Re-homing from a python file associated to a glade interface
- Nico2017
- Thank you received: 26
26 Nov 2018 03:27 #121359
by Nico2017
Re-homing from a python file associated to a glade interface was created by Nico2017
I am building a glade interface for linuxcnc for a specific project. I would like toobtain a home button feature which can actually act as a rehome button if the axis is already homed. I struggle to find the good sequence of command to send for the re home case. Here is the ini file section for one axis (X and values are identical for Y)
[AXIS_X]
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 100.0
MIN_LIMIT = -100
MAX_LIMIT = 500
[JOINT_0]
TYPE = LINEAR
MAX_VELOCITY = 50
MAX_ACCELERATION = 500.0
BACKLASH = 0.000
INPUT_SCALE = 1.000
OUTPUT_SCALE = 1.000
MIN_LIMIT = -100
MAX_LIMIT = 500
FERROR = 0.050
MIN_FERROR = 0.010
#Homing type immediate
#Homing on the fly or manual, when pressing homing or sensor triggered
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
#HOME_SEQUENCE = -1
#HOME = 0.000
HOME = 0
HOME_OFFSET = 0.0
HOME_IGNORE_LIMITS = NO
#HOME_IS_SHARED = 1
I would like a homing sequence of homing type immediate, which take the value in a spin box ( here NameGladeInterface.hal_spinbuttonXManualHomeModePos-f) and set this value for the the associated axis (X or Y). So from the hal I am actually doing:
net XValueHomePosition NameGladeInterface.hal_spinbuttonXManualHomeModePos-f => ini.0.home ini.0.home_offset
net YValueHomePosition NameGladeInterface.hal_spinbuttonYManualHomeModePos-f => ini.1.home ini.1.home_offset
I defined an action linked to the button on my glade interface:
def on_hal_SetCurrentY_clicked(self, widget, data=None):
print 'Homing Y axis clicked.'
if self.status.homed[1]:
print 'Axis Y already home, unhoming then homing again'
#self.c.teleop_enable(1)
#self.c.wait_complete() # wait until the teleop mode is disable
self.c.unhome(1)
self.c.wait_complete() # wait until joint 0 is unhomed
self.c.home(1)
self.c.wait_complete() # wait until joint 0 is homed
self.c.teleop_enable(0)
self.c.wait_complete() # wait until trajectory mode back to Free mode (used for jogging)
else:
print 'Homing axis Y.'
self.c.home(1)
self.c.wait_complete() # wait until joint 0 homed
This work well when I home for the first time. However this does not when I try to re-home for a second time. The question being what should be the sequence of command to do a correct re home.
Thank you
Nicolas
[AXIS_X]
MIN_LIMIT = -100
MAX_LIMIT = 500
[JOINT_0]
TYPE = LINEAR
MAX_VELOCITY = 50
BACKLASH = 0.000
INPUT_SCALE = 1.000
MIN_LIMIT = -100
MAX_LIMIT = 500
FERROR = 0.050
MIN_FERROR = 0.010
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
#HOME_SEQUENCE = -1
#HOME = 0.000
HOME = 0
HOME_OFFSET = 0.0
#HOME_IS_SHARED = 1
self.c.unhome(1)
self.c.home(1)
else:
self.c.home(1)
Thank you
Nicolas
- newbynobi
- Thank you received: 394
29 Nov 2018 22:27 #121611
by newbynobi
Replied by newbynobi on topic Re-homing from a python file associated to a glade interface
Did you jog away from the homing switch prior to start the rehoming?
You home pos is null, so is the home offset. If you do not move away, it might be that it does not work.
Norbert
Norbert
The following user(s) said Thank You: Nico2017
- Nico2017
11 Dec 2018 04:27 #122180
by Nico2017
Replied by Nico2017 on topic Re-homing from a python file associated to a glade interface
thanks for your answer. So the sequence that is working for me is this one, where you actually have to force the teleop mode before rehoming as shown in:
if self.status.homed[0]:
print 'Axis X already homed, unhoming then homing again'
self.c.unhome(0)
self.c.home(0)
else:
print 'Homing axis X.'
self.c.home(0)
self.c.wait_complete() # wait until joint 0 homed, ie when the joint has been to the home location.
FYI, I am also using a home position and home offset identical to force homing to the position which is defined by this value. It works fine when my joint position feedback is using the joint pos-cmd but I am struggling when I am actually using a real encoder information to the joint pos fb.
self.c.unhome(0)
self.c.home(0)
else:
self.c.home(0)
- pl7i92
- Thank you received: 358
11 Dec 2018 08:52 #122188
by pl7i92
Replied by pl7i92 on topic Re-homing from a python file associated to a glade interface
rehoome has changed in halui as from 2.7.12
be aware only selected axis is to be rehomed now
Time to create page: 0.176 seconds
