Virtual keyboard for gmoccapy
- Peterdeleu
19 Dec 2018 14:39 #122595
by Peterdeleu
Virtual keyboard for gmoccapy was created by Peterdeleu
I've just installed a fresh version of LinuxCNC.
This is the version based on Wheezy.
When I try to install a virtual keyboard for use in gmoccapy, either "Matchbox-keyboard" and "Onboard" are not found.
Probably because these versions are removed for Wheezy.
Is there any way to get a virtual keyboard working?
Or is there a LinuxCNC for a more recent version of Debian?
Regards
Peter
Regards
Peter
- pl7i92
- Thank you received: 358
19 Dec 2018 16:06 #122601
by pl7i92
Replied by pl7i92 on topic Virtual keyboard for gmoccapy
DID you first lanch a Gmoccapy Demp Mahine
and also a NGCGui demo mashine to set up all needed folders
Then it shoudt work like you wish to
- newbynobi
- Thank you received: 394
19 Dec 2018 21:57 #122612
by newbynobi
Replied by newbynobi on topic Virtual keyboard for gmoccapy
You need to install matchbox keyboard or onboard!
Other virtual keyboards are not supported!
Ignore the previous post, as that answer will not solve your problem.
Norbert
Norbert
- Peterdeleu
19 Dec 2018 23:13 #122617
by Peterdeleu
Replied by Peterdeleu on topic Virtual keyboard for gmoccapy
Yes I know, matchbox or onboard...
But where can I find these?
It looks like the packages no longer exist for Wheezy.
Wheezy is old... and replaced by Jessy and Sid
Wheezy is debian 7, essie is debian 8 and sid is debian 9.
- Peterdeleu
20 Dec 2018 00:51 #122624
by Peterdeleu
I found the solution.
This is how I did it :
* Download matchbox-keyboard from debian.pkgs.org/7/debian-main-i386/match...6-9+b1_i386.deb.html
* First install the dependency : sudo app-get install libfakekey0
* Then install matchbox: sudo dopkg -i matchbox-keyboard_0.1+svn20080916-9+b1_i386.deb
- eriksalo
- Thank you received: 20
20 Feb 2019 05:17 - 20 Feb 2019 05:21 #126805
by eriksalo
Replied by eriksalo on topic Virtual keyboard for gmoccapy
Shouldn't that be "apt-get" instead of "app-get" ?
and also "dpkg" instead of "dlpkg" ?
Last edit: 20 Feb 2019 05:21 by eriksalo.
- pl7i92
22 Feb 2019 19:11 #126935
by pl7i92
Yes offcause
apt-get install
and
dpkg
apt-get install
and
dpkg
Time to create page: 0.408 seconds
