New 7I76E install error when launching linuxcnc
  • yoshimitsuspeed
  • Premium Member
  • Premium Member
29 Jan 2019 06:36 - 29 Jan 2019 23:12 #125132 by yoshimitsuspeed
New 7I76E install error when launching linuxcnc was created by yoshimitsuspeed
So I just upgraded from whatever generic controller my kit came with to a 7i76e. I am still waiting for the power supply to come in for the desktop I will be using as the old one just died. So for now I am trying to get this working on my M1710 laptop.
I installed the stretch version of linuxcnc, changed the IP on the board to 10.10.10.10, got a ping from the board, and then ran pnconf setup. The laptop is connected to the board but the board isn't connected to anything else.
Oh and when I ran updates I thought the buildbot repo was 2.8 so I selected that and ran updates. Then after getting this error I realized my mistake, added the master repo and ran updates again.
When I try to launch the machine controller it gives the following error and report. It seems to me like it's an issue with the configs or something but more than I could figure out on my own. If it's an issue with it being a laptop I can wait till I get my mini tower repaired but it doesn't seem like that's the issue and if I can get things working on the laptop to get a behind schedule project knocked out it would be best.
Debug
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./Mesa_2.8.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./Mesa_2.8.hal:8: /usr/bin/rtapi_app exited without becoming ready
./Mesa_2.8.hal:8: insmod for hm2_eth failed, returned -1
5986
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-4511-g649f421f0
Machine configuration directory is '/home/yoshi/linuxcnc/configs/Mesa_2.8'
Machine configuration file is 'Mesa_2.8.ini'
INIFILE=/home/yoshi/linuxcnc/configs/Mesa_2.8/Mesa_2.8.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ kinstype=BOTH
Starting LinuxCNC...
Found file(REL): ./Mesa_2.8.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=12321
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:42:df
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0:     IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 010 (P1-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 011 (P1-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0:     IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0:     IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0:     IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
./Mesa_2.8.hal:253: parameter or pin 'hm2_7i76e.0.7i76.0.0.spinout-minlim' not found
12321
Kernel message information:
[    0.000000] microcode: microcode updated early to revision 0xd1, date = 2010-10-01
[    0.000000] Linux version 4.9.0-8-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.130-2 (2018-10-27)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=dcfb27a6-9e7a-401d-87ad-9c8a2bbb2703 ro quiet
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007fed9bff] usable
[    0.000000] BIOS-e820: [mem 0x000000007fed9c00-0x000000007fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f4006fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f4008000-0x00000000f400bfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed9ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee0ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.4 present.
[    0.000000] DMI: Dell Inc. MXG061                          /0CF456, BIOS A07 06/27/2007
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x7fed9 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F80000000 write-back
[    0.000000]   1 base 07FF00000 mask FFFF00000 uncachable
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] Base memory trampoline at [ffff903740099000] 99000 size 24576
[    0.000000] BRK [0x269c0000, 0x269c0fff] PGTABLE
[    0.000000] BRK [0x269c1000, 0x269c1fff] PGTABLE
[    0.000000] BRK [0x269c2000, 0x269c2fff] PGTABLE
[    0.000000] BRK [0x269c3000, 0x269c3fff] PGTABLE
[    0.000000] BRK [0x269c4000, 0x269c4fff] PGTABLE
[    0.000000] BRK [0x269c5000, 0x269c5fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x34f1f000-0x36786fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000FC1D0 000014 (v00 DELL  )
[    0.000000] ACPI: RSDT 0x000000007FEDA148 000044 (v01 DELL   M07      27D7061B ASL  00000061)
[    0.000000] ACPI: FACP 0x000000007FEDB000 000074 (v01 DELL   M07      27D7061B ASL  00000061)
[    0.000000] ACPI: DSDT 0x000000007FEDBC00 004B19 (v01 INT430 SYSFexxx 00001001 INTL 20050624)
[    0.000000] ACPI: FACS 0x000000007FEEA400 000040
[    0.000000] ACPI: HPET 0x000000007FEDB700 000038 (v01 DELL   M07      00000001 ASL  00000061)
[    0.000000] ACPI: APIC 0x000000007FEDB800 000068 (v01 DELL   M07      27D7061B ASL  00000047)
[    0.000000] ACPI: MCFG 0x000000007FEDB7C0 00003E (v16 DELL   M07      27D7061B ASL  00000061)
[    0.000000] ACPI: SLIC 0x000000007FEDB89C 000176 (v01 DELL   M07      27D7061B ASL  00000061)
[    0.000000] ACPI: OSFR 0x000000007FEDAE00 00002C (v01 DELL   M07      27D7061B ASL  00000061)
[    0.000000] ACPI: BOOT 0x000000007FEDB3C0 000028 (v01 DELL   M07      27D7061B ASL  00000061)
[    0.000000] ACPI: SSDT 0x000000007FEDA1CF 0004DC (v01 PmRef  CpuPm    00003000 INTL 20050624)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000007fed8fff]
[    0.000000] NODE_DATA(0) allocated [mem 0x7fed4000-0x7fed8fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x000000007fed8fff]
[    0.000000]   Normal   empty
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000007fed8fff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007fed8fff]
[    0.000000] On node 0 totalpages: 523895
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 8124 pages used for memmap
[    0.000000]   DMA32 zone: 519897 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x1008
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] e820: [mem 0x80000000-0xefffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffff9037bfc00000 s437952 r8192 d28992 u1048576
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u1048576 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 515686
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=dcfb27a6-9e7a-401d-87ad-9c8a2bbb2703 ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 2020552K/2095580K available (6395K kernel code, 1152K rwdata, 2912K rodata, 1680K init, 968K bss, 75028K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:33024 nr_irqs:440 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2330.019 MHz processor
[    0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 4660.03 BogoMIPS (lpj=9320076)
[    0.004008] pid_max: default: 32768 minimum: 301
[    0.004026] ACPI: Core revision 20160831
[    0.010322] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.010362] Security Framework initialized
[    0.010364] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.010373] AppArmor: AppArmor disabled by boot time parameter
[    0.010804] Dentry cache hash table entries: 262144 (order: 10, 4194304 bytes)
[    0.013541] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.014345] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.014349] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.014860] mce: CPU supports 6 MCE banks
[    0.014869] CPU0: Thermal monitoring enabled (TM2)
[    0.014876] process: using mwait in idle threads
[    0.014882] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[    0.014883] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[    0.014886] Spectre V2 : Mitigation: Full generic retpoline
[    0.014887] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.014887] Speculative Store Bypass: Vulnerable
[    0.015336] Freeing SMP alternatives memory: 24K
[    0.017371] ftrace: allocating 25238 entries in 99 pages
[    0.040182] smpboot: Max logical packages: 1
[    0.040663] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.084000] smpboot: CPU0: Intel(R) Core(TM)2 CPU         T7600  @ 2.33GHz (family: 0x6, model: 0xf, stepping: 0x6)
[    0.084000] Performance Events: PEBS fmt0-, Core2 events, Intel PMU driver.
