probe debounce lines crashing linuxcnc start with probe tab installed
7 years 7 months ago #127736 by tony978
I've installed installed askjerrys probe tab and the probe debounce line is crashing startup. I need to have a debounce script other wise i get probe tripped when jogging . can someone let me know if it a simple syntax error .
File Name: custom_postgui.hal
File Size:4.26 KB
7 years 7 months ago #127760 by pl7i92
the debounce runs on servo-tread
not base thread
so you get the error from there
7 years 7 months ago #127784 by andypugh
LinuxCNC doesn't "crash" in this situation. It finds that it is unable to proceed and tells you why.
The HAL file you attached seems to rely heavily on existing signals and a GladeVCP panel. Do you have that panel loaded?
When the error dialog box appears, press the "select all" button then copy and paste it into a message here. We will explain how to interpret what that tells you, and where the problem lies.
7 years 7 months ago - 7 years 7 months ago #127835 by tony978
Andypugh your right is not a crash , error on start is as followed .
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.14 Machine configuration directory is '/home/tony/linuxcnc/configs/my-mill ' Machine configuration file is 'my-mill.ini' INIFILE=/home/tony/linuxcnc/configs/my-mill /my-mill.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./my-mill.hal Found file(REL): ./custom.hal Starting TASK program: milltask Starting DISPLAY program: axis Shutting down and cleaning up LinuxCNC... gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py Xlib.protocol.request.QueryExtension Xlib.protocol.request.QueryExtension Killing task linuxcncsvr, PID=3677 Killing task milltask, PID=3729 task: 164 cycles, min=0.000014, max=0.022102, avg=0.008962, 0 latency excursions (> 10x expected cycle time of 0.010000s) Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: dirname: extra operand `/my-mill.ini' Try `dirname --help' for more information. HAL: ERROR: function 'debounce.0' not found custom_postgui.hal:71: addf failed /usr/bin/gladevcp:295: GtkWarning: GdkWindow 0x3e00003 unexpectedly destroyed gtk.main() **** GLADE VCP ERROR: X Protocol Error: 3 3677 PID TTY STAT TIME COMMAND 3729 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable) [ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 00000000d7ee0000 (usable) [ 0.000000] BIOS-e820: 00000000d7ee0000 - 00000000d7ee3000 (ACPI NVS) [ 0.000000] BIOS-e820: 00000000d7ee3000 - 00000000d7ef0000 (ACPI data) [ 0.000000] BIOS-e820: 00000000d7ef0000 - 00000000d7f00000 (reserved) [ 0.000000] BIOS-e820: 00000000e8000000 - 00000000ec000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 0000000228000000 (usable) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.4 present. [ 0.000000] DMI: Gigabyte Technology Co., Ltd. EP45-DS3L/EP45-DS3L, BIOS F8 08/18/2008 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0xd7ee0 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CCFFF write-protect [ 0.000000] CD000-EFFFF uncachable [ 0.000000] F0000-FFFFF write-through [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F00000000 write-back [ 0.000000] 1 base 0E0000000 mask FE0000000 uncachable [ 0.000000] 2 base 0D8000000 mask FF8000000 uncachable [ 0.000000] 3 base 100000000 mask F00000000 write-back [ 0.000000] 4 base 200000000 mask FC0000000 write-back [ 0.000000] 5 base 230000000 mask FF0000000 uncachable [ 0.000000] 6 base 228000000 mask FF8000000 uncachable [ 0.000000] 7 base 0D7F00000 mask FFFF00000 uncachable [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000d7f00000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] found SMP MP-table at [c00f56f0] f56f0 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 36528000 - 3728c000 [ 0.000000] ACPI: RSDP 000f70e0 00014 (v00 GBT ) [ 0.000000] ACPI: RSDT d7ee3040 00038 (v01 GBT GBTUACPI 42302E31 GBTU 01010101) [ 0.000000] ACPI: FACP d7ee30c0 00074 (v01 GBT GBTUACPI 42302E31 GBTU 01010101) [ 0.000000] ACPI: DSDT d7ee3180 04B8A (v01 GBT GBTUACPI 00001000 MSFT 0100000C) [ 0.000000] ACPI: FACS d7ee0000 00040 [ 0.000000] ACPI: HPET d7ee7e80 00038 (v01 GBT GBTUACPI 42302E31 GBTU 00000098) [ 0.000000] ACPI: MCFG d7ee7f00 0003C (v01 GBT GBTUACPI 42302E31 GBTU 01010101) [ 0.000000] ACPI: APIC d7ee7d80 00084 (v01 GBT GBTUACPI 42302E31 GBTU 01010101) [ 0.000000] ACPI: SSDT d7ee85a0 003AB (v01 PmRef CpuPm 00003000 INTL 20040311) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 2566MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x000d7ee0 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x000d7ee0 [ 0.000000] On node 0 totalpages: 884335 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4a28200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 5134 pages used for memmap [ 0.000000] HighMem zone: 651988 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000 [ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at ec000000 (gap: ec000000:12c00000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 877425 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=f5450cb5-ba50-4e7d-9896-20164f0a96a6 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 7075456 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:000d7ee0) [ 0.000000] Memory: 3482060k/3537792k available (3495k kernel code, 55280k reserved, 1237k data, 416k init, 2628488k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:712 16 [ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2666.604 MHz processor. [ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5333.20 BogoMIPS (lpj=10666416) [ 0.004006] pid_max: default: 32768 minimum: 301 [ 0.004045] Security Framework initialized [ 0.004049] AppArmor: AppArmor disabled by boot time parameter [ 0.004065] Mount-cache hash table entries: 512 [ 0.004247] Initializing cgroup subsys cpuacct [ 0.004250] Initializing cgroup subsys memory [ 0.004257] Initializing cgroup subsys devices [ 0.004259] Initializing cgroup subsys freezer [ 0.004261] Initializing cgroup subsys net_cls [ 0.004263] Initializing cgroup subsys blkio [ 0.004269] Initializing cgroup subsys perf_event [ 0.004294] CPU: Physical Processor ID: 0 [ 0.004295] CPU: Processor Core ID: 0 [ 0.004298] mce: CPU supports 6 MCE banks [ 0.004303] CPU0: Thermal monitoring enabled (TM2) [ 0.004350] ACPI: Core revision 20120320 [ 