Two signals connected to one Output Pin
- GradeMind
- Topic Author
7 years 9 months ago #123881
by GradeMind
Two signals connected to one Output Pin was created by GradeMind
net emcmot.01.enable <= axis.1.amp-enable-out
net emcmot.04.enable <= axis.1.amp-enable-out
net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.01.enable pid.1.enable
net emcmot.04.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable
Is there a way to make this work?
Need to link the 2 together for a Tandem Gantry, so both motors are on one enable signal.
I tried Alias for the output pin, but it didn't work.
forum.linuxcnc.org/24-hal-components/33071-duplicating-signals
I see another person asked this and they said they made it work with:
not.0.in
not.0.out
Not sure how to do that?
not.0.in
not.0.out
- Thank you received: 5334
7 years 9 months ago #123899
Replied by PCW on topic Two signals connected to one Output Pin
net emcmot.01.enable => pid.1.enable
net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable
The following user(s) said Thank You: ikkuh, GradeMind
- GradeMind
- Topic Author
7 years 9 months ago #123923
by GradeMind
Replied by GradeMind on topic Two signals connected to one Output Pin
That did it -- thanks!
Didn't know you could reuse the same line like that, very interesting..
Also had to adjust this section near the top:
Top
..............etc
..............etc
# .write should be last after new outputs are computed
# in servo-thread
addf hm2_[HOSTMOT2](BOARD).0.write servo-thread
# external output signals
# --- X-ENABLE ---
net emcmot.00.enable hm2_5i25.0.7i76.0.0.output-00
# --- Y1-ENABLE ---
net emcmot.01.enable hm2_5i25.0.7i76.0.0.output-01
# --- Y2-ENABLE ---
net emcmot.01.enable hm2_5i25.0.7i76.0.0.output-04
Top
..............etc
..............etc
# in servo-thread
# --- X-ENABLE ---
# --- Y1-ENABLE ---
# --- Y2-ENABLE ---
- pl7i92
- Thank you received: 358
7 years 9 months ago #123982
by pl7i92
Replied by pl7i92 on topic Two signals connected to one Output Pin
To Get The Brain behind things
NET is the Signal Loaded only ones then You can output Multiple Times to Multiple PINS
OR use Logic if more then one in
LIKE
and2 This gives you a 2 Inputs must be on for the out
or logic eatch will trigger thew out
SEE www.linuxcnc.org/docs/html/man/man9/
THERE are all the good stuff listed
LIKE
The following user(s) said Thank You: GradeMind
- chili023
- Thank you received: 7
4 years 7 months ago #238354
by chili023
Replied by chili023 on topic Two signals connected to one Output Pin
Hi I have the sam problem. And I do not understand why this isn't possible.
I am trying to net two signals to one PIN.
Later this will not be nessecary but I need it for debugging.
net set-twitch-cw mh400e-gearbox.twitch-cw hm2_7i97.0.7i66.0.0.output-03 #Rechtslauf
net set-twitch-ccw mh400e-gearbox.twitch-ccw hm2_7i97.0.7i66.0.0.output-03 #Linkslauf
What am I not getting?
A.
A.
4 years 7 months ago #238356
What value should hm2_7i97.0.7i66.0.0.output-03 take when
mh400e-gearbox.twitch-cw is true and mh400e-gearbox.twitch-ccw
is false?
is false?
- chili023
4 years 7 months ago #238359
by chili023
Hi
Thanks for the reply.
It should be on. Like a circuit with two relays.
If ether relay is on there is power on the line.
But I get your point. If it is not programmed in it doesn’t work.
I will integrate it in my .comp file. I was just surprised that it doesn’t work.
Greetings from Berlin. Stay healthy
4 years 7 months ago #238360
In that case you should be able to accomplish
what you want with the "or" component
The following user(s) said Thank You: chili023
- chili023
4 years 7 months ago #238363
by chili023
Ahhh great.
I was not aware I could do logic in the Hal.
I feel stupid.
Thank you
I feel stupid.
Thank you
4 years 7 months ago #238365
You should feel empowered
