Stretch Distribution Update to Master RT-preempt not working
- tuffduck33
06 Mar 2019 20:52 #127910
by tuffduck33
Stretch Distribution Update to Master RT-preempt not working was created by tuffduck33
I have downloaded and installed the Stretch Iso from www.linuxcnc.org/testing-stretch-rtpreempt/ and selected the linuxcnc-stretch-uspace-amd64-r13.iso. It installed well. I have tried installing the keys for master but I always get an error. I am using the guide posted by BigJohnT at gnipsel.com/linuxcnc/uspace/debian9-emc.html.
Is there something I have missed that I cannot add the master branch either through terminal or through synaptic?
- Leon82
- Thank you received: 79
06 Mar 2019 22:11 #127914
by Leon82
Replied by Leon82 on topic Stretch Distribution Update to Master RT-preempt not working
There is another guide on this forum posted by big John that I followed to get stretch I'll see if I can find the link but it's one of the first things that comes up when you Google linuxcnc on Debian 9
- tuffduck33
06 Mar 2019 22:24 #127915
by tuffduck33
Replied by tuffduck33 on topic Stretch Distribution Update to Master RT-preempt not working
I Have linuxcnc 2.7.14 installed. Iam trying to get it to update to 2.8.
- Leon82
06 Mar 2019 22:29 #127916
by Leon82
in they synaptic manager search linuxcncand hit reload
also go to settings, repositories and see if one of them is not checked
- Clive S
- Thank you received: 486
06 Mar 2019 22:29 - 06 Mar 2019 22:31 #127917
by Clive S
Have a look at this post forum.linuxcnc.org/38-general-linuxcnc-q...updating-2-8?start=0 #113221 by Tod
Replied by Clive S on topic Stretch Distribution Update to Master RT-preempt not working
Last edit: 06 Mar 2019 22:31 by Clive S.
- tuffduck33
07 Mar 2019 03:23 #127942
by tuffduck33
Thanks, that did the trick. I just have to copy the config files from the working system over and test.
- tuffduck33
07 Mar 2019 03:24 #127943
by tuffduck33
Thanks for the help, 2.8 is installed.
- Leon82
07 Mar 2019 10:09 #127963
by Leon82
It's going to give you a warning when you first launch that it will update the config files. It will back them up also
- tuffduck33
07 Mar 2019 16:26 #127996
by tuffduck33
okay, thanks for the heads up.
Time to create page: 0.267 seconds
