Support for WHB04B 4/6 on LinuxCNC?
- nonkeldw
28 Dec 2018 18:31 #123027
by nonkeldw
Support for WHB04B 4/6 on LinuxCNC? was created by nonkeldw
Hello
I want to order this external handwheel on Ebay , WHB04B 4/6. Is this wireless handwheel already supported by LinuxCNC out of the box? I found en read a lot of topic about XHC-HB04, but this is not the same I think? I don't want to order this handwheel just for fun.
Haves anyone this handwheel already working with LinuxCNC?
- pl7i92
- Thank you received: 358
29 Dec 2018 15:23 - 29 Dec 2018 15:24 #123085
by pl7i92
Replied by pl7i92 on topic Support for WHB04B 4/6 on LinuxCNC?
there is a full out of the BOX linuxcnc Module that gets all the pins
so it is supported
BUT i URGENT say use a Wirerd USB XHC-hb04
this gives you full acces
the Wirerless will give you headbang if you act inpropper as it returns values on its own
AS well it uses Interupts that are not wanted on a Realtime system to interfear
i got 4 XHC-HB04 coustemised in use GREAT stuff
so it is supported
Last edit: 29 Dec 2018 15:24 by pl7i92. Reason: missing entrys
- nonkeldw
29 Dec 2018 17:24 #123104
by nonkeldw
Replied by nonkeldw on topic Support for WHB04B 4/6 on LinuxCNC?
Hello
Thanks for your reply.
I mean the WHB04B version not the XHC-hb04.
Thanks.
Thanks.
Time to create page: 0.210 seconds