[    0.084000] core: PEBS disabled due to CPU errata
[    0.084000] ... version:                2
[    0.084000] ... bit width:              40
[    0.084000] ... generic registers:      2
[    0.084000] ... value mask:             000000ffffffffff
[    0.084000] ... max period:             000000007fffffff
[    0.084000] ... fixed-purpose events:   3
[    0.084000] ... event mask:             0000000700000003
[    0.136125] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.188025] x86: Booting SMP configuration:
[    0.188026] .... node  #0, CPUs:      #1
[    0.191018] TSC synchronization [CPU#0 -> CPU#1]:
[    0.191019] Measured 4571783692 cycles TSC warp between CPUs, turning off TSC clock.
[    0.191029] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[    0.191136] x86: Booted up 1 node, 2 CPUs
[    0.191136] smpboot: Total of 2 processors activated (9320.07 BogoMIPS)
[    0.192260] devtmpfs: initialized
[    0.192260] x86/mm: Memory block size: 128MB
[    0.196103] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.196118] futex hash table entries: 512 (order: 4, 65536 bytes)
[    0.196181] pinctrl core: initialized pinctrl subsystem
[    0.196379] NET: Registered protocol family 16
[    0.200016] cpuidle: using governor ladder
[    0.200021] cpuidle: using governor menu
[    0.200028] Simple Boot Flag at 0x79 set to 0x80
[    0.200041] ACPI: bus type PCI registered
[    0.200043] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.200133] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[    0.200136] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in E820
[    0.200147] PCI: Using configuration type 1 for base access
[    0.200156] dmi type 0xB1 record - unknown flag
[    0.200177] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.200177] mtrr: probably your BIOS does not setup all CPUs.
[    0.200177] mtrr: corrected configuration.
[    0.204051] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.204095] ACPI: Added _OSI(Module Device)
[    0.204095] ACPI: Added _OSI(Processor Device)
[    0.204095] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.204095] ACPI: Added _OSI(Processor Aggregator Device)
[    0.209573] ACPI: Dynamic OEM Table Load:
[    0.209581] ACPI: SSDT 0xFFFF9037BC519F60 000043 (v01 LMPWR  DELLLOM  00001001 INTL 20050624)
[    0.209924] ACPI: Dynamic OEM Table Load:
[    0.209930] ACPI: SSDT 0xFFFF9037BC54C800 000286 (v01 PmRef  Cpu0Ist  00003000 INTL 20050624)
[    0.210106] ACPI: Dynamic OEM Table Load:
[    0.210111] ACPI: SSDT 0xFFFF9037BC504A00 0001C6 (v01 PmRef  Cpu0Cst  00003001 INTL 20050624)
[    0.210405] ACPI: Dynamic OEM Table Load:
[    0.210411] ACPI: SSDT 0xFFFF9037BC510200 0000C4 (v01 PmRef  Cpu1Ist  00003000 INTL 20050624)
[    0.210554] ACPI: Dynamic OEM Table Load:
[    0.210560] ACPI: SSDT 0xFFFF9037BC55D240 000085 (v01 PmRef  Cpu1Cst  00003000 INTL 20050624)
[    0.210983] ACPI: Interpreter enabled
[    0.211003] ACPI: (supports S0 S3 S4 S5)
[    0.211005] ACPI: Using IOAPIC for interrupt routing
[    0.211032] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.240629] acpi PNP0C15:00: ACPI dock station (docks/bays count: 1)
[    0.247788] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.247794] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.247799] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.247809] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.253523] PCI host bridge to bus 0000:00
[    0.253526] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.253528] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.253530] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.253532] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[    0.253534] pci_bus 0000:00: root bus resource [mem 0x80000000-0xefffffff window]
[    0.253536] pci_bus 0000:00: root bus resource [mem 0xf4007000-0xf4007fff window]
[    0.253538] pci_bus 0000:00: root bus resource [mem 0xf400c000-0xfebfffff window]
[    0.253540] pci_bus 0000:00: root bus resource [mem 0xfec10000-0xfecfffff window]
[    0.253542] pci_bus 0000:00: root bus resource [mem 0xfed00400-0xfed1ffff window]
[    0.253548] pci_bus 0000:00: root bus resource [mem 0xfee10000-0xffafffff window]
[    0.253550] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.253561] pci 0000:00:00.0: [8086:27a0] type 00 class 0x060000
[    0.253699] pci 0000:00:01.0: [8086:27a1] type 01 class 0x060400
[    0.253750] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.253909] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[    0.253935] pci 0000:00:1b.0: reg 0x10: [mem 0xefffc000-0xefffffff 64bit]
[    0.254046] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.254113] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.254180] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[    0.254293] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.254361] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.254426] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[    0.254538] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.254606] pci 0000:00:1c.1: System wakeup disabled by ACPI
[    0.254671] pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400
[    0.254783] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.254916] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[    0.255029] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.255099] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.255165] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[    0.255222] pci 0000:00:1d.0: reg 0x20: [io  0xbf80-0xbf9f]
[    0.256775] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.256840] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[    0.256897] pci 0000:00:1d.1: reg 0x20: [io  0xbf60-0xbf7f]
[    0.258399] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.258462] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[    0.258519] pci 0000:00:1d.2: reg 0x20: [io  0xbf40-0xbf5f]
[    0.260067] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.260130] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[    0.260187] pci 0000:00:1d.3: reg 0x20: [io  0xbf20-0xbf3f]
[    0.261714] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.261786] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[    0.261808] pci 0000:00:1d.7: reg 0x10: [mem 0xffa80000-0xffa803ff]
