PCI card
- daxur666
30 Jan 2019 16:14 #125303
by daxur666
PCI card was created by daxur666
Good Day
I had a problem with the parallel port in my computer, the "Status" pins that I was using for the limit switches are not working anymore, so to solve this issue I want to use a PCI card, I've been reading that it is a good option when you want to add I/O for the machine, but what I want is use that as port 1, not as a second port, Can somebody tell me if is possible to use a PCI card and in the Stepconfig use as Port 1?
- Thank you received: 1475
30 Jan 2019 20:23 #125331
Replied by Todd Zuercher on topic PCI card
If you're pc has multiple parallel ports, you can use any of the ports in any order you choose. It doesn't matter how they are connected as long as it's not by usb.
- daxur666
01 Feb 2019 17:41 #125484
by daxur666
Replied by daxur666 on topic PCI card
Thank you for answering, the PCI card worked fine, in my computer the port number for the stepconfig was 0xec00.
In a different subject, what does "net xenable axis.0.amp-enable-out => stepgen.0.enable" do?
- Grotius
- Thank you received: 2349
01 Feb 2019 19:59 - 01 Feb 2019 20:19 #125488
by Grotius
Replied by Grotius on topic PCI card
Net x enable is a name for defining a link
Between axis enable and stepgen enable.
The axis amp is maybe the enable the drive signal (enable stepperdrive or enable servo drive). When this is enabled is says the stepgen may also be enabled or visa versa. Stepgen is stepgenerator. In your case stepgen 0 is i think joint 0.
An other view with the same output is :
But the x-enable is often later on used in your hal file. So when changing to x-test, you will have to change all the rest of
xenable into x-test.
net xenable axis.0.amp-enable-out stepgen.0.enable
Or
net xenable stepgen.0.enable axis.0.amp-enable-out
Or
net x-test axis.0.amp-enable-out stepgen.0.enable
Etc.But the x-enable is often later on used in your hal file. So when changing to x-test, you will have to change all the rest of
Last edit: 01 Feb 2019 20:19 by Grotius.
Time to create page: 0.219 seconds
