About unexpected realtime delay ...
06 Feb 2019 19:55 #125856 by l2-max
I do not use stepconfig, i edited hal file manualy
06 Feb 2019 20:19 #125858 by Todd Zuercher
Replied by Todd Zuercher on topic Solved. Unexpected realtime delay with two parports
Then I'm confused by your question "why LinuxCNC reads second parport if no pins are connected for reading?"
The answer is it doesn't, it only reads them if you tell it to with the "addf addf parport.N.read base−thread" or "addf parport.read−all base−thread"
06 Feb 2019 20:34 #125862 by l2-max
No confuse. My logic was - despite function is loaded, if no pins are configured for read, then there is nothing to read. ;)
P.S. I understand that linuxcnc is implemented how it is implemented. No complains.
06 Feb 2019 20:53 #125869 by Todd Zuercher
Hal files are simple scrips they don't check if something is used or not, they just do what they are told, and halpins such as the parallel port input pins can be read and used by other things independent of the hal file.
06 Feb 2019 20:59 #125870 by l2-max
By what things they can be read and used?
06 Feb 2019 21:20 #125875 by Todd Zuercher
A custom M-code could use them without a hal file reference.
A python userspace component can look up the value of a hal pin.
The following user(s) said Thank You: l2-max
06 Feb 2019 21:31 - 06 Feb 2019 21:33 #125878 by l2-max
Okay. Will check that. You gave me the point.
Last edit: 06 Feb 2019 21:33 by l2-max.
07 Feb 2019 17:10 #125932 by l2-max
Moved parport.X.read functions to servo thread and got stable 31000nS base period for two parports generating pulses for 5 joints at 32kHz.
15 Oct 2019 14:32 #147931 by jonch919
Replied by jonch919 on topic About unexpected realtime delay ...
Hi Guys,
After tweaking LinuxCNC on my ASROCK-J3455-ITX board, I got really good latency not exceeding 5000nS. However, the minimum BASE_PERIOD I can set without getting unexpected realtime dalay is 39500nS. That gives me confident 25.3kHz pulse rate. If I go less than 39500nS then as close I approach ~32000nS as sooner after starting LinuxCNC I get the error. I also noticed, that I needed to increase BASE_PERIOD after I added second parallel port. With one parallel port BASE_PERIOD was set to 37500nS and no error was seen.
My question is "Is that CPU speed limits BASE_PERIOD in my case?"
CPU J3455 1.5GHz.
Maksym
I have the same motherboard as you and I'm trying to solve some latency issues.
Would you mind posting your bios settings ans what tweaks you have made to achieve such low latency numbers?
I'm at about 30-50us normally, with spikes up to over 100-120us on latest Debian 9 and RT kernel..
Have you been successful in disabling SMI, with Smictrl or some other method? It doesn't work at all for me.
15 Oct 2019 17:41 #147939 by l2-max
Replied by l2-max on topic About unexpected realtime delay ...
I do not think my tweaks will help you much as you and I running different Debian releases.
Initially, latency test on this mother board shown 16uS with official RTAI 2.7.14 ISO image. Then I switched to 2.8 master branch. Latency remain exactly the same as with official release despite kernel changed to preempt-rt. If you cannot reach such latency with clean 2.7.14 RTAI on the motherboard then I am not sure my BIOS setup will help you much.
Sorry, I do not have LinuxCNC machine by hand thus, what I recall, I disabled "INTEL speed step" (-3uS) to run processor at constant speed and may be, not sure disabled virtualization (not sure it had some impact on latency). I also isolated CPU on 2 cores only (that tweak helped a lot -8uS) and latency dropped down to 5uS.
That is it, from what I remember had noticeable impact on latency. Try booting from 2.7.14 RTAI flash drive and run latency test to see if it will be different from what you have now.
The following user(s) said Thank You: jonch919
Time to create page: 0.103 seconds