[    0.261912] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.263447] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.263513] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[    0.263644] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.263709] pci 0000:00:1f.0: [8086:27b9] type 00 class 0x060100
[    0.263824] pci 0000:00:1f.0: quirk: [io  0x1000-0x107f] claimed by ICH6 ACPI/GPIO/TCO
[    0.263830] pci 0000:00:1f.0: quirk: [io  0x1080-0x10bf] claimed by ICH6 GPIO
[    0.263834] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0900 (mask 007f)
[    0.263840] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0c80 (mask 003f)
[    0.263983] pci 0000:00:1f.2: [8086:27c4] type 00 class 0x010180
[    0.264020] pci 0000:00:1f.2: reg 0x10: [io  0x01f0-0x01f7]
[    0.264032] pci 0000:00:1f.2: reg 0x14: [io  0x03f4-0x03f7]
[    0.264044] pci 0000:00:1f.2: reg 0x18: [io  0x0170-0x0177]
[    0.264056] pci 0000:00:1f.2: reg 0x1c: [io  0x0374-0x0377]
[    0.264067] pci 0000:00:1f.2: reg 0x20: [io  0xbfa0-0xbfaf]
[    0.264093] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.264095] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.264097] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.264099] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.264133] pci 0000:00:1f.2: PME# supported from D3hot
[    0.264247] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[    0.264321] pci 0000:00:1f.3: reg 0x20: [io  0x10c0-0x10df]
[    0.264529] pci 0000:01:00.0: [10de:029a] type 00 class 0x030000
[    0.264542] pci 0000:01:00.0: reg 0x10: [mem 0xed000000-0xedffffff]
[    0.264554] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.264565] pci 0000:01:00.0: reg 0x1c: [mem 0xee000000-0xeeffffff 64bit]
[    0.264573] pci 0000:01:00.0: reg 0x24: [io  0xef00-0xef7f]
[    0.264581] pci 0000:01:00.0: reg 0x30: [mem 0xefe00000-0xefe1ffff pref]
[    0.264687] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device.  You can enable it with 'pcie_aspm=force'
[    0.264695] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.264698] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.264701] pci 0000:00:01.0:   bridge window [mem 0xed000000-0xefefffff]
[    0.264706] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.264787] pci 0000:00:1c.0: PCI bridge to [bus 0b]
[    0.264979] pci 0000:0c:00.0: [8086:4222] type 00 class 0x028000
[    0.265045] pci 0000:0c:00.0: reg 0x10: [mem 0xecfff000-0xecffffff]
[    0.265484] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold
[    0.265645] pci 0000:0c:00.0: disabling ASPM on pre-1.1 PCIe device.  You can enable it with 'pcie_aspm=force'
[    0.265672] pci 0000:00:1c.1: PCI bridge to [bus 0c]
[    0.265679] pci 0000:00:1c.1:   bridge window [mem 0xecf00000-0xecffffff]
[    0.265837] pci 0000:09:00.0: [14e4:1600] type 00 class 0x020000
[    0.265872] pci 0000:09:00.0: reg 0x10: [mem 0xecef0000-0xecefffff 64bit]
[    0.266052] pci 0000:09:00.0: PME# supported from D3hot D3cold
[    0.266101] pci 0000:09:00.0: System wakeup disabled by ACPI
[    0.266190] pci 0000:09:00.0: disabling ASPM on pre-1.1 PCIe device.  You can enable it with 'pcie_aspm=force'
[    0.266202] pci 0000:00:1c.2: PCI bridge to [bus 09]
[    0.266210] pci 0000:00:1c.2:   bridge window [mem 0xece00000-0xecefffff]
[    0.266325] acpiphp: Slot [1] registered
[    0.266332] pci 0000:00:1c.3: PCI bridge to [bus 0d-0e]
[    0.266337] pci 0000:00:1c.3:   bridge window [io  0xd000-0xdfff]
[    0.266341] pci 0000:00:1c.3:   bridge window [mem 0xecc00000-0xecdfffff]
[    0.266349] pci 0000:00:1c.3:   bridge window [mem 0xe0000000-0xe01fffff 64bit pref]
[    0.266445] pci 0000:03:01.0: [1180:0832] type 00 class 0x0c0010
[    0.266459] pci 0000:03:01.0: proprietary Ricoh MMC controller disabled (via firewire function)
[    0.266461] pci 0000:03:01.0: MMC cards are now supported by standard SDHCI controller
[    0.266477] pci 0000:03:01.0: reg 0x10: [mem 0xecbff800-0xecbfffff]
[    0.266578] pci 0000:03:01.0: supports D1 D2
[    0.266580] pci 0000:03:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.266666] pci 0000:03:01.1: [1180:0822] type 00 class 0x080501
[    0.266688] pci 0000:03:01.1: reg 0x10: [mem 0xecbff400-0xecbff4ff]
[    0.266789] pci 0000:03:01.1: supports D1 D2
[    0.266791] pci 0000:03:01.1: PME# supported from D0 D1 D2 D3hot D3cold
[    0.266875] pci 0000:03:01.2: [1180:0592] type 00 class 0x088000
[    0.266896] pci 0000:03:01.2: reg 0x10: [mem 0xecbff600-0xecbff6ff]
[    0.266997] pci 0000:03:01.2: supports D1 D2
[    0.266999] pci 0000:03:01.2: PME# supported from D0 D1 D2 D3hot D3cold
[    0.267079] pci 0000:03:01.3: [1180:0852] type 00 class 0x088000
[    0.267100] pci 0000:03:01.3: reg 0x10: [mem 0xecbff700-0xecbff7ff]
[    0.267201] pci 0000:03:01.3: supports D1 D2
[    0.267203] pci 0000:03:01.3: PME# supported from D0 D1 D2 D3hot D3cold
[    0.267337] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[    0.267345] pci 0000:00:1e.0:   bridge window [mem 0xecb00000-0xecbfffff]
[    0.267353] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.267355] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.267357] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.267359] pci 0000:00:1e.0:   bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[    0.267361] pci 0000:00:1e.0:   bridge window [mem 0x80000000-0xefffffff window] (subtractive decode)
[    0.267363] pci 0000:00:1e.0:   bridge window [mem 0xf4007000-0xf4007fff window] (subtractive decode)
[    0.267365] pci 0000:00:1e.0:   bridge window [mem 0xf400c000-0xfebfffff window] (subtractive decode)
[    0.267367] pci 0000:00:1e.0:   bridge window [mem 0xfec10000-0xfecfffff window] (subtractive decode)
[    0.267369] pci 0000:00:1e.0:   bridge window [mem 0xfed00400-0xfed1ffff window] (subtractive decode)
[    0.267371] pci 0000:00:1e.0:   bridge window [mem 0xfee10000-0xffafffff window] (subtractive decode)
[    0.269914] ACPI: PCI Interrupt Link [LNKA] (IRQs *9 10 11)
[    0.270006] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7) *3
[    0.270096] ACPI: PCI Interrupt Link [LNKC] (IRQs 9 10 11) *5
[    0.270187] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 9 10 *11)
[    0.270278] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[    0.270373] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.270468] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[    0.270562] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[    0.271255] ACPI: Enabled 3 GPEs in block 00 to 1F
[    0.272403] vgaarb: setting as boot device: PCI:0000:01:00.0
[    0.272403] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.272403] vgaarb: loaded
