sam/linuxcnc/configs/qgj/qgj.ini
process = subprocess.Popen(bashCommand.split(), stdout=subprocess.PIPE )
and I tried to terminate the linuxcnc in order to restart it to load a different ini., by the following methods:
#### process.communicate(" ^C")
## process.kill() #terminate()
## raise KeyboardInterrupt
## os.kill(os.getpid(), signal.SIGUSR1)
## os._exit(0) #sys.exit()
## thread.interrupt_main()
none of the above methods worked to terminate linuxcnc. ( i tried to do start linuxcnc in a thread, and then call thread.interrupt_main(), and it did not work).
But, If i manually press ctrl+c in the shell on which the python script is excuted, linuxcnc will close.
could someone help me to deal with this problem? I want to start and terminate linuxcnc all by python scripts.
Thanks very much!
import subprocess
Thanks very much!
- giantstone
24 Nov 2018 04:19 #121283
by giantstone
Replied by giantstone on topic python script , linuxcnc cannot terminate / unable to reload .ini file
update, the above methods did close a " linuxcnc tool changer (thread) ", but it did not terminate the main linuxcnc program.
- LinuxCNC
Time to create page: 0.229 seconds
