Help with getting linuxcnc to turn on router
- sandman92k
15 Jan 2019 00:52 #124207
by sandman92k
Help with getting linuxcnc to turn on router was created by sandman92k
I run a dewalt router on my cnc and i can not seem to find where to confrig to get the computer to turn on the router automatically
any help I would appreciate
- Grotius
- Thank you received: 2349
15 Jan 2019 01:14 #124210
by Grotius
Replied by Grotius on topic Help with getting linuxcnc to turn on router
@Sandman,
The linuxcnc wizard's will do that for you. Try it. In the output hal file of this, you will find "spindle" if you have Mesa it will be connected to a given mesa i/0 port. If you use parport, it will output problably parport 1, pin 17.
The dewalt router on off switch has to be active. And i think you need to adapt a female power plug for your dewalt router on your cnc portal, wich is connected to the on/off relais of your interface board. For higher power consumption's a secondairy power relais is an option to implement.
Good luck !
Good luck !
The following user(s) said Thank You: sandman92k
- BigJohnT
- Thank you received: 994
15 Jan 2019 21:10 #124267
by BigJohnT
Replied by BigJohnT on topic Help with getting linuxcnc to turn on router
You need to connect motion.spindle−on to an output.
JT
JT
