Two signals connected to one Output Pin
7 years 9 months ago #123881 by GradeMind
net emcmot.01.enable <= axis.1.amp-enable-out
net emcmot.04.enable <= axis.1.amp-enable-out
net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.01.enable pid.1.enable
net emcmot.04.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable
Is there a way to make this work?
Need to link the 2 together for a Tandem Gantry, so both motors are on one enable signal.
I tried Alias for the output pin, but it didn't work.
forum.linuxcnc.org/24-hal-components/33071-duplicating-signals
I see another person asked this and they said they made it work with:
not.0.in
not.0.out
Not sure how to do that?
7 years 9 months ago #123899 by PCW
net emcmot.01.enable => pid.1.enable
net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable
The following user(s) said Thank You: ikkuh, GradeMind
7 years 9 months ago #123923 by GradeMind
That did it -- thanks!
Didn't know you could reuse the same line like that, very interesting..
Also had to adjust this section near the top:
Top
..............etc
..............etc
# .write should be last after new outputs are computed
# in servo-thread
addf hm2_[HOSTMOT2](BOARD).0.write servo-thread
# external output signals
# --- X-ENABLE ---
net emcmot.00.enable hm2_5i25.0.7i76.0.0.output-00
# --- Y1-ENABLE ---
net emcmot.01.enable hm2_5i25.0.7i76.0.0.output-01
# --- Y2-ENABLE ---
net emcmot.01.enable hm2_5i25.0.7i76.0.0.output-04
7 years 9 months ago #123982 by pl7i92
To Get The Brain behind things
NET is the Signal Loaded only ones then You can output Multiple Times to Multiple PINS
OR use Logic if more then one in
LIKE
and2 This gives you a 2 Inputs must be on for the out
or logic eatch will trigger thew out
SEE www.linuxcnc.org/docs/html/man/man9/
THERE are all the good stuff listed
The following user(s) said Thank You: GradeMind
4 years 7 months ago #238354 by chili023
Hi I have the sam problem. And I do not understand why this isn't possible.
I am trying to net two signals to one PIN.
Later this will not be nessecary but I need it for debugging.
net set-twitch-cw mh400e-gearbox.twitch-cw hm2_7i97.0.7i66.0.0.output-03 #Rechtslauf
net set-twitch-ccw mh400e-gearbox.twitch-ccw hm2_7i97.0.7i66.0.0.output-03 #Linkslauf
What am I not getting?
A.
4 years 7 months ago #238356 by PCW
What value should hm2_7i97.0.7i66.0.0.output-03 take when
mh400e-gearbox.twitch-cw is true and mh400e-gearbox.twitch-ccw
is false?
Time to create page: 0.239 seconds