0.011407] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.011763] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.051458] CPU0: Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz stepping 0b [ 0.052002] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver. [ 0.052002] PEBS disabled due to CPU errata. [ 0.052002] ... version: 2 [ 0.052002] ... bit width: 40 [ 0.052002] ... generic registers: 2 [ 0.052002] ... value mask: 000000ffffffffff [ 0.052002] ... max period: 000000007fffffff [ 0.052002] ... fixed-purpose events: 3 [ 0.052002] ... event mask: 0000000700000003 [ 0.060057] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.072023] CPU 1 irqstacks, hard=f3cd4000 soft=f3cd6000 [ 0.072026] Booting Node 0, Processors #1 [ 0.008000] Initializing CPU#1 [ 0.084034] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.084073] Brought up 2 CPUs [ 0.084075] Total of 2 processors activated (10666.41 BogoMIPS). [ 0.085590] devtmpfs: initialized [ 0.085590] PM: Registering ACPI NVS region [mem 0xd7ee0000-0xd7ee2fff] (12288 bytes) [ 0.085590] dummy: [ 0.085590] NET: Registered protocol family 16 [ 0.085590] ACPI: bus type pci registered [ 0.085590] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe8000000-0xebffffff] (base 0xe8000000) [ 0.085590] PCI: MMCONFIG at [mem 0xe8000000-0xebffffff] reserved in E820 [ 0.085590] PCI: Using MMCONFIG for extended config space [ 0.085590] PCI: Using configuration type 1 for base access [ 0.085590] bio: create slab <bio-0> at 0 [ 0.088049] ACPI: Added _OSI(Module Device) [ 0.088051] ACPI: Added _OSI(Processor Device) [ 0.088054] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.088056] ACPI: Added _OSI(Processor Aggregator Device) [ 0.089152] ACPI: EC: Look up EC in DSDT [ 0.094227] ACPI: SSDT d7ee7f80 0022A (v01 PmRef Cpu0Ist 00003000 INTL 20040311) [ 0.094506] ACPI: Dynamic OEM Table Load: [ 0.094509] ACPI: SSDT (null) 0022A (v01 PmRef Cpu0Ist 00003000 INTL 20040311) [ 0.094710] ACPI: SSDT d7ee8440 00152 (v01 PmRef Cpu1Ist 00003000 INTL 20040311) [ 0.094974] ACPI: Dynamic OEM Table Load: [ 0.094977] ACPI: SSDT (null) 00152 (v01 PmRef Cpu1Ist 00003000 INTL 20040311) [ 0.095196] ACPI: Interpreter enabled [ 0.095213] ACPI: (supports S0 S3 S4 S5) [ 0.095239] ACPI: Using IOAPIC for interrupt routing [ 0.100635] ACPI: No dock devices found. [ 0.100643] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.100703] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3f]) [ 0.100793] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] [ 0.100796] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] [ 0.100798] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.100801] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff] [ 0.100803] pci_root PNP0A03:00: host bridge window [mem 0xd7f00000-0xfebfffff] [ 0.100843] PCI host bridge to bus 0000:00 [ 0.100845] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.100848] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.100850] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.100853] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff] [ 0.100855] pci_bus 0000:00: root bus resource [mem 0xd7f00000-0xfebfffff] [ 0.100866] pci 0000:00:00.0: [8086:2e20] type 00 class 0x060000 [ 0.100905] pci 0000:00:01.0: [8086:2e21] type 01 class 0x060400 [ 0.100936] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.100975] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300 [ 0.101016] pci 0000:00:1a.0: reg 20: [io 0xe000-0xe01f] [ 0.101058] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300 [ 0.101099] pci 0000:00:1a.1: reg 20: [io 0xe100-0xe11f] [ 0.101141] pci 0000:00:1a.2: [8086:3a39] type 00 class 0x0c0300 [ 0.101182] pci 0000:00:1a.2: reg 20: [io 0xe500-0xe51f] [ 0.101227] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320 [ 0.101243] pci 0000:00:1a.7: reg 10: [mem 0xf4105000-0xf41053ff] [ 0.101322] pci 0000:00:1b.0: [8086:3a3e] type 00 class 0x040300 [ 0.101336] pci 0000:00:1b.0: reg 10: [mem 0xf4100000-0xf4103fff 64bit] [ 0.101388] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.101409] pci 0000:00:1c.0: [8086:3a40] type 01 class 0x060400 [ 0.101462] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.101487] pci 0000:00:1c.4: [8086:3a48] type 01 class 0x060400 [ 0.101540] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.101562] pci 0000:00:1c.5: [8086:3a4a] type 01 class 0x060400 [ 0.101614] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.101639] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300 [ 0.101680] pci 0000:00:1d.0: reg 20: [io 0xe200-0xe21f] [ 0.101722] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300 [ 0.101762] pci 0000:00:1d.1: reg 20: [io 0xe300-0xe31f] [ 0.101804] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300 [ 0.101845] pci 0000:00:1d.2: reg 20: [io 0xe400-0xe41f] [ 0.101891] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320 [ 0.101907] pci 0000:00:1d.7: reg 10: [mem 0xf4104000-0xf41043ff] [ 0.101981] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401 [ 0.102034] pci 0000:00:1f.0: [8086:3a18] type 00 class 0x060100 [ 0.102136] pci 0000:00:1f.2: [8086:3a20] type 00 class 0x01018a [ 0.102150] pci 0000:00:1f.2: reg 10: [io 0x0000-0x0007] [ 0.102158] pci 0000:00:1f.2: reg 14: [io 0x0000-0x0003] [ 0.102166] pci 0000:00:1f.2: reg 18: [io 0x0000-0x0007] [ 0.102174] pci 0000:00:1f.2: reg 1c: [io 0x0000-0x0003] [ 0.102182] pci 0000:00:1f.2: reg 20: [io 0xf000-0xf00f] [ 0.102189] pci 0000:00:1f.2: reg 24: [io 0xf100-0xf10f] [ 0.102224] pci 0000:00:1f.3: [8086:3a30] type 00 class 0x0c0500 [ 0.102239] pci 0000:00:1f.3: reg 10: [mem 0xf4106000-0xf41060ff 64bit] [ 0.102259] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f] [ 0.102290] pci 0000:00:1f.5: [8086:3a26] type 00 class 0x010185 [ 0.102305] pci 0000:00:1f.5: reg 10: [io 0xe700-0xe707] [ 0.102312] pci 0000:00:1f.5: reg 14: [io 0xe800-0xe803] [ 0.102320] pci 0000:00:1f.5: reg 18: [io 0xe900-0xe907] [ 0.102328] pci 0000:00:1f.5: reg 1c: [io 0xea00-0xea03] [ 0.102336] pci 0000:00:1f.5: reg 20: [io 0xeb00-0xeb0f] [ 0.102343] pci 0000:00:1f.5: reg 24: [io 0xec00-0xec0f] [ 0.102409] pci 0000:01:00.0: [10de:1201] type 00 class 0x030000 [ 0.102419] pci 0000:01:00.0: reg 10: [mem 0xec000000-0xedffffff] [ 0.102430] pci 0000:01:00.0: reg 14: [mem 0xd8000000-0xdfffffff 64bit pref] [ 0.102441] pci 0000:01:00.0: reg 1c: [mem 0xe0000000-0xe3ffffff 64bit pref] [ 0.102448] pci 0000:01:00.0: reg 24: [io 0xa000-0xa07f] [ 