Need help for school Project with mesa 7i96
11 Feb 2019 18:37 #126211 by Stubenrocker3
Replied by Stubenrocker3 on topic Need help for school Project with mesa 7i96
Sure! Here you go.
File Name: testy_2019-02-11.ini
File Size:4 KB
File Name: cnc_2019-02-11.hal
File Size:10 KB
11 Feb 2019 18:51 #126213 by PCW
The hal/ini files are definitely broken, at the very minimum they seem like they were created with a quite old version of pncconf, worse, they have no step scaling settings...
If you want to patch this, I would suggest reading the LinuxCNC documents on ini file settings:
linuxcnc.org/docs/html/config/ini-config.html
Another option is trying JTs 7I96 configuration utility:
github.com/jethornton/7i96
The following user(s) said Thank You: Stubenrocker3
Time to create page: 0.181 seconds
