Axis, joints and soft limits confusion.
01 Mar 2019 12:50 #127405
Which answer was the solution?
Replied by andypugh on topic Axis, joints and soft limits confusion.
You are RIGHT!
This was the problem!
You saved my day!
Thanks!
- pl7i92
- Thank you received: 358
01 Mar 2019 13:23 #127417
by pl7i92
Replied by pl7i92 on topic Axis, joints and soft limits confusion.
i woudt also like to know what did your day
- vmihalca
- Thank you received: 22
01 Mar 2019 13:55 #127423
by vmihalca
Replied by vmihalca on topic Axis, joints and soft limits confusion.
It was a soft limits problem, the bold values are what I'm using now, the other ones are what I was using.
MIN_LIMIT = -360 ; -365.0
MAX_LIMIT = 0.001 ; -5.0
HOME_OFFSET = 5 ; 0.000000
Thank you all for supporting this forum.
- joekline9
- Thank you received: 9
01 Mar 2019 16:13 #127435
by joekline9
Replied by joekline9 on topic Axis, joints and soft limits confusion.
After homing try insert tool 1, then M6 T1 G43 then touch off tool 1 to top of part.
The following user(s) said Thank You: vmihalca
Time to create page: 0.570 seconds