[    0.272403] vgaarb: bridge control possible 0000:01:00.0
[    0.272408] PCI: Using ACPI for IRQ routing
[    0.274470] PCI: pci_cache_line_size set to 64 bytes
[    0.274560] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.274562] e820: reserve RAM buffer [mem 0x7fed9c00-0x7fffffff]
[    0.276091] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.276097] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.276102] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.280028] clocksource: Switched to clocksource hpet
[    0.296365] VFS: Disk quotas dquot_6.6.0
[    0.296403] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.296559] pnp: PnP ACPI init
[    0.305426] system 00:00: [mem 0x00000000-0x0009fbff] could not be reserved
[    0.305429] system 00:00: [mem 0x0009fc00-0x0009ffff] could not be reserved
[    0.305432] system 00:00: [mem 0x000c0000-0x000cffff] could not be reserved
[    0.305434] system 00:00: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.305437] system 00:00: [mem 0x00100000-0x7fed9bff] could not be reserved
[    0.305439] system 00:00: [mem 0x7fed9c00-0x7fefffff] has been reserved
[    0.305442] system 00:00: [mem 0x7ff00000-0x7fffffff] has been reserved
[    0.305446] system 00:00: [mem 0xffb00000-0xffffffff] has been reserved
[    0.305448] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[    0.305451] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[    0.305453] system 00:00: [mem 0xfed20000-0xfed9ffff] has been reserved
[    0.305456] system 00:00: [mem 0xffa80000-0xffa83fff] could not be reserved
[    0.305458] system 00:00: [mem 0xf4000000-0xf4003fff] has been reserved
[    0.305461] system 00:00: [mem 0xf4004000-0xf4004fff] has been reserved
[    0.305463] system 00:00: [mem 0xf4005000-0xf4005fff] has been reserved
[    0.305466] system 00:00: [mem 0xf4006000-0xf4006fff] has been reserved
[    0.305468] system 00:00: [mem 0xf4008000-0xf400bfff] has been reserved
[    0.305471] system 00:00: [mem 0xf0000000-0xf3ffffff] has been reserved
[    0.305478] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.305515] pnp 00:01: disabling [io  0x1000-0x1005] because it overlaps 0000:00:1f.0 BAR 13 [io  0x1000-0x107f]
[    0.305518] pnp 00:01: disabling [io  0x1008-0x100f] because it overlaps 0000:00:1f.0 BAR 13 [io  0x1000-0x107f]
[    0.305562] system 00:01: [io  0x04d0-0x04d1] has been reserved
[    0.305567] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.305599] pnp 00:02: disabling [io  0x1006-0x1007] because it overlaps 0000:00:1f.0 BAR 13 [io  0x1000-0x107f]
[    0.305601] pnp 00:02: disabling [io  0x100a-0x1059] because it overlaps 0000:00:1f.0 BAR 13 [io  0x1000-0x107f]
[    0.305604] pnp 00:02: disabling [io  0x1060-0x107f] because it overlaps 0000:00:1f.0 BAR 13 [io  0x1000-0x107f]
[    0.305606] pnp 00:02: disabling [io  0x1010-0x102f] because it overlaps 0000:00:1f.0 BAR 13 [io  0x1000-0x107f]
[    0.305654] system 00:02: [io  0xf400-0xf4fe] has been reserved
[    0.305656] system 00:02: [io  0x1080-0x10bf] has been reserved
[    0.305659] system 00:02: [io  0x10c0-0x10df] has been reserved
[    0.305662] system 00:02: [io  0x0809] has been reserved
[    0.305666] system 00:02: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.305723] pnp 00:03: Plug and Play ACPI device, IDs PNP0f13 (active)
[    0.305770] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.305820] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.305890] system 00:06: [io  0x0c80-0x0cff] could not be reserved
[    0.305893] system 00:06: [io  0x0910-0x091f] has been reserved
[    0.305896] system 00:06: [io  0x0920-0x092f] has been reserved
[    0.305898] system 00:06: [io  0x0cb0-0x0cbf] has been reserved
[    0.305900] system 00:06: [io  0x0930-0x097f] has been reserved
[    0.305904] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.306000] system 00:07: [mem 0xfed00000-0xfed003ff] has been reserved
[    0.306005] system 00:07: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[    0.308986] pnp: PnP ACPI: found 8 devices
[    0.317335] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.317363] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 0b] add_size 1000
[    0.317367] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0b] add_size 200000 add_align 100000
[    0.317369] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 0b] add_size 200000 add_align 100000
[    0.317381] pci 0000:00:1c.1: bridge window [io  0x1000-0x0fff] to [bus 0c] add_size 1000
[    0.317384] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0c] add_size 200000 add_align 100000
[    0.317395] pci 0000:00:1c.2: bridge window [io  0x1000-0x0fff] to [bus 09] add_size 1000
[    0.317398] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 09] add_size 200000 add_align 100000
[    0.317429] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.317431] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.317434] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.317436] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.317438] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.317441] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.317443] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.317445] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.317448] pci 0000:00:1c.0: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.317450] pci 0000:00:1c.0: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.317452] pci 0000:00:1c.1: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.317455] pci 0000:00:1c.1: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.317457] pci 0000:00:1c.2: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.317459] pci 0000:00:1c.2: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.317466] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
[    0.317474] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[    0.317481] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref]
[    0.317487] pci 0000:00:1c.2: BAR 15: assigned [mem 0x80600000-0x807fffff 64bit pref]
[    0.317491] pci 0000:00:1c.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.317494] pci 0000:00:1c.1: BAR 13: assigned [io  0x3000-0x3fff]
[    0.317497] pci 0000:00:1c.2: BAR 13: assigned [io  0x4000-0x4fff]
[    0.317502] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.317505] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.317509] pci 0000:00:01.0:   bridge window [mem 0xed000000-0xefefffff]