0.102456] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0007ffff pref] [ 0.102499] pci 0000:01:00.1: [10de:0e0c] type 00 class 0x040300 [ 0.102510] pci 0000:01:00.1: reg 10: [mem 0xef000000-0xef003fff] [ 0.102590] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.102593] pci 0000:00:01.0: bridge window [io 0xa000-0xafff] [ 0.102596] pci 0000:00:01.0: bridge window [mem 0xec000000-0xefffffff] [ 0.102601] pci 0000:00:01.0: bridge window [mem 0xd8000000-0xe7ffffff 64bit pref] [ 0.102638] pci 0000:00:1c.0: PCI bridge to [bus 02-02] [ 0.102699] pci 0000:03:00.0: [197b:2368] type 00 class 0x010185 [ 0.102729] pci 0000:03:00.0: reg 10: [io 0xb000-0xb007] [ 0.102742] pci 0000:03:00.0: reg 14: [io 0xb100-0xb103] [ 0.102756] pci 0000:03:00.0: reg 18: [io 0xb200-0xb207] [ 0.102770] pci 0000:03:00.0: reg 1c: [io 0xb300-0xb303] [ 0.102784] pci 0000:03:00.0: reg 20: [io 0xb400-0xb40f] [ 0.102855] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.102865] pci 0000:00:1c.4: PCI bridge to [bus 03-03] [ 0.102869] pci 0000:00:1c.4: bridge window [io 0xb000-0xbfff] [ 0.102873] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf0ffffff] [ 0.102932] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000 [ 0.102948] pci 0000:04:00.0: reg 10: [io 0xc000-0xc0ff] [ 0.102976] pci 0000:04:00.0: reg 18: [mem 0xf4010000-0xf4010fff 64bit pref] [ 0.102994] pci 0000:04:00.0: reg 20: [mem 0xf4000000-0xf400ffff 64bit pref] [ 0.103006] pci 0000:04:00.0: reg 30: [mem 0x00000000-0x0000ffff pref] [ 0.103044] pci 0000:04:00.0: supports D1 D2 [ 0.103046] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.108024] pci 0000:00:1c.5: PCI bridge to [bus 04-04] [ 0.108029] pci 0000:00:1c.5: bridge window [io 0xc000-0xcfff] [ 0.108034] pci 0000:00:1c.5: bridge window [mem 0xf1000000-0xf1ffffff] [ 0.108041] pci 0000:00:1c.5: bridge window [mem 0xf4000000-0xf40fffff 64bit pref] [ 0.108074] pci 0000:05:00.0: [9710:9805] type 00 class 0x078000 [ 0.108090] pci 0000:05:00.0: reg 10: [io 0xd000-0xd007] [ 0.108101] pci 0000:05:00.0: reg 14: [io 0xd100-0xd107] [ 0.108113] pci 0000:05:00.0: reg 18: [io 0xd200-0xd207] [ 0.108124] pci 0000:05:00.0: reg 1c: [io 0xd300-0xd307] [ 0.108135] pci 0000:05:00.0: reg 20: [io 0xd400-0xd407] [ 0.108146] pci 0000:05:00.0: reg 24: [io 0xd500-0xd50f] [ 0.108181] pci 0000:05:01.0: [8086:107c] type 00 class 0x020000 [ 0.108207] pci 0000:05:01.0: reg 10: [mem 0xf3020000-0xf303ffff] [ 0.108217] pci 0000:05:01.0: reg 14: [mem 0xf3000000-0xf301ffff] [ 0.108227] pci 0000:05:01.0: reg 18: [io 0xd600-0xd63f] [ 0.108260] pci 0000:05:01.0: reg 30: [mem 0x00000000-0x0001ffff pref] [ 0.108283] pci 0000:05:01.0: PME# supported from D0 D3hot D3cold [ 0.108330] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode) [ 0.108334] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff] [ 0.108338] pci 0000:00:1e.0: bridge window [mem 0xf2000000-0xf3ffffff] [ 0.108344] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.108347] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.108349] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.108352] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode) [ 0.108354] pci 0000:00:1e.0: bridge window [mem 0xd7f00000-0xfebfffff] (subtractive decode) [ 0.108374] pci_bus 0000:00: on NUMA node 0 [ 0.108377] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.108632] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT] [ 0.108697] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX4._PRT] [ 0.108765] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX5._PRT] [ 0.108821] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT] [ 0.108971] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.123601] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 *10 11 12 14 15) [ 0.123658] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 14 15) [ 0.123715] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.123771] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.123827] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 *4 5 6 7 9 10 11 12 14 15) [ 0.123883] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 *10 11 12 14 15) [ 0.123938] ACPI: PCI Interrupt Link [LNK0] (IRQs *3 4 5 6 7 9 10 11 12 14 15) [ 0.123994] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 *9 10 11 12 14 15) [ 0.124055] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.124055] vgaarb: loaded [ 0.124055] vgaarb: bridge control possible 0000:01:00.0 [ 0.124071] PCI: Using ACPI for IRQ routing [ 0.125350] PCI: pci_cache_line_size set to 64 bytes [ 0.125439] reserve RAM buffer: 000000000009f800 - 000000000009ffff [ 0.125442] reserve RAM buffer: 00000000d7ee0000 - 00000000d7ffffff [ 0.125577] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0 [ 0.125584] hpet0: 4 comparators, 64-bit 14.318180 MHz counter [ 0.127605] Switching to clocksource hpet [ 0.127662] pnp: PnP ACPI init [ 0.127672] ACPI: bus type pnp registered [ 0.127746] pnp 00:00: [bus 00-3f] [ 0.127749] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.127751] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.127753] pnp 00:00: [io 0x0d00-0xffff window] [ 0.127756] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.127758] pnp 00:00: [mem 0x000c0000-0x000dffff window] [ 0.127761] pnp 00:00: [mem 0xd7f00000-0xfebfffff window] [ 0.127813] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active) [ 0.127917] pnp 00:01: [io 0x0010-0x001f] [ 0.127920] pnp 00:01: [io 0x0022-0x003f] [ 0.127922] pnp 00:01: [io 0x0044-0x005f] [ 0.127924] pnp 00:01: [io 0x0062-0x0063] [ 0.127926] pnp 00:01: [io 0x0065-0x006f] [ 0.127928] pnp 00:01: [io 0x0074-0x007f] [ 0.127930] pnp 00:01: [io 0x0091-0x0093] [ 0.127932] pnp 00:01: [io 0x00a2-0x00bf] [ 0.127934] pnp 00:01: [io 0x00e0-0x00ef] [ 0.127936] pnp 00:01: [io 0x04d0-0x04d1] [ 0.127938] pnp 00:01: [io 0x0290-0x029f] [ 0.127938] pnp 00:01: [io 0x0800-0x087f] [ 0.127938] pnp 00:01: [io 0x0290-0x0294] [ 0.127938] pnp 00:01: [io 0x0880-0x088f] [ 0.127938] pnp 00:01: [io 0x04c0-0x04ff] [ 0.127938] system 00:01: [io 0x04d0-0x04d1] has been reserved [ 0.127938] system 00:01: [io 0x0290-0x029f] has been reserved [ 0.127938] system 00:01: [io 0x0800-0x087f] has been reserved [ 0.127938] system 00:01: [io 0x0290-0x0294] has been reserved [ 0.127938] system 00:01: [io 0x0880-0x088f] has been reserved [ 0.127938] system 00:01: [io 0x04c0-0x04ff] could not be