Testing of 7i76e stepper outputs
- AuricGoldfinger
10 Feb 2019 14:13 #126146
by AuricGoldfinger
Testing of 7i76e stepper outputs was created by AuricGoldfinger
Hi over there,
just converted my old deckel FP3L mill to linuxcnc.
The general purpose IOs of the 7i76e work (I can switch on my drives supply, coolant pump and spindle from Linuxcnc), but the stepper outputs are dead.
Aready checked with an external scope for pulses. nothing.
Used the wizards to generate the HAL file. Linuxcnc was fresh installed with all updatesand realtime kernel last month.
Is there an easy way, program or sample HAL file to just test the stepperoutputs?
I have not connected the endstop switches yet. (missing some terminal block connector bar hardware parts...) Are the outputs maybe suppresed due to that?
Any ideas?
best regards
Maik
Any ideas?
best regards
Maik
- Thank you received: 5321
10 Feb 2019 14:19 #126147
Replied by PCW on topic Testing of 7i76e stepper outputs
You can read back the GPIO pins that match the direction outputs
or just use a voltmeter on the direction pins and check that they change
when you jog in either direction
(the step pulses will be too short to catch with halshow or halscope)
No step outputs could also be a hal/ini file issue
- Thank you received: 4652
13 Feb 2019 22:56 #126411
Replied by andypugh on topic Testing of 7i76e stepper outputs
Can you post the HAL and INI files?
- pl7i92
- Thank you received: 358
16 Feb 2019 07:26 #126599
by pl7i92
Replied by pl7i92 on topic Testing of 7i76e stepper outputs
i did setup a Video on How to Messure a Parport
- Thank you received: 4144
16 Feb 2019 09:27 #126602
Replied by rodw on topic Testing of 7i76e stepper outputs
Did you happen to connect wires to the stepper controller enable terminals? If so remove the connection as its a dis-enable signal.
