LinuxCNC Freezing
- BigBird
16 Oct 2019 15:27 #147998
by BigBird
Replied by BigBird on topic LinuxCNC Freezing
I had to put my LinuxCNC project on hold for quite a while, but I'm able to get back to work on it now. Unfortunately, I never did get Preempt-RT kernel (4.19.10-rt8) installed and my Ryzen system is still not functioning reliably with LinuxCNC.
I used the Qt Online Installer for Linux (32-bit) available at www.qt.io to install Qt5 under /home/linuxcnc. Then I followed PCW's instructions but when I get to "make xconfig" the following messages appear:
* Could not find Qt via pkg-config.
* Please install either Qt 4.8 or 5.x. and make sure it's in PKG_CONFIG_PATH
make[1]: *** [scripts/kconfig/.qconf-cfg] Error 1
make: *** [xconfig] Error 2
I get the same error message if I set PKG_CONFIG_PATH to
/home/linuxcnc
/home/linuxcnc/Qt
/home/linuxcnc/Qt/5.5
/home/linuxcnc/Qt/5.5/gcc
/home/linuxcnc/Qt/5.5/gcc/bin
I assume xconfig wants to run qmake which is in the bin file. Is there a different file I should be pointing to? Any ideas on how I can get to the next step in PCW's instructions?
Thanks!!
/home/linuxcnc
/home/linuxcnc/Qt
Thanks!!
- Online
- Thank you received: 7468
16 Oct 2019 15:33 #148000
Replied by tommylight on topic LinuxCNC Freezing
Why are you installing QT in a Linuxcnc folder ?
- BigBird
16 Oct 2019 16:06 - 17 Oct 2019 01:15 #148005
by BigBird
I don't believe I specified a location for it when I used the Qt online installer so I'm not sure why it showed up there. Maybe I was in the folder called linuxcnc when I ran the installer so it added it as a subfolder. Is it supposed to be in a specific folder?
It seemed to me that as long as PKG_CONFIG_PATH provided Qt's path to xconfig, it didn't matter where it was installed. Or am I missing something?
UPDATE: The path was suggested by the Qt installer and I accepted it. The installer was in the linuxcnc folder so it just added the Qt folder as a sub folder to linuxcnc.
UPDATE 1: After installing Qt5.5 in /opt/Qt I entered the following:
export PKG_CONFIG_PATH=/opt/Qt/5.5/gcc/lib/pkgconfig
and that took care of the "Could not find Qt via pkg-config".
Then I added the following to /etc/apt/sources.list:
deb archive.ubuntu.com/ubuntu/ trusty main restricted universe multiverse
deb archive.ubuntu.com/ubuntu/ trusty-security main restricted universe mult$
deb archive.ubuntu.com/ubuntu/ trusty-updates main restricted universe multi$
deb archive.ubuntu.com/ubuntu/ trusty-proposed main restricted universe mult$
deb archive.ubuntu.com/ubuntu/ trusty-backports main restricted universe mul$
to install flex and bison. After that, I got some more errors that looked like this:
HOSTLD scripts/kconfig/qconf
/usr/bin/ld: warning: libicui18n.so.54, needed by /opt/Qt/5.5/gcc/lib/libQt5Core.so, not found (try using -rpath or -rpath-link)
which I think caused a whole bunch of errors like this:
/opt/Qt/5.5/gcc/lib/libQt5Core.so: undefined reference to `ucnv_countAvailable_54'
All of this seems to be a problem in locating files and/or not having the right executables available.
Making some progress, but this is quite painful. Anybody have any thoughts on this?
Last edit: 17 Oct 2019 01:15 by BigBird. Reason: Provide additional information
- BigBird
22 Oct 2019 18:00 #148551
by BigBird
Just thought I'd close this out in case anyone else is having fun with a Ryzen 2200G.
I gave up and went with Intel.
Here's what I did before changing horses: I updated the motherboard BIOS. I tried two variations of the kernel all the way up to 5.2. And I built LinuxCNC on 5.2. But no luck....LinuxCNC would just freeze at random times.
It works on the Intel box though. Go figure. I thought they were interchangeable.
Maybe the Ryzen microcode updates due out in Nov 2019 via motherboard BIOS upgrade will fix the problem. Apparently there are over 100 fixes but I don't know how many fixes are specific to the 2200G.