reserved [ 0.127938] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.127938] pnp 00:02: [dma 4] [ 0.127938] pnp 00:02: [io 0x0000-0x000f] [ 0.127938] pnp 00:02: [io 0x0080-0x0090] [ 0.127938] pnp 00:02: [io 0x0094-0x009f] [ 0.127938] pnp 00:02: [io 0x00c0-0x00df] [ 0.127938] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.127938] pnp 00:03: [irq 0 disabled] [ 0.127938] pnp 00:03: [irq 8] [ 0.127938] pnp 00:03: [mem 0xfed00000-0xfed003ff] [ 0.127938] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.127938] pnp 00:04: [io 0x0070-0x0073] [ 0.127938] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.127938] pnp 00:05: [io 0x0061] [ 0.127938] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.127938] pnp 00:06: [io 0x00f0-0x00ff] [ 0.127938] pnp 00:06: [irq 13] [ 0.127938] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.127938] pnp 00:07: [io 0x03f0-0x03f5] [ 0.127938] pnp 00:07: [io 0x03f7] [ 0.127938] pnp 00:07: [irq 6] [ 0.127938] pnp 00:07: [dma 2] [ 0.127938] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.127938] pnp 00:08: [io 0x0378-0x037f] [ 0.127938] pnp 00:08: [irq 7] [ 0.127938] pnp 00:08: Plug and Play ACPI device, IDs PNP0400 (active) [ 0.127938] pnp 00:09: [io 0x0400-0x04bf] [ 0.127938] system 00:09: [io 0x0400-0x04bf] has been reserved [ 0.127938] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.127938] pnp 00:0a: [mem 0xe8000000-0xebffffff] [ 0.127938] system 00:0a: [mem 0xe8000000-0xebffffff] has been reserved [ 0.127938] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.127938] pnp 00:0b: [mem 0x000d1000-0x000d3fff] [ 0.127938] pnp 00:0b: [mem 0x000f0000-0x000f7fff] [ 0.127938] pnp 00:0b: [mem 0x000f8000-0x000fbfff] [ 0.127938] pnp 00:0b: [mem 0x000fc000-0x000fffff] [ 0.127938] pnp 00:0b: [mem 0xd7ee0000-0xd7efffff] [ 0.127938] pnp 00:0b: [mem 0x00000000-0x0009ffff] [ 0.127938] pnp 00:0b: [mem 0x00100000-0xd7edffff] [ 0.127938] pnp 00:0b: [mem 0xfec00000-0xfec00fff] [ 0.127938] pnp 00:0b: [mem 0xfed10000-0xfed1dfff] [ 0.127938] pnp 00:0b: [mem 0xfed20000-0xfed8ffff] [ 0.127938] pnp 00:0b: [mem 0xfee00000-0xfee00fff] [ 0.127938] pnp 00:0b: [mem 0xffb00000-0xffb7ffff] [ 0.127938] pnp 00:0b: [mem 0xfff00000-0xffffffff] [ 0.127938] pnp 00:0b: [mem 0x000e0000-0x000effff] [ 0.127938] system 00:0b: [mem 0x000d1000-0x000d3fff] has been reserved [ 0.127938] system 00:0b: [mem 0x000f0000-0x000f7fff] could not be reserved [ 0.127938] system 00:0b: [mem 0x000f8000-0x000fbfff] could not be reserved [ 0.127938] system 00:0b: [mem 0x000fc000-0x000fffff] could not be reserved [ 0.127938] system 00:0b: [mem 0xd7ee0000-0xd7efffff] could not be reserved [ 0.127938] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.127938] system 00:0b: [mem 0x00100000-0xd7edffff] could not be reserved [ 0.127938] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.127938] system 00:0b: [mem 0xfed10000-0xfed1dfff] has been reserved [ 0.127938] system 00:0b: [mem 0xfed20000-0xfed8ffff] has been reserved [ 0.127938] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.127938] system 00:0b: [mem 0xffb00000-0xffb7ffff] has been reserved [ 0.127938] system 00:0b: [mem 0xfff00000-0xffffffff] has been reserved [ 0.127938] system 00:0b: [mem 0x000e0000-0x000effff] has been reserved [ 0.127938] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.127938] pnp 00:0c: [mem 0xffb80000-0xffbfffff] [ 0.127938] pnp 00:0c: Plug and Play ACPI device, IDs INT0800 (active) [ 0.127938] pnp: PnP ACPI: found 13 devices [ 0.127938] ACPI: ACPI bus type pnp unregistered [ 0.127938] PnPBIOS: Disabled by ACPI PNP [ 0.162802] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000 [ 0.162806] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000 [ 0.162810] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02-02] add_size 200000 [ 0.162818] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000 [ 0.162836] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000 [ 0.162839] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.162842] pci 0000:00:1c.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.162845] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.162849] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf4200000-0xf43fffff] [ 0.162853] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf4400000-0xf45fffff 64bit pref] [ 0.162856] pci 0000:00:1c.4: BAR 15: assigned [mem 0xf4600000-0xf47fffff 64bit pref] [ 0.162859] pci 0000:00:1e.0: BAR 15: assigned [mem 0xd7f00000-0xd7ffffff pref] [ 0.162862] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff] [ 0.162867] pci 0000:01:00.0: BAR 6: assigned [mem 0xe4000000-0xe407ffff pref] [ 0.162869] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.162872] pci 0000:00:01.0: bridge window [io 0xa000-0xafff] [ 0.162876] pci 0000:00:01.0: bridge window [mem 0xec000000-0xefffffff] [ 0.162879] pci 0000:00:01.0: bridge window [mem 0xd8000000-0xe7ffffff 64bit pref] [ 0.162883] pci 0000:00:1c.0: PCI bridge to [bus 02-02] [ 0.162886] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff] [ 0.162891] pci 0000:00:1c.0: bridge window [mem 0xf4200000-0xf43fffff] [ 0.162895] pci 0000:00:1c.0: bridge window [mem 0xf4400000-0xf45fffff 64bit pref] [ 0.162901] pci 0000:00:1c.4: PCI bridge to [bus 03-03] [ 0.162904] pci 0000:00:1c.4: bridge window [io 0xb000-0xbfff] [ 0.162908] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf0ffffff] [ 0.162912] pci 0000:00:1c.4: bridge window [mem 0xf4600000-0xf47fffff 64bit pref] [ 0.162919] pci 0000:04:00.0: BAR 6: assigned [mem 0xf4020000-0xf402ffff pref] [ 0.162921] pci 0000:00:1c.5: PCI bridge to [bus 04-04] [ 0.162924] pci 0000:00:1c.5: bridge window [io 0xc000-0xcfff] [ 0.162929] pci 0000:00:1c.5: bridge window [mem 0xf1000000-0xf1ffffff] [ 0.162933] pci 0000:00:1c.5: bridge window [mem 0xf4000000-0xf40fffff 64bit pref] [ 0.162939] pci 0000:05:01.0: BAR 6: assigned [mem 0xd7f00000-0xd7f1ffff pref] [ 0.162941] pci 0000:00:1e.0: PCI bridge to [bus 05-05] [ 0.162944] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff] [ 0.162949] pci 0000:00:1e.0: bridge window [mem 0xf2000000-0xf3ffffff] [ 0.162953] pci 0000:00:1e.0: bridge window [mem 0xd7f00000-0xd7ffffff pref] [ 0.162989] pci 0000:00:1e.0: setting latency timer to 64 [ 0.162993] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.162995] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.162998] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.163000] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff] [ 