Can a machine be setup with one axis?
29 Nov 2018 03:26 #121573 by Leon82
For example if I wanted to buy parts over time and setup z axis first. Can I still use the software to control the one axis and add the others later.
My old computer has a legacy parallel port on it so I just have to buy the cable so I'm going to use a standard parallel breakout board
The following user(s) said Thank You: behai
29 Nov 2018 08:23 #121580 by Clive S
Replied by Clive S on topic Can a machine be setup with one axis?
Yes you can, you can even set it up as a 3 axis machine and still only use one axis
The following user(s) said Thank You: Leon82, behai
30 Nov 2018 01:28 - 30 Nov 2018 01:29 #121617 by Leon82
Replied by Leon82 on topic Can a machine be setup with one axis?
Thanks .
I booted with the live cd And the max jitter sofar is 13105 nanoseconds. From what I've read my box should be ok.
Hopefully the plug in the motherboard is still working
What's the difference between the base and service thread? The base thread is at 19788ns
Last edit: 30 Nov 2018 01:29 by Leon82.
02 Dec 2018 17:09 #121721 by andypugh
Replied by andypugh on topic Can a machine be setup with one axis?
The base thread does the fast ND stuff, like output step pulses, but typically does not do any difficult mathematics (no floating point)
The servo thread does the complicated stuff, like calculating the step frequency for the next 1mS, before passing that number on to the base thread.
16 Dec 2018 13:35 #122473 by Leon82
Thanks.
I got the z axis up and running. I had to invert it in the pin menu.
I selected the g201(because I got 201x) for driver but it was choppy and jumping. So I tried the keling preset and it was very smooth
16 Dec 2018 15:36 #122479 by pl7i92
Replied by pl7i92 on topic Can a machine be setup with one axis?
For Steppper Mashines BEST To stay at the Given 100000 BASE
will give you 5meter/min that shout reatch your NEED
No need to edit in
BE arare the Entry You makes go to the Stepgen Timing not to the BASETREAD
Servotread is the Time that Switches Buttons PERYPHERY are ancounterd
17 Dec 2018 03:28 #122503 by Leon82
Here's a silly question,
How do I make a text file a program? I'm not quite ready to run anything but it has what seem to be image file extension. Png... Ect
I saw this in the ini when I tried out the GMOCCAPY UI. Could I use a .txt file?
17 Dec 2018 09:26 #122509 by pl7i92
Yes You can use TXT Just open * Files
BUT BETTER To Safe to NC_File Folder With ending ngc
17 Dec 2018 10:13 - 17 Dec 2018 10:14 #122512 by andypugh
There are two questions that you could be asking here.
1) How do I make a text file containing Pyhon, Bash, Java etc into an executable file.
- Then you need the file to start with the #! sequence and the path to the interpreter
For example #! /usr/bin/python
And you also need to give the file execute permissions "chmod +x file.name"
2) How do I get LinuxCNC to treat a text file containing G-code as .G-code:
- Change the file extension to .ngc
Or edit the INI to accept the other extension as G-code.
Three! There are at least three questions you could be asking :-)
3) To interpret a bitmap image (.png, .gif, .jpg) as a depth map simply open it in the LinuxCNC GUI file browser, the special filter file "Image-to-gcode" will run and convert the image to a machinable file.
Last edit: 17 Dec 2018 10:14 by andypugh.
23 Dec 2018 14:34 #122781 by Leon82
Thanks again.
I got all three axes up and running. I even ran a little test program .
I can use mastercam at work but I'm going to have to figure something out for home
Time to create page: 0.382 seconds
