Doh!...looks like I shot myself in the the realtime foot...
- pferrick
- Thank you received: 3
12 Feb 2019 01:40 #126240
by pferrick
Doh!...looks like I shot myself in the the realtime foot... was created by pferrick
Hi all-
In goofing around with pygtk, Glade and popup windows that refuse to go away, I very regrettably deleted a file which is important to the health and well-being of 2.7, namely:
Error: could not load module /usr/realtime-3.4-9-rtai-686-pae/modules/rtai_hal.ko: No such file or directory
Please tell me that there's a fix that does not require a full re-install!!
Thanks,
Patrick
Thanks,
Patrick
- pl7i92
- Thank you received: 358
12 Feb 2019 07:47 #126250
by pl7i92
Replied by pl7i92 on topic Doh!...looks like I shot myself in the the realtime foot...
Best is on this error
Go to bios
SAVE and exit and that is the Trick
it simply stuck in the realtime loader
Go to bios
- pferrick
12 Feb 2019 11:02 #126259
by pferrick
Replied by pferrick on topic Doh!...looks like I shot myself in the the realtime foot...
Not sure I understand what you mean. Are you saying that some change has (or needs to ) happen to the BIOS??
If you could be just a bit more specific I would really appreciate it! Thanks.
- Thank you received: 2175
12 Feb 2019 13:30 #126267
Replied by cmorley on topic Doh!...looks like I shot myself in the the realtime foot...
can you post more of the error?
Unless you were using a sudo command you can't delete a file in there.
Chris M
Chris M
- pferrick
12 Feb 2019 15:17 - 12 Feb 2019 15:18 #126271
by pferrick
Well, I hate to admit it but sudo WAS involved. Basically I was experimenting with having windows appear via pygtk, and for a while some could not be gotten rid of, because I hadn't yet connected the destroy signal to the right place. And of course I designed them without a iconify/fullscreen/close bar across the top.
In the process of dealing with these windows, linuxcnc didn't start up as usual and it looked to me (at the time, anyway) that there was a file related to the realtime part of linuxcnc that was hanging around that shouldn't be. That's essentially what led me to mistakenly delete the file in question. Super dumb move, I know.
Anyhow, here's the whole error output:
and here's the contents of linuxcnc_debug.txt:
and finally, here's the tail end of dmesg:
(everything before this is I believe unrelated to this particular problem...)
Well, I've got my asbestos underwear on so flame away!
Many thanks,
Patrick
Starting LinuxCNC...
Realtime system did not load
Running HAL shutdown script
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: line 542: 3630 Segmentation fault $HALCMD -f $SHUTDOWN
/usr/bin/linuxcnc: line 542: 3636 Segmentation fault $HALCMD stop
/usr/bin/linuxcnc: line 542: 3637 Segmentation fault $HALCMD unload all
Error: Module hal_lib is not currently loaded
Error: Module rtapi is not currently loaded
Error: Module rtai_math is not currently loaded
Error: Module rtai_sched is not currently loaded
Error: Module rtai_hal is not currently loaded
LinuxCNC terminated with an error. You can find more information in the log:
/home/pferrick/linuxcnc_debug.txt
and
/home/pferrick/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminaland here's the contents of linuxcnc_debug.txt:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/pferrick/linuxcnc/configs/PKF/./my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=3603
Removing NML shared memory segmentsand finally, here's the tail end of dmesg:
[ 74.651549] halcmd[3630]: segfault at 8 ip b77aa9bd sp bfbfbf90 error 6 in liblinuxcnchal.so.0[b77a6000+9000]
[ 74.717476] halcmd[3636]: segfault at 8 ip b77459bd sp bfd930d0 error 6 in liblinuxcnchal.so.0[b7741000+9000]
[ 74.723557] halcmd[3637]: segfault at 8 ip b76dd9bd sp bf9b54d0 error 6 in liblinuxcnchal.so.0[b76d9000+9000]
[ 74.730580] halcmd[3640]: segfault at 8 ip b77719bd sp bfb2c8d0 error 6 in liblinuxcnchal.so.0[b776d000+9000]
[ 74.935867] halcmd[3644]: segfault at 8 ip b779f9bd sp bfa7c0e0 error 6 in liblinuxcnchal.so.0[b779b000+9000]
[ 75.141280] halcmd[3648]: segfault at 8 ip b77259bd sp bfc8ade0 error 6 in liblinuxcnchal.so.0[b7721000+9000]
[ 75.346569] halcmd[3652]: segfault at 8 ip b76fc9bd sp bf94e160 error 6 in liblinuxcnchal.so.0[b76f8000+9000]
[ 75.551936] halcmd[3656]: segfault at 8 ip b76f29bd sp bfaa5640 error 6 in liblinuxcnchal.so.0[b76ee000+9000]
[ 75.757299] halcmd[3660]: segfault at 8 ip b77889bd sp bffb4c20 error 6 in liblinuxcnchal.so.0[b7784000+9000]
[ 75.962538] halcmd[3664]: segfault at 8 ip b76cc9bd sp bfce91d0 error 6 in liblinuxcnchal.so.0[b76c8000+9000](everything before this is I believe unrelated to this particular problem...)
Many thanks,
Patrick
Last edit: 12 Feb 2019 15:18 by pferrick.
- Thank you received: 1472
12 Feb 2019 15:39 - 12 Feb 2019 15:43 #126273
Replied by Todd Zuercher on topic Doh!...looks like I shot myself in the the realtime foot...
You might try this and see if it fixes it.
Open Synaptic, search for "rtai", then mark every thing in that search which was already installed for re-installation, apply, reboot and see if it works again.
Last edit: 12 Feb 2019 15:43 by Todd Zuercher.
- pferrick
12 Feb 2019 15:41 #126274
by pferrick
I'll try that. Thanks, Todd.
Patrick
Patrick
- pferrick
12 Feb 2019 15:52 #126276
by pferrick
It worked! Todd gets the gold star today.
Y'know, it's been said many times on this forum but I'll say it again: if ANY of you guru-types are ever passing through central NY (ie. the Syracuse area) you should really drop me a line. I would really enjoy heading out for a cold one and talking cnc, and you've certainly earned it! As a matter of fact, now I'm wondering what (if any) linuxcnc gatherings there might be in the works...now THAT would be a lot of fun.
Thanks again.
Patrick
Thanks again.
Patrick
Time to create page: 0.107 seconds
