LinuxCNC Uspace
- pl7i92
- Thank you received: 358
01 Mar 2019 13:28 #127418
by pl7i92
LinuxCNC Uspace was created by pl7i92
As Pcw answers here
I do like to know if i can start a Linuxcnc Mashine Coonfig bevor Powering the Mashine itself
Im in Education so it is NOT best to power the mashine bevor the PC
and the Mesa Cards need to be powerd bevor the Mashine Config starts otherwise im getting a pin not present error
So maxbe the Config line reading the Bitfile or somthing like the pin file first
- Thank you received: 5321
01 Mar 2019 15:57 #127433
Replied by PCW on topic LinuxCNC Uspace
If you want to avoid the startup error you could create a script
(or edit the LinuxCNC script) to pause LinuxCNC startup
and print a message like "Waiting for machine power"
until the I/O card is accessible
(you could ping the card to determine if its accessible)
- pl7i92
04 Mar 2019 11:25 #127680
by pl7i92
Replied by pl7i92 on topic LinuxCNC Uspace
is there a Example on How to do this somewehere
@pcw
@pcw