[    0.317512] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.317517] pci 0000:00:1c.0: PCI bridge to [bus 0b]
[    0.317520] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.317526] pci 0000:00:1c.0:   bridge window [mem 0x80000000-0x801fffff]
[    0.317531] pci 0000:00:1c.0:   bridge window [mem 0x80200000-0x803fffff 64bit pref]
[    0.317539] pci 0000:00:1c.1: PCI bridge to [bus 0c]
[    0.317542] pci 0000:00:1c.1:   bridge window [io  0x3000-0x3fff]
[    0.317548] pci 0000:00:1c.1:   bridge window [mem 0xecf00000-0xecffffff]
[    0.317553] pci 0000:00:1c.1:   bridge window [mem 0x80400000-0x805fffff 64bit pref]
[    0.317561] pci 0000:00:1c.2: PCI bridge to [bus 09]
[    0.317564] pci 0000:00:1c.2:   bridge window [io  0x4000-0x4fff]
[    0.317570] pci 0000:00:1c.2:   bridge window [mem 0xece00000-0xecefffff]
[    0.317575] pci 0000:00:1c.2:   bridge window [mem 0x80600000-0x807fffff 64bit pref]
[    0.317583] pci 0000:00:1c.3: PCI bridge to [bus 0d-0e]
[    0.317586] pci 0000:00:1c.3:   bridge window [io  0xd000-0xdfff]
[    0.317592] pci 0000:00:1c.3:   bridge window [mem 0xecc00000-0xecdfffff]
[    0.317597] pci 0000:00:1c.3:   bridge window [mem 0xe0000000-0xe01fffff 64bit pref]
[    0.317605] pci 0000:00:1e.0: PCI bridge to [bus 03]
[    0.317612] pci 0000:00:1e.0:   bridge window [mem 0xecb00000-0xecbfffff]
[    0.317623] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.317626] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.317628] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.317630] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[    0.317632] pci_bus 0000:00: resource 8 [mem 0x80000000-0xefffffff window]
[    0.317634] pci_bus 0000:00: resource 9 [mem 0xf4007000-0xf4007fff window]
[    0.317636] pci_bus 0000:00: resource 10 [mem 0xf400c000-0xfebfffff window]
[    0.317638] pci_bus 0000:00: resource 11 [mem 0xfec10000-0xfecfffff window]
[    0.317640] pci_bus 0000:00: resource 12 [mem 0xfed00400-0xfed1ffff window]
[    0.317642] pci_bus 0000:00: resource 13 [mem 0xfee10000-0xffafffff window]
[    0.317644] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.317646] pci_bus 0000:01: resource 1 [mem 0xed000000-0xefefffff]
[    0.317648] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.317650] pci_bus 0000:0b: resource 0 [io  0x2000-0x2fff]
[    0.317652] pci_bus 0000:0b: resource 1 [mem 0x80000000-0x801fffff]
[    0.317654] pci_bus 0000:0b: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[    0.317656] pci_bus 0000:0c: resource 0 [io  0x3000-0x3fff]
[    0.317658] pci_bus 0000:0c: resource 1 [mem 0xecf00000-0xecffffff]
[    0.317660] pci_bus 0000:0c: resource 2 [mem 0x80400000-0x805fffff 64bit pref]
[    0.317662] pci_bus 0000:09: resource 0 [io  0x4000-0x4fff]
[    0.317664] pci_bus 0000:09: resource 1 [mem 0xece00000-0xecefffff]
[    0.317666] pci_bus 0000:09: resource 2 [mem 0x80600000-0x807fffff 64bit pref]
[    0.317668] pci_bus 0000:0d: resource 0 [io  0xd000-0xdfff]
[    0.317670] pci_bus 0000:0d: resource 1 [mem 0xecc00000-0xecdfffff]
[    0.317672] pci_bus 0000:0d: resource 2 [mem 0xe0000000-0xe01fffff 64bit pref]
[    0.317674] pci_bus 0000:03: resource 1 [mem 0xecb00000-0xecbfffff]
[    0.317676] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.317678] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.317680] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.317682] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000dffff window]
[    0.317684] pci_bus 0000:03: resource 8 [mem 0x80000000-0xefffffff window]
[    0.317686] pci_bus 0000:03: resource 9 [mem 0xf4007000-0xf4007fff window]
[    0.317688] pci_bus 0000:03: resource 10 [mem 0xf400c000-0xfebfffff window]
[    0.317690] pci_bus 0000:03: resource 11 [mem 0xfec10000-0xfecfffff window]
[    0.317692] pci_bus 0000:03: resource 12 [mem 0xfed00400-0xfed1ffff window]
[    0.317694] pci_bus 0000:03: resource 13 [mem 0xfee10000-0xffafffff window]
[    0.317803] NET: Registered protocol family 2
[    0.318058] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.318237] TCP bind hash table entries: 16384 (order: 7, 917504 bytes)
[    0.318672] TCP: Hash tables configured (established 16384 bind 16384)
[    0.318748] UDP hash table entries: 1024 (order: 5, 131072 bytes)
[    0.318826] UDP-Lite hash table entries: 1024 (order: 5, 131072 bytes)
[    0.318965] NET: Registered protocol family 1
[    0.320842] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.320867] PCI: CLS 64 bytes, default 64
[    0.320955] Unpacking initramfs...
[    0.806886] Freeing initrd memory: 24992K
[    0.806987] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2195fb31bcc, max_idle_ns: 440795317385 ns
[    0.807584] audit: initializing netlink subsys (disabled)
[    0.807625] audit: type=2000 audit(1548739717.804:1): initialized
[    0.808408] workingset: timestamp_bits=40 max_order=19 bucket_order=0
[    0.811374] zbud: loaded
[    0.812995] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.813053] io scheduler noop registered
[    0.813055] io scheduler deadline registered
[    0.813107] io scheduler cfq registered (default)
[    0.814736] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.814747] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.814774] intel_idle: does not run on family 6 model 15
[    0.815204] GHES: HEST is not enabled!
[    0.815312] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.815998] Linux agpgart interface v0.103
[    0.816332] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.816334] AMD IOMMUv2 functionality not available on this system
[    0.816597] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    0.819540] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.819597] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.819796] mousedev: PS/2 mouse device common for all mice
[    0.819856] rtc_cmos 00:05: RTC can wake from S4
[    0.820088] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    0.820191] rtc_cmos 00:05: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.820933] NET: Registered protocol family 10
[    0.821283] mip6: Mobile IPv6
[    0.821286] NET: Registered protocol family 17
[    0.821290] mpls_gso: MPLS GSO support
[    0.821535] microcode: sig=0x6f6, pf=0x20, revision=0xd1
[    0.821611] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    0.821902] registered taskstats version 1
[    0.821934] zswap: loaded using pool lzo/zbud
[    0.822000] ima: No TPM chip found, activating TPM-bypass!
