Two signals connected to one Output Pin
4 years 7 months ago #238359 by chili023
Hi
Thanks for the reply.
It should be on. Like a circuit with two relays.
If ether relay is on there is power on the line.
But I get your point. If it is not programmed in it doesn’t work.
I will integrate it in my .comp file. I was just surprised that it doesn’t work.
Greetings from Berlin. Stay healthy
4 years 7 months ago #238360 by PCW
In that case you should be able to accomplish
what you want with the "or" component
The following user(s) said Thank You: chili023
4 years 7 months ago #238363 by chili023
Ahhh great.
I was not aware I could do logic in the Hal.
I feel stupid.
Thank you
4 years 7 months ago #238365 by PCW
You should feel empowered :-)
Time to create page: 0.180 seconds
