QtVCP
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Mar 2019 06:46 - 01 Mar 2019 07:34 #127389 by phillc54
QtVCP was created by phillc54
I am finding some strange behaviour in the file dialog in both open and save mode.
If I try to enter the file name I get the following error:
In the terminal:
Warning: Spoiler!
In a popup dialog:
Warning: Spoiler!
Am I missing something in my processed_key_event__
Cheers, Phill.
Edit 1:
OK, if you type the first character and it matches the first character of an existing file/files then a popup appears with the file/files in it.
The next keypress give the error as does the key release.
Edit 2:
I think it is the way I set up my processed_key_event__ to try to stop the plethora of error messages from various widgets...
Last edit: 01 Mar 2019 07:34 by phillc54.
09 Mar 2019 11:31 #128153 by pl7i92
Replied by pl7i92 on topic QtVCP
can you tell us please what system and version you are on
Thank you
  • phillc54
  • Platinum Member
  • Platinum Member
12 Mar 2019 02:20 #128410 by phillc54
Replied by phillc54 on topic QtVCP
Sorry for the lack of response, I have been away.
I should also have posted earlier that I have solved the issues I was having by using a variation of the processed_key_event__ function used in the qtaxis sample screen.
Cheers, Phill
12 Mar 2019 11:56 #128422 by pl7i92
can you specifi the problem please you are running into
and the solution you made in a Separate Thread
that wouodt prevent others to run into
Time to create page: 0.080 seconds
