Axis drift with Lagun
- archfitters
- Topic Author
We have attempted to tune the board (westamp 30059/30060) with the potentiometer on the resistor with little success. (the board is from 1988) and the components may not be as precise as they once were.
Is there a way to either fine tune programatically, to avoid drift or to disable power to the motors when an error state is reached? We are running a Lagun with westamp 30059/30060 and Pico I/O boards.
Included are configs, please let me know if there are any other items that would be useful, I will take a video once the machine is free.
Thank you
- Thank you received: 5334
When linuxCNC in not in a machine-on state, your drives
should be disabled
- archfitters
- Topic Author
newsig ppmcEstop bit
linksp ppmcEstop ppmc.0.din.estop.in
linksp ppmcEstop and2.0.in0
newsig EstopOkIn bit
linksp EstopOkIn estop-latch.0.fault-in
linksp EstopOkIn and2.0.out
newsig EstopOkOut bit
linksp EstopOkOut ppmc.0.dout.07.out
linksp EstopOkOut ppmc.0.dout.Estop.out
linksp EstopOkOut iocontrol.0.emc-enable-in
linksp EstopOkOut estop-latch.0.ok-out
linksp EstopOkOut and2.0.in1
newsig emc-estop-out bit
linksp emc-estop-out iocontrol.0.user-enable-out
linksp emc-estop-out estop-latch.0.ok-in
newsig emc-estop-reset bit
linksp emc-estop-reset iocontrol.0.user-request-enable
linksp emc-estop-reset estop-latch.0.reset
- archfitters
- Topic Author
"This indicates that the hardware or hal file is not setup properly" I am new to this, and am not sure what I am looking for.
Thank you
- dberndt
Something like pid.x.enable
pid.y.enable
and pid.z.enable
should be netted up somewhere to a digital output which interfaces with your drives.
- Thank you received: 1480
archfitters wrote: May I please have some clarification on where the misconfiguration might be?
Thank you
Lets start at the beginning. What hardware are you using? (The clip of hal code you posted was for a Pico Systems config. Are you using their hardware? Are you using your old amps or some of Pico's?
If you are using Pico hardware, hopefully Jon will chime in with some help. (or perhaps you should contact him directly.)
- archfitters
- Topic Author
Can you please suggest which Jon to ping?
I am certain he can tell you the best way to connect the drive enables and e-stop chain to his hardware.
- archfitters
- Topic Author