0.163003] pci_bus 0000:00: resource 8 [mem 0xd7f00000-0xfebfffff] [ 0.163005] pci_bus 0000:01: resource 0 [io 0xa000-0xafff] [ 0.163007] pci_bus 0000:01: resource 1 [mem 0xec000000-0xefffffff] [ 0.163010] pci_bus 0000:01: resource 2 [mem 0xd8000000-0xe7ffffff 64bit pref] [ 0.163012] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff] [ 0.163014] pci_bus 0000:02: resource 1 [mem 0xf4200000-0xf43fffff] [ 0.163017] pci_bus 0000:02: resource 2 [mem 0xf4400000-0xf45fffff 64bit pref] [ 0.163019] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff] [ 0.163022] pci_bus 0000:03: resource 1 [mem 0xf0000000-0xf0ffffff] [ 0.163024] pci_bus 0000:03: resource 2 [mem 0xf4600000-0xf47fffff 64bit pref] [ 0.163026] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff] [ 0.163028] pci_bus 0000:04: resource 1 [mem 0xf1000000-0xf1ffffff] [ 0.163031] pci_bus 0000:04: resource 2 [mem 0xf4000000-0xf40fffff 64bit pref] [ 0.163033] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff] [ 0.163036] pci_bus 0000:05: resource 1 [mem 0xf2000000-0xf3ffffff] [ 0.163038] pci_bus 0000:05: resource 2 [mem 0xd7f00000-0xd7ffffff pref] [ 0.163040] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7] [ 0.163042] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff] [ 0.163045] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff] [ 0.163047] pci_bus 0000:05: resource 7 [mem 0x000c0000-0x000dffff] [ 0.163049] pci_bus 0000:05: resource 8 [mem 0xd7f00000-0xfebfffff] [ 0.163115] NET: Registered protocol family 2 [ 0.163175] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.163328] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.163590] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.163713] TCP: Hash tables configured (established 131072 bind 65536) [ 0.163715] TCP: reno registered [ 0.163718] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.163724] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.163793] NET: Registered protocol family 1 [ 0.164014] pci 0000:01:00.0: Boot video device [ 0.164029] PCI: CLS 32 bytes, default 64 [ 0.164069] Unpacking initramfs... [ 0.408479] Freeing initrd memory: 13712k freed [ 0.413165] audit: initializing netlink socket (disabled) [ 0.413184] type=2000 audit(1551805903.412:1): initialized [ 0.423357] highmem bounce pool size: 64 pages [ 0.423361] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.423524] VFS: Disk quotas dquot_6.5.2 [ 0.423549] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.423618] msgmni has been set to 1693 [ 0.423765] alg: No test for stdrng (krng) [ 0.423788] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.423792] io scheduler noop registered [ 0.423794] io scheduler deadline registered [ 0.423812] io scheduler cfq registered (default) [ 0.424103] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.424121] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.424123] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.424599] GHES: HEST is not enabled! [ 0.424611] isapnp: Scanning for PnP cards... [ 0.777563] isapnp: No Plug & Play device found [ 0.777610] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.778035] Linux agpgart interface v0.103 [ 0.778323] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 0.778730] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.778744] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.778889] mousedev: PS/2 mouse device common for all mice [ 0.778939] rtc_cmos 00:04: RTC can wake from S4 [ 0.779059] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0 [ 0.779082] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs [ 0.779194] TCP: cubic registered [ 0.779243] NET: Registered protocol family 10 [ 0.779448] Mobile IPv6 [ 0.779451] NET: Registered protocol family 17 [ 0.779455] Registering the dns_resolver key type [ 0.779502] Using IPI No-Shortcut mode [ 0.779588] PM: Hibernation image not present or could not be loaded. [ 0.779598] registered taskstats version 1 [ 0.780010] rtc_cmos 00:04: setting system clock to 2019-03-05 17:11:44 UTC (1551805904) [ 0.780092] Freeing unused kernel memory: 416k freed [ 0.780259] Write protecting the kernel text: 3496k [ 0.780280] Write protecting the kernel read-only data: 984k [ 0.790214] udevd[49]: starting version 175 [ 0.803951] usbcore: registered new interface driver usbfs [ 0.803975] usbcore: registered new interface driver hub [ 0.804596] usbcore: registered new device driver usb [ 0.804960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.805018] ehci_hcd 0000:00:1a.7: setting latency timer to 64 [ 0.805022] ehci_hcd 0000:00:1a.7: EHCI Host Controller [ 0.805041] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1 [ 0.808944] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported [ 0.808966] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf4105000 [ 0.820030] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00 [ 0.820063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.820065] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.820068] usb usb1: Product: EHCI Host Controller [ 0.820070] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 0.820072] usb usb1: SerialNumber: 0000:00:1a.7 [ 0.820193] hub 1-0:1.0: USB hub found [ 0.820198] hub 1-0:1.0: 6 ports detected [ 0.820330] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 0.820334] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 0.820345] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2 [ 0.824262] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 0.824286] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf4104000 [ 0.824336] uhci_hcd: USB Universal Host Controller Interface driver [ 0.834950] SCSI subsystem initialized [ 0.836024] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 0.836053] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.836056] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.836059] usb usb2: Product: EHCI Host Controller [ 0.836061] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 0.836063] usb usb2: SerialNumber: 0000:00:1d.7 [ 0.836182] hub 2-0:1.0: USB hub found [ 0.836187] hub 2-0:1.0: 6 ports detected [ 0.836488] uhci_hcd 0000:00:1a.0: setting latency timer to 64 [ 0.836492] uhci_hcd 0000:00:1a.0: UHCI Host Controller [ 0.836501] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3 [ 0.836539] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000e000 [ 0.836577] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.836580] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.836582] usb usb3: Product: UHCI Host Controller [ 0.836584] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.836586] usb usb3: SerialNumber: 0000:00:1a.0 [ 0.836830] hub 3-0:1.0: USB hub found [ 0.836835] hub 3-0:1.0: 2 ports detected [ 0.836922] uhci_hcd 0000:00:1a.1: setting latency timer to 64 [ 0.836926] uhci_hcd 0000:00:1a.1: UHCI Host Controller [ 0.836933] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4 [ 0.836965] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000e100 [ 0.836997] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.837000] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.837002] usb usb4: Product: UHCI Host Controller [ 0.837005] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.837007] usb usb4: SerialNumber: 0000:00:1a.1 [ 0.837096] hub 4-0:1.0: USB hub found [ 0.837101] hub 4-0:1.0: 2 ports detected [ 0.837181] uhci_hcd 0000:00:1a.2: setting latency timer to 64 [ 0.837185] uhci_hcd 0000:00:1a.2: UHCI Host Controller [ 0.837192] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5 [ 0.837215] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000e500 [ 0.837246] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.837248] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.837251] usb usb5: Product: UHCI Host Controller [ 0.837253] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.837255] usb usb5: SerialNumber: 0000:00:1a.2 [ 0.837344] hub 5-0:1.0: USB hub found [ 0.837348] hub 5-0:1.0: 2 ports detected [ 0.837429] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 0.837432] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 0.837444] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6 [ 0.837466] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000e200 [ 0.837497] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.837500] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.837502] usb usb6: Product: UHCI Host Controller [ 0.837504] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.837506] usb usb6: SerialNumber: 0000:00:1d.0 [ 0.837596] hub 6-0:1.0: USB hub found [ 0.837601] hub 6-0:1.0: 2 ports detected [ 0.837686] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 0.837689] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 0.837697] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7 [ 0.837733] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e300 [ 0.837764] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.837767] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.837769] usb usb7: Product: UHCI Host Controller [ 0.837771] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.837773] usb usb7: SerialNumber: 0000:00:1d.1 [ 0.837862] hub 7-0:1.0: USB hub found [ 0.837867] hub 7-0:1.0: 2 ports detected [ 0.837951] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 0.837954] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 0.837963] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8 [ 0.837985] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e400 [ 0.838016] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.838019] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.838021] usb usb8: Product: UHCI Host Controller [ 0.838023] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.838025] usb usb8: SerialNumber: 0000:00:1d.2 [ 0.838116] hub 8-0:1.0: USB hub found [ 0.838121] hub 8-0:1.0: 2 ports detected [ 0.838886] libata version 3.00 loaded. [ 0.839188] ata_piix 0000:00:1f.2: version 2.13 [ 0.839203] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] [ 0.839246] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 0.842764] scsi0 : ata_piix [ 0.842843] microcode: CPU0 sig=0x6fb, pf=0x1, revision=0xb6 [ 0.845573] scsi1 : ata_piix [ 0.846215] scsi2 : pata_jmicron [ 0.846283] scsi3 : pata_jmicron [ 0.846317] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14 [ 0.846322] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15 [ 0.846392] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ] [ 0.846433] ata_piix 0000:00:1f.5: setting latency timer to 64 [ 0.847274] ata3: PATA max UDMA/100 cmd 0xb000 ctl 0xb100 bmdma 0xb400 irq 16 [ 0.847277] ata4: PATA max UDMA/100 cmd 0xb200 ctl 0xb300 bmdma 0xb408 irq 16 [ 0.847444] scsi4 : ata_piix [ 0.847509] scsi5 : ata_piix [ 0.848489] ata5: SATA max UDMA/133 cmd 0xe700 ctl 0xe800 bmdma 0xeb00 irq 19 [ 0.848494] ata6: SATA max UDMA/133 cmd 0xe900 ctl 0xea00 bmdma 0xeb08 irq 19 [ 0.848954] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 0.848957] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.869309] Floppy drive(s): fd0 is 1.44M [ 0.887854] microcode: CPU0 updated to revision 0xba, date = 2010-10-03 [ 0.892025] microcode: CPU1 sig=0x6fb, pf=0x1, revision=0xb6 [ 0.896008] microcode: CPU1 updated to revision 0xba, date = 2010-10-03 [ 0.901025] FDC 0 is a post-1991 82077 [ 0.901397] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.178609] ata5: SATA link down (SStatus 0 SControl 300) [ 1.189238] ata6: SATA link down (SStatus 0 SControl 300) [ 1.302117] e1000 0000:05:01.0: eth0: (PCI:33MHz:32-bit) 00:1b:21:24:ec:5b [ 1.302126] e1000 0000:05:01.0: eth0: Intel(R) PRO/1000 Network Connection [ 1.412026] Refined TSC clocksource calibration: 2666.363 MHz. [ 1.412032] Switching to clocksource tsc [ 1.428030] usb 4-1: new full-speed USB device number 2 using uhci_hcd [ 1.615001] usb 4-1: New USB device found, idVendor=046d, idProduct=c52e [ 1.615004] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.615008] usb 4-1: Product: USB Receiver [ 1.615010] usb 4-1: Manufacturer: Logitech [ 1.626414] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.1/usb4/4-1/4-1:1.0/input/input0 [ 1.626461] generic-usb 0003:046D:C52E.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.1-1/input0 [ 1.630059] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.1/usb4/4-1/4-1:1.1/input/input1 [ 1.630161] generic-usb 0003:046D:C52E.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.1-1/input1 [ 1.630181] usbcore: registered new interface driver usbhid [ 1.630183] usbhid: USB HID core driver [ 1.656073] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.656087] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.656205] ata2.