Angular axis only reaches half of maximum speed
- l2-max
31 Jan 2019 08:49 #125378
by l2-max
Stepper only accelerates up to the half of max speed. was created by l2-max
Hi All. Yesterday, I experienced with strange behavior of chinese DM542 stepper driver. This driver I have recently bought so do not know exactly how should it work.
The issue: Motor connected to the driver increases its speed up to approximately half of my maximum pulse rate then it proportionally decelerates to almost full stop at maximum pulse rate then when the joint decelerates behavior exactly the same but reversed. LinuxCNC shows speed as it should be.
My setup: LinuxCNC Maximum pulse rate 27.2kHz, Driver steps per revolution 1600, Driver voltage 24V, Driver current ~3.3A, Motor coil inductance 2.5mH
I tried to swap this driver with one from another axis (also chinese but different noname brand) and it works as expected, I also tried to swap parport pins to be sure there is no issue in joints configs and it does not help.
Anyone experienced such issue? I suspect that driver is "a sick driver"
- pl7i92
- Thank you received: 358
31 Jan 2019 14:45 #125387
by pl7i92
Replied by pl7i92 on topic Stepper only accelerates up to the half of max speed.
Seams like you did miss the stepgen acceleration
Doubel the latency
Why did you use so mutch Multiplication
You shoudt try to get it down to 400 by Hardware
or not more then 800
Calculation
at BallbearingSpindle is 200Steps Motor Half stepping 400steps /revelution Will lead to a 1,25 gear Meaning timingbelt 20Z/25Z gives you accuraccy of 0,01mm per step lots of Force and Best speed
adding Multiplicator 4 so 200*4 = 800steps /rev will give you a direct drive
But Not a good acceleration as the Force will kill your speed
Doubel the latency
Calculation
- l2-max
31 Jan 2019 15:04 - 31 Jan 2019 15:12 #125394
by l2-max
Replied by l2-max on topic Stepper only accelerates up to the half of max speed.
Not sure about acceleration. I increased it but that did not help. I recorded video for better understanding of the issue. On video I start rapid move at 61Kdegre/min. Then was reducing speed down to 31Kdegree/min where motor rotation is stable. It really looks like the driver "eats" steps.
P.S. 1/8 was my preferred settings where I do not see resonance on linear axis, now, I just try to figure out where is the problem. The driver must work up to 25600Kpulse per minute
P.S.P.S. Right now I am connecting the driver to one of linear axis, will see how it goes
Last edit: 31 Jan 2019 15:12 by l2-max.
- l2-max
31 Jan 2019 15:23 - 31 Jan 2019 15:26 #125396
by l2-max
Okay, after connecting the driver to X linear axis everything works as expected. So, driver is OK. It is configuration issue. I will investigate my HAL .
Thanks for reply
Thanks for reply
Last edit: 31 Jan 2019 15:26 by l2-max.
- Thank you received: 1472
31 Jan 2019 15:51 - 31 Jan 2019 15:54 #125399
Replied by Todd Zuercher on topic Stepper only accelerates up to the half of max speed.
It sounds/looks like your exceeding your driver's maximum step rate, then it starts to only see half of the steps sent to it.
(double check your drive's minimum step spacing in it's documentation, and set it as such plus some safety margin.)
Last edit: 31 Jan 2019 15:54 by Todd Zuercher.
- l2-max
31 Jan 2019 16:08 #125401
by l2-max
Replied by l2-max on topic Angular axis only reaches half of maximum speed
No, no ... I configured all my joints XYYZA to have exactly the same maximum pulse rate 27200Hz in my case. All joints have exactly the same timings in hal. Looks like ANGULAR axis does not want to move at that rate. If I rewire A axis' driver to X axis or remap pins in HAL and jog that linear axis then motor on A axis turns properly but if I try to jog angular axis it only reaches half of that speed then decelerates.
It looks like there is signed overflow in LinuxCNC code
- l2-max
31 Jan 2019 16:23 #125402
by l2-max
Looks like I have found culprit, need some time to check that out an then I will reply
- l2-max
31 Jan 2019 17:13 #125413
by l2-max
Solved, by reading manual!!!
Namely this
1.6. Using DoubleStep
I have added reset string after write addf parport.1.reset base-thread and A axis, connected to my second parport (thatI did not tell you at the begging) works as expected.
Thanks to all
Namely this
Thanks to all
31 Jan 2019 17:26 #125415
Replied by Todd Zuercher on topic Angular axis only reaches half of maximum speed
Good to hear you found the problem.
Time to create page: 0.087 seconds