[    0.822003] ima: Allocated hash algorithm: sha256
[    0.822505] rtc_cmos 00:05: setting system clock to 2019-01-29 05:28:38 UTC (1548739718)
[    0.822560] PM: Hibernation image not present or could not be loaded.
[    0.823395] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    0.824781] Freeing unused kernel memory: 1680K
[    0.824784] Write protecting the kernel read-only data: 12288k
[    0.826322] Freeing unused kernel memory: 1780K
[    0.830010] Freeing unused kernel memory: 1184K
[    0.836329] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.857158] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.857283] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.857299] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    0.912316] pps_core: LinuxPPS API ver. 1 registered
[    0.912319] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.912598] PTP clock support registered
[    0.914989] tg3.c:v3.137 (May 11, 2014)
[    0.917111] thermal LNXTHERM:00: registered as thermal_zone0
[    0.917114] ACPI: Thermal Zone [THM] (55 C)
[    0.953258] SCSI subsystem initialized
[    0.953561] ACPI: bus type USB registered
[    0.957435] usbcore: registered new interface driver usbfs
[    0.958019] usbcore: registered new interface driver hub
[    0.958716] tg3 0000:09:00.0 eth0: Tigon3 [partno(BCM5752KFBG) rev 6002] (PCI Express) MAC address 00:18:8b:a6:92:0f
[    0.958719] tg3 0000:09:00.0 eth0: attached PHY is 5752 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[    0.958722] tg3 0000:09:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[    0.958725] tg3 0000:09:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[    0.959528] usbcore: registered new device driver usb
[    0.959567] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    0.963960] sdhci: Secure Digital Host Controller Interface driver
[    0.963963] sdhci: Copyright(c) Pierre Ossman
[    0.970786] sdhci-pci 0000:03:01.1: SDHCI controller found [1180:0822] (rev 19)
[    0.972551] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.973514] uhci_hcd: USB Universal Host Controller Interface driver
[    0.973779] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.973788] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[    0.973799] uhci_hcd 0000:00:1d.0: detected 2 ports
[    0.973939] ehci-pci: EHCI PCI platform driver
[    0.974844] libata version 3.00 loaded.
[    0.977668] uhci_hcd 0000:00:1d.0: irq 20, io base 0x0000bf80
[    0.978541] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[    0.978544] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.978546] usb usb1: Product: UHCI Host Controller
[    0.978548] usb usb1: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    0.978550] usb usb1: SerialNumber: 0000:00:1d.0
[    0.979534] hub 1-0:1.0: USB hub found
[    0.979551] hub 1-0:1.0: 2 ports detected
[    0.980221] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    0.980228] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.980243] ehci-pci 0000:00:1d.7: debug port 1
[    0.985244] mmc0: SDHCI controller on PCI [0000:03:01.1] using DMA
[    0.985818] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    0.985871] ehci-pci 0000:00:1d.7: irq 20, io mem 0xffa80000
[    1.000056] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.000186] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.000189] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.000191] usb usb2: Product: EHCI Host Controller
[    1.000193] usb usb2: Manufacturer: Linux 4.9.0-8-rt-amd64 ehci_hcd
[    1.000194] usb usb2: SerialNumber: 0000:00:1d.7
[    1.001954] hub 2-0:1.0: USB hub found
[    1.001967] hub 2-0:1.0: 8 ports detected
[    1.028274] hub 1-0:1.0: USB hub found
[    1.028306] hub 1-0:1.0: 2 ports detected
[    1.028482] ata_piix 0000:00:1f.2: version 2.13
[    1.028694] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[    1.029903] scsi host0: ata_piix
[    1.030894] scsi host1: ata_piix
[    1.030979] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xbfa0 irq 14
[    1.030981] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xbfa8 irq 15
[    1.031234] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    1.031245] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    1.031254] uhci_hcd 0000:00:1d.1: detected 2 ports
[    1.031598] uhci_hcd 0000:00:1d.1: irq 21, io base 0x0000bf60
[    1.031687] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.031690] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.031692] usb usb3: Product: UHCI Host Controller
[    1.031694] usb usb3: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    1.031696] usb usb3: SerialNumber: 0000:00:1d.1
[    1.031919] hub 3-0:1.0: USB hub found
[    1.031930] hub 3-0:1.0: 2 ports detected
[    1.032337] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    1.032343] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    1.032356] uhci_hcd 0000:00:1d.2: detected 2 ports
[    1.032442] uhci_hcd 0000:00:1d.2: irq 22, io base 0x0000bf40
[    1.032741] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.032744] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.032746] usb usb4: Product: UHCI Host Controller
[    1.032748] usb usb4: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    1.032750] usb usb4: SerialNumber: 0000:00:1d.2
[    1.033108] hub 4-0:1.0: USB hub found
[    1.033124] hub 4-0:1.0: 2 ports detected
[    1.033466] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    1.033475] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    1.033483] uhci_hcd 0000:00:1d.3: detected 2 ports
[    1.033571] uhci_hcd 0000:00:1d.3: irq 23, io base 0x0000bf20
[    1.033739] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.033741] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.033743] usb usb5: Product: UHCI Host Controller
[    1.033745] usb usb5: Manufacturer: Linux 4.9.0-8-rt-amd64 uhci_hcd
[    1.033747] usb usb5: SerialNumber: 0000:00:1d.3
[    1.033944] hub 5-0:1.0: USB hub found
[    1.033955] hub 5-0:1.0: 2 ports detected
[    1.064176] firewire_ohci 0000:03:01.0: added OHCI v1.10 device as card 0, 4 IR + 4 IT contexts, quirks 0x11
[    1.194857] ata1.00: ATA-8: TOSHIBA MK1246GSX, LB212D, max UDMA/100
[    1.194863] ata1.00: 234441648 sectors, multi 8: LBA48 NCQ (depth 0/32)
[    1.197762] ata1.00: configured for UDMA/100
[    1.198255] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MK1246GS 2D   PQ: 0 ANSI: 5
[    1.236480] ata2.00: ATAPI: PBDS DVD+/-RW DS-8W1P, BD1B, max UDMA/33
[    1.280364] ata2.00: configured for UDMA/33
[    1.287477] scsi 1:0:0:0: CD-ROM            PBDS     DVD+-RW DS-8W1P  BD1B PQ: 0 ANSI: 5
[    1.307943] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[    1.308046] sd 0:0:0:0: [sda] Write Protect is off
[    1.308049] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.308081] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.323945] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[    1.323946] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.324166] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    1.372849]  sda: sda1 sda2 < sda5 >
[    1.373426] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.524058] usb 1-1: new full-speed USB device number 2 using uhci_hcd
[    1.596182] firewire_core 0000:03:01.0: created device fw0: GUID 334fc00025392161, S400
[    1.620934] psmouse serio1: synaptics: Touchpad model: 1, fw: 6.2, id: 0xfa0b1, caps: 0xa04713/0x200000/0x0/0x0, board id: 0, fw id: 128333
[    1.659160] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input2
[    1.683221] random: fast init done
[    1.684239] usb 1-1: New USB device found, idVendor=413c, idProduct=a005
[    1.684245] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.686350] hub 1-1:1.0: USB hub found
[    1.688315] hub 1-1:1.0: 4 ports detected
[    1.917831] PM: Starting manual resume from disk
[    1.917836] PM: Hibernation image partition 8:5 present
[    1.917837] PM: Looking for hibernation image.
