- Thank you received: 358
MPG handwheel sources
7 years 7 months ago #128069
by pl7i92
Replied by pl7i92 on topic MPG handwheel sources
No eBay APP ID and/or Cert ID defined in Kunena configurationHere in germany you can buy them for 15Euros
use Handwheel encoder to search
on ebay
on ebay
7 years 7 months ago #128081
by OT-CNC
Replied by OT-CNC on topic MPG handwheel sources
These all look similar to the ones I use off fleabay. I wore out the spring detent mechanism pretty quickly on one. There is a rather thin stainless flat spring that pushes against a roller that clicks into the grooves. Mine fatigued and snapped. I replaced it with a home made spring. Works fine but the feel is a bit loose now after some time. Also the lines engraved on the dial do not always line up with the slot, suggesting it was not concentric during marking and the timing is often off too. The lines may line up in the vertical position and half rotation between two. If you're like me and that kind of stuff bugs you, I suggest getting a better unit otherwise they are just fine. Once installed you most likely never look at the dial and the lines anyway. The tactile feel to me is more important.
MaHa
Nice job on the engraving. I did mine on the laser. Looks cool.
MaHa
7 years 7 months ago #128083
by OT-CNC
Meant to add, some have a horrible smell to them. The later one I ordered was fine but few years back, they used some nasty rubber for the lower gasket. I chucked that and had to make a new gasket. You know the smell. Smelled like odor you encounter when walking into tractor supply or horbor freight here in the US.
7 years 7 months ago #128085
Replied by PCW on topic MPG handwheel sources
Bought a flashlight at the Dollar store a couple years ago, smelled so bad I had to leave it outdoors. Wonder if they used old motor oil as a plasticizer...
- Ivan_The_Red
- Topic Author
7 years 7 months ago #128185
by Ivan_The_Red
Replied by Ivan_The_Red on topic MPG handwheel sources
Thanks for all of your input, looks like ill try one of those cheap units since most responses were positive and for $20.00 its worth a try.
Time to create page: 0.109 seconds
