Keeping track of where the cnc is
- DanielCNC
- Topic Author
7 years 7 months ago #127619
by DanielCNC
Keeping track of where the cnc is was created by DanielCNC
I would linke to keep track of where my cnc is. the absolute optimum would be one or more funktions of time to position. i need it to have corrosponding Values for a sensor (its a distance sensor for welding, able to samle at 50 100 and 200 hz).
I didn´t found a lot about similar aprotches online. probably the closest on is
with the only differenc that i dont want to accually stop for the mesurements i´d like to do the mesurements while the cnc is moving.
also an importent point is i can´t controll the sonsor from the computer i´m running linux cnc on, but i found plenty of information on remote accses so i´m planing to run my from a second pc, the one im controlling the sensor from.
If any of you could point out a site where i can read about such an proach or has any idea how to realise it that would be realy nice. (im also happy with evey different solution the solves the problem, or aproaches that are close to mine)
thanks for your help in advance
Daniel
Daniel
7 years 7 months ago #127647
Replied by tommylight on topic Keeping track of where the cnc is
I think there is a web interface for Linuxcnc that just updates the position.
You can also use VNC and have full control from another computer but it is laggy (slow).
What type of sensor does require having it's own PC?
There are plenty of ways to solve a problem, but we do need more info.
- pl7i92
- Thank you received: 358
7 years 7 months ago #127663
by pl7i92
Replied by pl7i92 on topic Keeping track of where the cnc is
if you only need the numbers
you can also use a MPG component
like xhc-hb04 this gives you numbers on servotread 1ms
The following user(s) said Thank You: DanielCNC
- DanielCNC
- Topic Author
7 years 7 months ago #127677
by DanielCNC
Replied by DanielCNC on topic Keeping track of where the cnc is
Tanks a lot
i think that will be fine at least for the beginning its more then enought.
if you could give me a clue where i could find a good overview about this topic it ywould be great. (i had to google the hole stuff to understand what you are talking about)
Thanks a lot
Daniel
Thanks a lot
Daniel
- pl7i92
7 years 7 months ago #127678
by pl7i92
you shoudt start at a running config and use this pins of halui in first hand
linuxcnc.org/docs/html/man/man1/halui.1.html
then keep inside here
for the xhc
and as you asked for python
here
linuxcnc.org/docs/2.6/html/common/python-interface.html
for the xhc
here
Time to create page: 0.049 seconds
