Incremental g10 possible?
03 Mar 2019 12:40 #127596 by pl7i92
Replied by pl7i92 on topic Incremental g10 possible?
@MaHa
i made /Uploaded a Video that Adsvices this Issue
Usinf G-code G10 to offset the Tool
Multiple pathes with one tool diferent Parameters
The following user(s) said Thank You: Leon82
05 Mar 2019 16:35 #127798 by andypugh
Replied by andypugh on topic Incremental g10 possible?
If you need this a lot you could re-map G10.1 to be an incremental G10.
Or maybe G10.2 to match the (incremental) G43.2
This might be a reasonable feature request.
05 Mar 2019 17:28 #127808 by Leon82
Replied by Leon82 on topic Incremental g10 possible?
Ok, I'll read up on those.
It's not necessarily for in program use but an mdi button in a vcp as a +input button.
This I pulled.from the UI file. The write button sets the value from the offset label and writes to the tool in spindle.
This it in qtpyvcp
<string>G10L11P#&lt;toolInSpindle&gt;R#&lt;toolOffsetLabel&gt;</string>
So I want to make a separate button that would add incrementally to the tool. So an offset of .001 in the lable, then hit the mdi button to write it to the tool in the spindle.
05 Mar 2019 18:30 #127811 by Todd Zuercher
Replied by Todd Zuercher on topic Incremental g10 possible?
That is how I use my incremental G10 moves. I have a series of buttons on a VCP for incrementally moving the coordinate system to make it easier for the machine operators to center the carvings done on a wood router in the factory.
05 Mar 2019 19:23 - 05 Mar 2019 22:39 #127813 by MaHa
Replied by MaHa on topic Incremental g10 possible?
Last edit: 05 Mar 2019 22:39 by MaHa.
05 Mar 2019 20:57 - 05 Mar 2019 20:57 #127821 by Leon82
Thanks, this is what my goal is. Did you mean to attach a file?
Last edit: 05 Mar 2019 20:57 by Leon82.
05 Mar 2019 21:39 - 05 Mar 2019 21:39 #127831 by Todd Zuercher
I didn't actually intend to. But now that you mention it. A lot of my configs I've posted here and there on the forum have it included. Here is one example.
File Name: Digital_1.zip
File Size:40 KB
The GladeVCP file has a series of buttons that can jog the offsets for the XYZ and W axis a chosen increment in the G54 coordinate systems.
Last edit: 05 Mar 2019 21:39 by Todd Zuercher.
06 Mar 2019 01:14 #127844 by Leon82
File Size:40 KB
Thanks,
I see what was done and have tried it. I get so me errors but typing the code into mdi works. So I'll have to investigate some more
Time to create page: 0.090 seconds