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.656216] ata2.01: SATA link down (SStatus 0 SControl 300) [ 1.685313] ata2.00: HPA detected: current 976771055, native 976773168 [ 1.685319] ata2.00: ATA-8: WDC WD5000AACS-00ZUB0, 01.01B01, max UDMA/133 [ 1.685322] ata2.00: 976771055 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 1.692567] ata2.00: configured for UDMA/133 [ 1.715100] ata1.00: HPA detected: current 625140335, native 625142448 [ 1.715105] ata1.00: ATA-7: MAXTOR STM3320620AS, 3.AAE, max UDMA/133 [ 1.715108] ata1.00: 625140335 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 1.715191] ata1.01: ATA-9: OCZ-AGILITY4, 1.4.1.3, max UDMA/133 [ 1.715195] ata1.01: 125045424 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 1.781731] ata1.00: configured for UDMA/133 [ 1.788194] ata1.01: configured for UDMA/133 [ 1.788294] scsi 0:0:0:0: Direct-Access ATA MAXTOR STM332062 3.AA PQ: 0 ANSI: 5 [ 1.788468] scsi 0:0:1:0: Direct-Access ATA OCZ-AGILITY4 1.4. PQ: 0 ANSI: 5 [ 1.788647] scsi 1:0:0:0: Direct-Access ATA WDC WD5000AACS-0 01.0 PQ: 0 ANSI: 5 [ 1.860024] usb 4-2: new low-speed USB device number 3 using uhci_hcd [ 1.945079] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 1.945288] r8169 0000:04:00.0: eth1: RTL8168c/8111c at 0xf8016000, 00:1f:d0:95:5b:8c, XID 1c4000c0 IRQ 17 [ 1.945291] r8169 0000:04:00.0: eth1: jumbo features [frames: 6128 bytes, tx checksumming: ko] [ 1.950760] sd 0:0:0:0: [sda] 625140335 512-byte logical blocks: (320 GB/298 GiB) [ 1.950815] sd 0:0:0:0: [sda] Write Protect is off [ 1.950818] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.950841] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.952822] sd 1:0:0:0: [sdc] 976771055 512-byte logical blocks: (500 GB/465 GiB) [ 1.952875] sd 1:0:0:0: [sdc] Write Protect is off [ 1.952878] sd 1:0:0:0: [sdc] Mode Sense: 00 3a 00 00 [ 1.952901] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.955581] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 1.955616] sd 0:0:1:0: Attached scsi generic sg1 type 0 [ 1.955651] sd 1:0:0:0: Attached scsi generic sg2 type 0 [ 1.971408] sd 0:0:1:0: [sdb] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB) [ 1.971538] sda: sda1 [ 1.971552] sd 0:0:1:0: [sdb] Write Protect is off [ 1.971556] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00 [ 1.971587] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.971838] sd 0:0:0:0: [sda] Attached SCSI disk [ 1.972358] sdb: sdb1 sdb2 < sdb5 > [ 1.972635] sd 0:0:1:0: [sdb] Attached SCSI disk [ 1.976810] sdc: sdc1 sdc2 < sdc5 > [ 1.977092] sd 1:0:0:0: [sdc] Attached SCSI disk [ 2.037002] usb 4-2: New USB device found, idVendor=046d, idProduct=c216 [ 2.037007] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.037010] usb 4-2: Product: Logitech Dual Action [ 2.037013] usb 4-2: Manufacturer: Logitech [ 2.068084] input: Logitech Logitech Dual Action as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/input/input2 [ 2.068136] generic-usb 0003:046D:C216.0003: input,hidraw2: USB HID v1.10 Joystick [Logitech Logitech Dual Action] on usb-0000:00:1a.1-2/input0 [ 7.277442] PM: Starting manual resume from disk [ 7.277446] PM: Hibernation image partition 8:21 present [ 7.277447] PM: Looking for hibernation image. [ 7.277714] PM: Image not found (code -22) [ 7.277716] PM: Hibernation image not present or could not be loaded. [ 7.288704] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null) [ 7.523084] udevd[387]: starting version 175 [ 7.590406] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3 [ 7.590412] ACPI: Power Button [PWRB] [ 7.590481] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4 [ 7.590485] ACPI: Power Button [PWRF] [ 7.635064] [drm] Initialized drm 1.1.0 20060810 [ 7.645337] wmi: Mapper loaded [ 7.647313] parport_pc 00:08: reported by Plug and Play ACPI [ 7.647337] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP] [ 7.648228] udevd[465]: renamed network interface eth1 to rename3 [ 7.666156] iTCO_vendor_support: vendor-support=0 [ 7.666759] [drm] nouveau 0000:01:00.0: Detected an NVc0 generation card (0x0ce080a1) [ 7.668729] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 7.668863] iTCO_wdt: Found a ICH10 TCO device (Version=2, TCOBASE=0x0460) [ 7.670823] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 7.682795] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS [ 7.687070] coretemp coretemp.0: Using relative temperature scale! [ 7.687080] coretemp coretemp.0: Using relative temperature scale! [ 7.700159] udevd[443]: renamed network interface eth0 to eth1 [ 7.713185] udevd[465]: renamed network interface rename3 to eth0 [ 7.717299] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5 [ 7.733077] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6 [ 7.735074] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7 [ 7.735873] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8 [ 7.740457] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9 [ 7.740657] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10 [ 7.740805] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11 [ 7.740877] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12 [ 7.740938] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13 [ 7.744246] PCI parallel port detected: 9710:9805, I/O at 0xd000(0xd100), IRQ 20 [ 7.744287] parport1: PC-style at 0xd000 (0xd100), irq 20 [PCSPP,TRISTATE] [ 7.830714] [drm] nouveau 0000:01:00.0: ... appears to be valid [ 7.830718] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN [ 7.830721] [drm] nouveau 0000:01:00.0: BIT BIOS found [ 7.830724] [drm] nouveau 0000:01:00.0: Bios version 70.24.2e.00 [ 7.830727] [drm] nouveau 0000:01:00.0: TMDS table version 2.0 [ 7.831040] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do [ 7.831043] [drm] nouveau 0000:01:00.0: DCB version 4.0 [ 7.831046] [drm] nouveau 0000:01:00.0: DCB outp 00: 02000300 00000000 [ 7.831048] [drm] nouveau 0000:01:00.0: DCB outp 01: 01000302 00020030 [ 7.831051] [drm] nouveau 0000:01:00.0: DCB outp 02: 04011380 00000000 [ 7.831053] [drm] nouveau 0000:01:00.0: DCB outp 03: 08011382 00020030 [ 7.831055] [drm] nouveau 0000:01:00.0: DCB outp 04: 02022362 00020010 [ 7.831057] [drm] nouveau 0000:01:00.0: DCB conn 00: 00001030 [ 7.831060] [drm] nouveau 0000:01:00.0: DCB conn 01: 00010130 [ 7.831062] [drm] nouveau 0000:01:00.0: DCB conn 02: 00002261 [ 