Strange behaviour after program stop button pressed in axis
7 years 10 months ago #122679 by RichJordan
So I have found some time to do some debugging here. I found not all g-code runs would produce the same error. This helped me trace it down to a line that the Fusion 360 post processor is adding after the tool change (M6 T5):
G43 Z7.35 H5
Removing this line stops the error. I tried removing the Z7.35 and having only G43 H5 but the move after a stop command still occurs.
I would assume this means there is a tool length offset for this tool somewhere I don't know where to find. The Z value in the tool table (which I have been assuming is the tool length offset) is zero. Any idea why it does this?
Clearly I can remove the line but I'd like to understand the behaviour.
Richard
7 years 10 months ago #122680 by RichJordan
After reading the G43 description I am wondering if the recent addition of the 'tool touch off with probe' sim that ships with LinuxCNC might be part of this issue. I have a spindle with collets (cant set the tool length the same between changes) and I think I am running the manual tool changer - is this a potential problem?
6 years 5 months ago - 6 years 5 months ago #168752 by cadcam
I just got caught with this and F'd everything.
I'm not sure this has always been the case... or that it's a Fusion issue. The only thing that has changed for me is linuxcnc - currently on 2-9-0.
Did you get anywhere with this?
It appears to only occur on the mill, not lathe (I use fusion for both). From what I can see, STOP does not stop until DTG on all axis is 0. And that's a problem!!
Last edit: 6 years 5 months ago by cadcam.
6 years 5 months ago - 6 years 5 months ago #168762 by PCW
This seems to be a 2.9 bug:
github.com/LinuxCNC/linuxcnc/issues/865
One suggestion (from rmu) is to add
260 emcTaskPlanClose();
+++ emcTaskPlanReset();
after line 260 in emctask.cc
This fixes the issue in my simulations, but AFAIK no task expert has looked at this yet
Last edit: 6 years 5 months ago by PCW.
6 years 5 months ago #168768 by cadcam
6 years 5 months ago #168842 by RichJordan
Hi cadcam
I was tired of chasing this and wanted to get on with making things... I modified Fusion g-code to remove all M6 calls and I removed the remap function I had put in for M6. Now I just run single g-code files for each tool and the stop button behaves. Feels much safer and no disappointment of written of jobs.
I don't have a tool changer and this is a sensible workaround for me.
Reading the bug on github makes it clear to me that this is the same behaviour I was experiencing. That was on 2.7.14 I think and I am now running a master from some time ago (so 2.9) but haven't retested this issue. And they were definitely large g-code files doing 3d surfacing type work.
Time to create page: 0.109 seconds
