where are the f*ng rtapi_print_msg(RTAPI_MSG_INFO, -messages?
- wicki
- Thank you received: 21
27 Jan 2019 09:32 - 27 Jan 2019 09:32 #124952
by wicki
where are the f*ng rtapi_print_msg(RTAPI_MSG_INFO, -messages? was created by wicki
I remember, that I have always been bothered by these missing messages
even if I set
DEBUG = 0xFFFFFFFF
there is NOTHING.
not on the screen, not in the terminal, not in the logs (pring, debug, dmesg)
what's the problem with it?
if the messages don't appear, why just send them to /dev/null an deletethis stupid
RTAPI_MSG_INFO from the docs?
the solution from 2012 (this forum) may help - but it is not really a solution
Consequently I use rtapi_print_msg(RTAPI_MSG_ERR, " .........."); for debugging, even for none errors.
It displays to Axis and in the terminal.
even if I set
DEBUG = 0xFFFFFFFF
there is NOTHING.
Last edit: 27 Jan 2019 09:32 by wicki.
- Thank you received: 4652
29 Jan 2019 17:27 - 29 Jan 2019 17:27 #125181
Replied by andypugh on topic where are the f*ng rtapi_print_msg(RTAPI_MSG_INFO, -messages?
The rtapi messaging level is not controlled by the DEBUG= INI entry. It is a separate mask.
It used to be the case that you could set it (by the rather Byzantine method of)
echo 6 > /proc/trapi/debug
But I think that no longer works.
sourceforge.net/p/emc/mailman/emc-develo...priv.at/#msg30532123
Here is a suggestion, a little custom component. (untested)
You can loadrt this, then setp it in your HAL file, or from the halcmd prompt while the system is running.
component set_message_level;
param rw level
static int last_level = 0
if (last_level != level){
rtapi_set_msg_level(level)
}You can loadrt this, then setp it in your HAL file, or from the halcmd prompt while the system is running.
Last edit: 29 Jan 2019 17:27 by andypugh.
- wicki
30 Jan 2019 17:28 #125312
by wicki
that's the hint! thx
in the original-driver is a
rtapi_set_msg_level(RTAPI_MSG_WARN);
thatÅ› the reason why no info-messages are shown.....
Replied by wicki on topic where are the f*ng rtapi_print_msg(RTAPI_MSG_INFO, -messages?
It used to be the case that you could set [....]
Time to create page: 0.079 seconds
