Tool error
- Jram1
27 Dec 2018 17:59 #122966
by Jram1
Tool error was created by Jram1
Hello , I am using a Probotixcnc router and am having problems with the first run. I am getting a tool error. It is telling me that I don’t have a tool in the T1 slot even after I enter a tool there. Any help is appreciated.
- Thank you received: 4652
27 Dec 2018 21:24 #122971
Replied by andypugh on topic Tool error
You might need to reload the tool table.
- pl7i92
- Thank you received: 358
29 Dec 2018 15:28 #123086
by pl7i92
Replied by pl7i92 on topic Tool error
you may delete the VAR and TBL files in your
Mashine Folder
under Linuxcnc Configs MashineName
this helped me on the problem of copying the Config to a other pc where i had the same problem
THEN order of Toolcompensation is
First load the G-code
then
Edit tooltable SAVE file Reread file Reload file
in linuxcnc Reload Tooltable
and reload the G-code
Mashine Folder
then
Time to create page: 0.070 seconds
