Single Board PC for LinuxCnc
- vmihalca
- Thank you received: 22
26 Jan 2019 17:34 #124908
by vmihalca
Single Board PC for LinuxCnc was created by vmihalca
Hello,
I am thinking to buy this mini pc with 4Gb Ram and 64Gb ssd to use it only for LinuxCnc
www.aliexpress.com/item/Small-Form-PC-Du...alm/32804200687.html
There was a post somewere where I think I saw that PCW has one of these.
Please let me know if you think its ok, so that I can order it.
I needed 2 ethernet ports since I have two Mesa 7i76e (lathe and mill) and I hope I will be able to hook both of those to this PC
Do you think processor is powerful enough for what I need?
Thanks,
Vasi
Thanks,
Vasi
- Thank you received: 5321
26 Jan 2019 19:06 #124919
Replied by PCW on topic Single Board PC for LinuxCnc
It should be OK , note that you really don't really need 2 LAN ports if you don't mind using a USB --> Ethernet or USB --> WIFI dongle for internet
- vmihalca
27 Jan 2019 09:54 #124953
by vmihalca
Replied by vmihalca on topic Single Board PC for LinuxCnc
Would that still be realtime? One of the reasons I know ethernet is preferred over the usb, is that usb is buffered.
Did I understood correctly? Do you have the same PC?
How do you find the configuration, is it capable enough for linuxcnc?
- Leon82
- Thank you received: 79
27 Jan 2019 13:15 #124963
by Leon82
Replied by Leon82 on topic Single Board PC for LinuxCnc
Hp also makes a mini PC like that
HP HPELT705T-R EliteDesk 705 G1 Mini AMD 3.1 GHz Desktop, 8GB RAM, Windows 10 Pro www.amazon.com/dp/B07BMNBFYW/ref=cm_sw_r_cp_apa_i_C6AtCb51A49EF
- Thank you received: 4652
29 Jan 2019 17:31 #125182
I think he was meaning one LAN port for each machine tool, ie 2 x 7i76E or whatever and different configs using each one.
As a tip: You might want to use the loadrt hostmot2 use_serial_numbers=1 option, so that the 7i76 (or other) smart-serial devices are identified by serial number just in case the system swaps the boards / ports around on you.
Replied by andypugh on topic Single Board PC for LinuxCnc
29 Jan 2019 17:37 #125184
Ahh, I missed that he had 2 7I76Es
You can also use a Ethernet switch in this circumstance (at the expense of perhaps 100 usec of additional store+forward latency from the switch)
Not much danger of the system swapping boards if you chose a different
IP address for each 7I76E
