Mesa 7i92m Bitfile Compiling
  • pl7i92
  • pl7i92's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Dec 2018 09:46 #122192 by pl7i92
Mesa 7i92m Bitfile Compiling was created by pl7i92
Someone that is Eable to make me my own Bitfile
i added the pin and vhd for the 7i92m
i need the extra Out GPIO so reduce and rename channel of the stepgens
Someone please help
i cand Download 7GB of the Compiler
11 Dec 2018 16:49 #122219 by PCW
The following user(s) said Thank You: pl7i92
  • pl7i92
  • Platinum Member
  • Platinum Member
12 Dec 2018 07:44 #122248 by pl7i92
Replied by pl7i92 on topic Mesa 7i92m Bitfile Compiling
Thank You
Question : Filename VHD and packack naming is not the same
I DID NOT CHANGE the Package Name in the VHD
Will this LEAD in a Problem
As the Filename shoudt also be the packege Name ?
12 Dec 2018 13:31 - 12 Dec 2018 19:39 #122264 by PCW
Replied by PCW on topic Mesa 7i92m Bitfile Compiling
The file name is actually arbitrary but both the package name and file name
need to be selected so that you don't have a name collision with existing files/packages
I tend to have the package and file names at least similar so you know whats where...
So to compile your pinout file, I needed to change the package name and change
the count of stepgens in the module ID section.
Last edit: 12 Dec 2018 19:39 by PCW.