7.831067] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0x6EB0 [ 7.851124] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0x75B0 [ 7.858747] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0x8C88 [ 7.858750] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0x8C92 [ 7.858802] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0x8E71 [ 7.858804] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0x8ED6 [ 7.878856] [drm] nouveau 0000:01:00.0: 0x8ED6: Condition still not met after 20ms, skipping following opcodes [ 7.884217] [TTM] Zone kernel: Available graphics memory: 433850 kiB [ 7.884220] [TTM] Zone highmem: Available graphics memory: 1748094 kiB [ 7.884222] [TTM] Initializing pool allocator [ 7.884232] [drm] nouveau 0000:01:00.0: Detected 1024MiB VRAM (GDDR5) [ 7.884239] mtrr: type mismatch for d8000000,8000000 old: write-back new: write-combining [ 7.884251] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture) [ 7.887938] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 7.887940] [drm] No driver support for vblank timestamp query. [ 7.893334] [drm] nouveau 0000:01:00.0: 3 available performance level(s) [ 7.893339] [drm] nouveau 0000:01:00.0: 0: core 50MHz shader 101MHz memory 135MHz voltage 875mV [ 7.893342] [drm] nouveau 0000:01:00.0: 1: core 405MHz shader 810MHz memory 324MHz voltage 912mV [ 7.893346] [drm] nouveau 0000:01:00.0: 3: core 850MHz shader 1701MHz memory 2052MHz voltage 975mV-1087mV [ 7.893350] [drm] nouveau 0000:01:00.0: c: core 50MHz shader 101MHz memory 135MHz voltage 875mV fanspeed 40% [ 8.073628] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x1c0000, bo f6dc2200 [ 8.073692] fbcon: nouveaufb (fb0) is primary device [ 8.098958] Console: switching to colour frame buffer device 160x64 [ 8.106363] fb0: nouveaufb frame buffer device [ 8.106365] drm: registered panic notifier [ 8.106369] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0 [ 8.106401] hda_intel: Disabling MSI [ 8.992108] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14 [ 8.992206] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15 [ 8.992449] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16 [ 8.993259] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17 [ 9.269616] Adding 2579452k swap on /dev/sdb5. Priority:-1 extents:1 across:2579452k SS [ 9.281076] EXT4-fs (sdb1): re-mounted. Opts: (null) [ 9.607446] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro [ 9.631736] loop: module loaded [ 10.201139] RPC: Registered named UNIX socket transport module. [ 10.201142] RPC: Registered udp transport module. [ 10.201143] RPC: Registered tcp transport module. [ 10.201145] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 10.206377] FS-Cache: Loaded [ 10.213641] NFS: Registering the id_resolver key type [ 10.213660] FS-Cache: Netfs 'nfs' registered for caching [ 10.218567] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 10.827915] Bluetooth: Core ver 2.16 [ 10.827929] NET: Registered protocol family 31 [ 10.827931] Bluetooth: HCI device and connection manager initialized [ 10.827933] Bluetooth: HCI socket layer initialized [ 10.827935] Bluetooth: L2CAP socket layer initialized [ 10.827940] Bluetooth: SCO socket layer initialized [ 10.835293] Bluetooth: RFCOMM TTY layer initialized [ 10.835299] Bluetooth: RFCOMM socket layer initialized [ 10.835301] Bluetooth: RFCOMM ver 1.11 [ 10.865643] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 10.865646] Bluetooth: BNEP filters: protocol multicast [ 10.893931] lp0: using parport0 (interrupt-driven). [ 10.893969] lp1: using parport1 (interrupt-driven). [ 10.899818] ppdev: user-space parallel port driver [ 11.020114] r8169 0000:04:00.0: eth0: link down [ 11.020252] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 11.027041] ADDRCONF(NETDEV_UP): eth1: link is not ready [ 11.028425] e1000: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX [ 11.028565] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 11.612564] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input18 [ 35.219970] I-pipe: head domain RTAI registered. [ 35.219974] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 35.220001] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 35.220005] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20829427, CLK_FREQ 2666604000, CPU_FREQ 2666604000 [ 35.220007] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 35.220010] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20829427, 20829427, 20099500 [ 35.238062] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 35.238088] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 35.238092] RTAI[sched]: hard timer type/freq = APIC/20829427(Hz); default timing: oneshot; linear timed lists. [ 35.238095] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666604000 hz. [ 35.238097] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 35.246379] RTAI[math]: loaded. [ 35.320850] config string '0 out' [ 36.939025] [drm] nouveau 0000:01:00.0: PMFB0_SUBP0: 0x037f0000 [ 36.939031] [drm] nouveau 0000:01:00.0: PMFB0_SUBP1: 0x037f0040 [ 36.939036] [drm] nouveau 0000:01:00.0: PMFB1_SUBP0: 0x037f0040 [ 36.939040] [drm] nouveau 0000:01:00.0: PMFB1_SUBP1: 0x037f0000 [ 36.939045] [drm] nouveau 0000:01:00.0: PMFB2_SUBP0: 0x037f0000 [ 36.939049] [drm] nouveau 0000:01:00.0: PMFB2_SUBP1: 0x037f0040 [ 36.939054] [drm] nouveau 0000:01:00.0: PMFB3_SUBP0: 0x037f0040 [ 36.939058] [drm] nouveau 0000:01:00.0: PMFB3_SUBP1: 0x037f0000 [ 39.177454] RTAI[math]: unloaded. [ 39.180603] SCHED releases registered named ALIEN PEDV$D [ 39.185460] RTAI[malloc]: unloaded. [ 39.284016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 39.287728] I-pipe: head domain RTAI unregistered. [ 39.287759] RTAI[hal]: unmounted.
Last edit: 7 years 7 months ago by andypugh.
7 years 7 months ago #127836 by andypugh
This is the error, line 71 of your custom_postgui HAL file.
addf debounce.0 base-thread setp debounce.0.delay 100 unlinkp motion.probe-input net probe-in debounce.0.0.in net probe-filt debounce.0.0.out => motion.probe-input
You need (somewhere) a "loadrt debounce"
Given that you appear not to have one anywhere else, add it here, before line 71.
loadrt debounce cfg=1
linuxcnc.org/docs/devel/html/man/man9/debounce.9.html
7 years 7 months ago #127837 by tony978
thank you !!! that worked , I'm shocked it was working before I added the probe tab .
Time to create page: 0.393 seconds