[    1.918201] PM: Image not found (code -22)
[    1.918204] PM: Hibernation image not present or could not be loaded.
[    1.984161] usb 1-1.2: new full-speed USB device number 3 using uhci_hcd
[    2.109229] usb 1-1.2: New USB device found, idVendor=0b97, idProduct=7761
[    2.109233] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.111295] hub 1-1.2:1.0: USB hub found
[    2.113241] hub 1-1.2:1.0: 3 ports detected
[    2.200059] usb 1-1.4: new full-speed USB device number 4 using uhci_hcd
[    2.263459] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    2.365239] usb 1-1.4: New USB device found, idVendor=413c, idProduct=8103
[    2.365242] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.408059] usb 1-1.2.2: new full-speed USB device number 5 using uhci_hcd
[    2.542255] usb 1-1.2.2: New USB device found, idVendor=0b97, idProduct=7762
[    2.542258] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.542260] usb 1-1.2.2: Product: O2Micro CCID SC Reader
[    2.542262] usb 1-1.2.2: Manufacturer: O2
[    3.777303] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.888584] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    3.888778] systemd[1]: Detected architecture x86-64.
[    3.899199] systemd[1]: Set hostname to <shopbot>.
[    4.418048] random: crng init done
[    4.418052] random: 7 urandom warning(s) missed due to ratelimiting
[    5.116661] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    5.116711] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    5.117596] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.117708] systemd[1]: Listening on fsck to fsckd communication Socket.
[    5.117969] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.118031] systemd[1]: Listening on udev Kernel Socket.
[    5.118127] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.974538] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    6.243562] lp: driver loaded but no devices found
[    6.330172] systemd-journald[210]: Received request to flush runtime journal from PID 1
[    6.420779] ppdev: user-space parallel port driver
[    7.902766] ACPI: Video Device [VID] (multi-head: yes  rom: no  post: no)
[    7.914951] acpi device:2d: registered as cooling_device2
[    7.915172] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:2a/LNXVIDEO:00/input/input3
[    7.917698] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    8.087220] ACPI: AC Adapter [AC] (on-line)
[    8.106427] ACPI: Battery Slot [BAT0] (battery present)
[    8.108586] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input4
[    8.109014] ACPI: Lid Switch [LID]
[    8.109087] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[    8.109091] ACPI: Power Button [PBTN]
[    8.109159] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input6
[    8.109161] ACPI: Sleep Button [SBTN]
[    8.265409] [drm] Initialized
[    8.266261] intel_rng: FWH not detected
[    8.409546] wmi: Mapper loaded
[    8.763639] snd_hda_codec_idt hdaudioC0D0: autoconfig for STAC9200: line_outs=2 (0xe/0x11/0x0/0x0/0x0) type:speaker
[    8.763643] snd_hda_codec_idt hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    8.763646] snd_hda_codec_idt hdaudioC0D0:    hp_outs=1 (0xd/0x0/0x0/0x0/0x0)
[    8.763647] snd_hda_codec_idt hdaudioC0D0:    mono: mono_out=0x0
[    8.763649] snd_hda_codec_idt hdaudioC0D0:    dig-out=0x9/0x0
[    8.763651] snd_hda_codec_idt hdaudioC0D0:    inputs:
[    8.763654] snd_hda_codec_idt hdaudioC0D0:      Mic=0x10
[    9.027559] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    9.027617] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    9.123317] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, in-tree:s
[    9.123320] iwl3945: Copyright(c) 2003-2011 Intel Corporation
[    9.123398] iwl3945 0000:0c:00.0: can't disable ASPM; OS doesn't have ASPM control
[    9.177367] iwl3945 0000:0c:00.0: Tunable channels: 11 802.11bg, 13 802.11a channels
[    9.177370] iwl3945 0000:0c:00.0: Detected Intel Wireless WiFi Link 3945ABG
[    9.187799] leds_ss4200: no LED devices found
[    9.188787] r592: driver successfully loaded
[    9.220242] Bluetooth: Core ver 2.22
[    9.220265] NET: Registered protocol family 31
[    9.220267] Bluetooth: HCI device and connection manager initialized
[    9.220272] Bluetooth: HCI socket layer initialized
[    9.220276] Bluetooth: L2CAP socket layer initialized
[    9.220291] Bluetooth: SCO socket layer initialized
[    9.303114] input: PC Speaker as /devices/platform/pcspkr/input/input9
[    9.504271] ieee80211 phy0: Selected rate control algorithm 'iwl-3945-rs'
[    9.685075] r852: Non dma capable device detected, dma disabled
[    9.685181] r852: driver loaded successfully
[    9.701615] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    9.701675] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    9.717599] nouveau 0000:01:00.0: NVIDIA G71 (049a00a2)
[    9.735807] usbcore: registered new interface driver btusb
[    9.808838] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    9.945175] nouveau 0000:01:00.0: bios: version 05.71.22.16.16
[    9.947320] nouveau 0000:01:00.0: fb: 512 MiB GDDR3
[    9.995875] kvm: disabled by bios
[   10.005316] [TTM] Zone  kernel: Available graphics memory: 1025106 kiB
[   10.005318] [TTM] Initializing pool allocator
[   10.005325] [TTM] Initializing DMA pool allocator
[   10.005362] nouveau 0000:01:00.0: DRM: VRAM: 505 MiB
[   10.005364] nouveau 0000:01:00.0: DRM: GART: 512 MiB
[   10.005370] nouveau 0000:01:00.0: DRM: TMDS table version 1.1
[   10.005372] nouveau 0000:01:00.0: DRM: TMDS table script pointers not stubbed
[   10.005374] nouveau 0000:01:00.0: DRM: DCB version 3.0
[   10.005377] nouveau 0000:01:00.0: DRM: DCB outp 00: 03000323 00000004
[   10.005380] nouveau 0000:01:00.0: DRM: DCB outp 01: 01011300 00000028
[   10.005382] nouveau 0000:01:00.0: DRM: DCB outp 02: 020223f1 0040c080
[   10.005385] nouveau 0000:01:00.0: DRM: DCB outp 03: 08035312 00000000
[   10.005387] nouveau 0000:01:00.0: DRM: DCB outp 04: 04036312 00000000
[   10.005389] nouveau 0000:01:00.0: DRM: DCB conn 00: 0041
[   10.005391] nouveau 0000:01:00.0: DRM: DCB conn 01: 0100
[   10.005393] nouveau 0000:01:00.0: DRM: DCB conn 02: 0310
[   10.005395] nouveau 0000:01:00.0: DRM: DCB conn 03: 0311
[   10.005397] nouveau 0000:01:00.0: DRM: DCB conn 04: 0313
[   10.005399] nouveau 0000:01:00.0: DRM: DCB conn 05: 0254
[   10.005401] nouveau 0000:01:00.0: DRM: DCB conn 06: 0455
[   10.005633] nouveau 0000:01:00.0: DRM: Saving VGA fonts
[   10.026340] kvm: disabled by bios
[   10.074475] nouveau 0000:01:00.0: DRM: unknown connector type 54
[   10.074544] nouveau 0000:01:00.0: DRM: unknown connector type 55
[   10.075919] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   10.075920] [drm] Driver supports precise vblank timestamp query.
