Rapid speed Solved
  • JohnnyCNC
  • JohnnyCNC's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Jan 2019 16:46 #124438 by JohnnyCNC
Rapid speed was created by JohnnyCNC
Now that I've had my converted X3 mill running for a year I'm doing some fine tuning. I running AXIS and using a using a VistaCNC P4-SE pendant. I was trying to speed up the rapids and they are now much faster than before but only when using the pendant in velocity mode and for the short move after homing that takes the axis to the home offset location. When I issue a G0 X2 the axis moves at the same pace it used to. What an I missing?
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 6.0
MAX_ACCELERATION = 36.0
HOME_SEQUENCE=1
HOME_SEARCH_VEL = -.90000
HOME_LATCH_VEL = .10000
BACKLASH = 0.0001
STEPGEN_MAXVEL = 6.3
STEPGEN_MAXACCEL = 61.2
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 200
DIRHOLD = 200
STEPLEN = 1000
STEPSPACE = 2000
STEP_SCALE = 10160.000
MIN_LIMIT = -0.001
MAX_LIMIT = 19.7
HOME_OFFSET = 0.6
19 Jan 2019 17:00 #124440 by Leon82
Replied by Leon82 on topic Rapid speed
Is your rapid override set to 50% when you enter the GUI
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
19 Jan 2019 17:08 #124441 by JohnnyCNC
Replied by JohnnyCNC on topic Rapid speed
It is set to 100%
I also just changed the MAX_LINEAR_VELOCITY from 1 to 6 in the [TRAJ] section and that had no effect.
19 Jan 2019 17:16 #124442 by Leon82
Are there other velocity parameters in the top of the ini? I can't remember if there was
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
19 Jan 2019 17:53 #124445 by JohnnyCNC
There are some in the [DISPLAY] and [TRAJ] sections.
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/john/linuxcnc/nc_files
PYVCP = pyvcp-panel.xml
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.50
MAX_LINEAR_VELOCITY = 6.00
19 Jan 2019 18:33 #124447 by Leon82
What's default velocity
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
19 Jan 2019 19:08 #124450 by JohnnyCNC
This is what the manual says. I tried playing with DEFAULT_VELOCITY but it didn't change what I am looking for.
DEFAULT_VELOCITY = 0.0167 - The initial rate for jogs of linear axes, in machine units per second. The value shown in Axis equals machine units per minute.
DEFAULT_LINEAR_VELOCITY = .25 - The default velocity for linear jogs, in , machine units per second.
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
19 Jan 2019 19:43 #124453 by JohnnyCNC
Replied by JohnnyCNC on topic Rapid speed - Solved
It was this. I thought I had tried a different value but apparently not. I changed it from 1 to 4 and G0 moves are now faster. Now I just need to decide just how fast I want it. It looks like it can go a lot faster than I would be comfortable with.
[DISPLAY]
MAX_LINEAR_VELOCITY = 4.000000
Thanks Leon82
19 Jan 2019 21:12 #124458 by Leon82
Nice,
I've got an x3 also but haven't gone over 2 on my velocity yet
19 Jan 2019 21:18 #124459 by Leon82
Perhaps something like a homing macro works outside of axis so it's not governed by that parameter
Time to create page: 0.344 seconds
