Need help for school Project with mesa 7i96
09 Feb 2019 15:34 #126060 by Stubenrocker3
Need help for school Project with mesa 7i96 was created by Stubenrocker3
Hello guys!
I'm a german student and for a school project, called "P-Seminar" our goal was to build a milling machine. To controll it I want to use Linuxcnc and the mesa 7i96 board. I managed to create a configuration file that opens without any errors or problems, but if i want to move the axis my motor still won't move. I also tried messuring the signal and if i move the axis in a negative direction I get a 4.8V signal on Dir+ but no Step+ signal. It would be great if you helped me, thank you in advance!
These are my motors and drivers:
www.amazon.de/ACT-Motor-23HS8840D8P1-C-3...mation/dp/B07C2XPV85
www.amazon.de/ACT-Motor-18-50VDC-3D-Prin...trumen/dp/B01FFSFN8U
Here are my conf files(I'm using Linuxcnc 2.8):
File Name: testy.ini
File Size:4 KB
File Name: cnc.hal
File Size:10 KB
  • Moderator
  • Moderator
09 Feb 2019 19:25 #126070 by tommylight
Replied by tommylight on topic Need help for school Project with mesa 7i96
In the INI file you have:
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
set those to at least 15000 for all axis, afterwards you can lower those values gradually if you need to.
The following user(s) said Thank You: Stubenrocker3
10 Feb 2019 09:03 - 10 Feb 2019 09:03 #126133 by Stubenrocker3
Replied by Stubenrocker3 on topic Need help for school Project with mesa 7i96
Thank you!
Now as I try moving the axis still nothing moves and i get following error.
Last edit: 10 Feb 2019 09:03 by Stubenrocker3.
  • Moderator
  • Moderator
10 Feb 2019 12:16 - 10 Feb 2019 12:21 #126137 by tommylight
There is something wrong with your config as a servo period of 1.4something milion is not right, and that shows that your computer has a very high latency that looks to be unusable.
Can you post your config files here so we can try to figure out what is going on.
Sorry just found them above.
The servo period should be 1000000 ( one million ), the display section for max_velocity should be something more than 1mm per second that is 60mm per minute and
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
They should be set to what your machine can do, these are way to low for anything usable.
Those are values in mm per second.
Last edit: 10 Feb 2019 12:21 by tommylight.
10 Feb 2019 14:22 #126148 by PCW
Also, what computer hardware do you have?
PCs with Intel Ethernet chips need specific setup tweaks to get decent latency
10 Feb 2019 16:06 #126152 by Stubenrocker3
lspci shows:
00:19.0 Ethernet controller: Intel Corporation 82567LM Gigabit Network Connection (rev 03)
Do you need a latency test, too?
10 Feb 2019 16:30 #126155 by Stubenrocker3
Here is my new conf
File Name: testy_2019-02-10.ini
File Size:4 KB
and I get a new error. It seems like he didn't like the 1000000 servo period
By the way thanks for your help, you are really saving me.
10 Feb 2019 16:33 #126157 by PCW
A latency test would help determine your rough system latency,
but one thing that needs to be addressed is your Ethernet settings
The Intel Ethernet driver defaults to waiting in its interrupt service routine
for additional RX packets whenever it receives a Ethernet packet. This helps
thoughput for normal Ethernet use, since it eliminates the interrupt overhead
when multiple packets are received in a burst but its terrible for latency
To fix this you set a driver parameter called rx-usecs to 0. This requires the "ethtool" utility:
sudo ethtool -C eth0 rx-usecs 0
This will only set the parameter temporarily, to set it at system startup, follow the directions in the hm2_eth manual page
Note that your Ethernet port may not be named 'eth0' so change the
name in the command/ scripts to match the name of the ethernet device connected to the 7I96
The following user(s) said Thank You: tommylight, Stubenrocker3
11 Feb 2019 17:56 - 11 Feb 2019 18:13 #126208 by Stubenrocker3
Okay I did as I was told. Now linuxcnc doesn't complain about the 1000000 servo period. The problem is my motor still isn't turning :(
Could it be that there is something wrong with my cabeling or is there still a major error in my conf? Furthermore do I need to configure the driversettings by flipping the switches? (all 8 are on off right now)
Edit: I messured the Step+ signal. Now I get something like 0.28V when I move the axis.
My cableing looks like this:
Last edit: 11 Feb 2019 18:13 by Stubenrocker3.
11 Feb 2019 18:29 #126209 by PCW
Wiring looks OK
Can you post your current hal/ini files?
Time to create page: 0.201 seconds