[   10.082178] nouveau 0000:01:00.0: DRM: MM: using M2MF for buffer copies
[   10.082191] nouveau 0000:01:00.0: DRM: Calling LVDS script 6:
[   10.082195] nouveau 0000:01:00.0: DRM: 0xC81B: Parsing digital output script table
[   10.345420] dell_wmi: Detected Dell WMI interface version 1
[   10.345507] input: Dell WMI hotkeys as /devices/virtual/input/input10
[   10.360543] nouveau 0000:01:00.0: DRM: Setting dpms mode 3 on TV encoder (output 2)
[   10.368228] iTCO_vendor_support: vendor-support=0
[   10.424138] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   10.424183] iTCO_wdt: Found a ICH7-M or ICH7-U TCO device (Version=2, TCOBASE=0x1060)
[   10.424318] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   10.474523] nouveau 0000:01:00.0: DRM: allocated 1920x1200 fb: 0x9000, bo ffff9037b9a68800
[   10.474617] fbcon: nouveaufb (fb0) is primary device
[   10.497418] nouveau 0000:01:00.0: DRM: Calling LVDS script 2:
[   10.497421] nouveau 0000:01:00.0: DRM: 0xC89F: Parsing digital output script table
[   10.644334] nouveau 0000:01:00.0: DRM: Calling LVDS script 5:
[   10.644337] nouveau 0000:01:00.0: DRM: 0xC80C: Parsing digital output script table
[   10.759752] Console: switching to colour frame buffer device 240x75
[   10.761152] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
[   10.776096] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[   11.009253] intel_powerclamp: No package C-state available
[   11.052505] intel_powerclamp: No package C-state available
[   11.732593] Adding 2093052k swap on /dev/sda5.  Priority:-1 extents:1 across:2093052k FS
[   17.291011] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   17.291014] Bluetooth: BNEP filters: protocol multicast
[   17.291021] Bluetooth: BNEP socket layer initialized
[   18.196301] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.762403] tg3 0000:09:00.0 eth0: Link is up at 100 Mbps, full duplex
[   19.762407] tg3 0000:09:00.0 eth0: Flow control is on for TX and on for RX
[   19.762425] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   20.220346] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   20.427781] iwl3945 0000:0c:00.0: firmware: direct-loading firmware iwlwifi-3945-2.ucode
[   20.427790] iwl3945 0000:0c:00.0: loaded firmware version 15.32.2.9
[   20.509769] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   20.617976] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   21.486521] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   23.866514] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   23.907717] wlan0: authenticate with 14:35:8b:18:f8:f1
[   23.910046] wlan0: send auth to 14:35:8b:18:f8:f1 (try 1/3)
[   23.911900] wlan0: authenticated
[   23.916107] wlan0: associate with 14:35:8b:18:f8:f1 (try 1/3)
[   23.919145] wlan0: RX AssocResp from 14:35:8b:18:f8:f1 (capab=0x1011 status=0 aid=3)
[   23.920870] wlan0: associated
[   24.120541] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   85.488032] NOHZ: local_softirq_pending 80
[  590.833734] CE: hpet increased min_delta_ns to 20115 nsec
[  681.524137] perf: interrupt took too long (2509 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
[ 1073.052102] perf: interrupt took too long (3161 > 3136), lowering kernel.perf_event_max_sample_rate to 63250
[ 1811.501934] perf: interrupt took too long (3953 > 3951), lowering kernel.perf_event_max_sample_rate to 50500
[ 2081.752747] systemd[1]: apt-daily-upgrade.timer: Adding 46min 15.237709s random time.
Info report created by linuxcnc_info:
Last edit: 29 Jan 2019 23:12 by andypugh.
29 Jan 2019 07:10 #125137 by rodw
Out of all that mess, this is the error
So you are referring to a non-existent pin. It may have changed its name with the move to multispindle support that is now in master.
I'd just comment that line out so LInuxCNC will load and open up halshow to review what pins now exist and edit it to agree with the current naming convention. From the Axis menus "Show Machine Configuration"
29 Jan 2019 07:13 #125138 by cmorley
Hmm I don't know the 7i76e very well, but often the boards need field power to them before all the pins show.
Chris M
29 Jan 2019 14:11 #125169 by PCW
Yes, missing pins/parameters suggests that there's no field power
  • yoshimitsuspeed
  • Premium Member
  • Premium Member
30 Jan 2019 02:56 #125244 by yoshimitsuspeed
Replied by yoshimitsuspeed on topic New 7I76E install error when launching linuxcnc
Thanks guys got it all wired up and everything loaded up properly. Having some VFD issues. Going to make a new post about that.
Time to create page: 0.241 seconds
