Connecting 7i76E with VFD
04 Feb 2019 05:29 #125633 by tjones
Connecting 7i76E with VFD was created by tjones
Hello,
It looks like the 7i76E board has a rs-422 connection and my huanyang VFD has a rs-485 connection. Is there a converter to make this work? I would like to try and avoid using a USB to rs-485 as my computer doesn't sit that close to the VFD.
-Thanks
04 Feb 2019 07:57 #125645 by rodw
Replied by rodw on topic Connecting 7i76E with VFD
I have yet to try this but this link has the links to docs and the bit file you need. I'm not sure if your VFD has a 4 wire interface...
forum.linuxcnc.org/27-driver-boards/3328...6e-with-uart?start=0
13 Feb 2019 14:31 #126346 by andypugh
Replied by andypugh on topic Connecting 7i76E with VFD
There is rather more to using the Mesa card serial connection to control the VFD than just the physical wiring. You would also need a driver as the Mesa UART does not appear as a serial defive in /dev but only exists in the LinuxCNC HAL.
Time to create page: 0.209 seconds
