Writing a .pp - need explaination for error code
- allenwg2005
- Thank you received: 4
08 Mar 2019 18:48 #128102
by allenwg2005
Writing a .pp - need explaination for error code was created by allenwg2005
Not sure this thread belongs here, apologies if that's the case.
I've been working on a PP with ATC for Vetric software, I have a ngc file that loads, when I try and run it I get the following:
"Need tool prepared - Txxx for Toolchange"
What dose this mean? (The tool number is there).
Here is the ngc file I tried to run:
( New ) ( File created: Friday March 08 2019 - 10:45 AM)
( for LinuxCNC )
( Material Size) ( X= 6.000, Y= 6.000, Z= 0.750)
G91 (Incremental distance mode)
G17 G20 (Active Plane: XY)(Inch Mode)
G40 G49 G80(Tool Diameter, Length compensation & canned cycles off)
G64 P0.05 Q0.05(Path Blending)
M06 (T1 End Mill 0.25 inch)
G43 H1
G90 (absolute distance mode)
G54 (Coordinate System)
S12000M5
G00 Z0.501
( T1 .250 EM Profile )
G00 X3.000 Y0.875 Z0.500 F104.5
G00 X3.000 Y0.875 Z0.200
G01 Z-0.187 F40.0 M3 G4 P2
G02 X0.875 Y3.000 I0.000 J2.125
G02 X3.000 Y5.125 I2.125 J0.000
G02 X5.125 Y3.000 I0.000 J-2.125
G02 X3.000 Y0.875 I-2.125 J0.000
G01 Z-0.375 F40.0 M3 G4 P2
G00 Z0.500
M05
M1 G64 P0.05 Q0.05
M0
M6 (T36 2mm tapered BN)
G43 H36
S12000 M03
( TT36 2mm BN 3D Finish )
G00 X3.123 Y0.885 Z0.500 F104.5
G00 X3.123 Y0.885 Z0.200
G01 X3.123 Y0.885 Z-0.750 F52.3
Any help is appreciated, Thanks
( for LinuxCNC )
G43 H1
S12000M5
G00 Z0.501
G00 Z0.500
M05
M1 G64 P0.05 Q0.05
M0
G43 H36
S12000 M03
- MaHa
- Thank you received: 241
08 Mar 2019 19:29 #128104
by MaHa
Replied by MaHa on topic Writing a .pp - need explaination for error code
Because M6 without tool. T1, T36 is inside the comment. Better is M06 T1 (End Mill 0.25 inch)
- Thank you received: 1477
08 Mar 2019 19:35 #128105
Replied by Todd Zuercher on topic Writing a .pp - need explaination for error code
I think your problem is that your tool numbers are enclosed in brackets making them a comment rather than a command.
So for example change line#9 from
to
T1 M06 (End Mill 0.25 inch)
to
( for LinuxCNC )
G43 H1
S12000M5
G00 Z0.501
G00 Z0.500
M05
M1 G64 P0.05 Q0.05
M0
T36 M6 (2mm tapered BN)
G43 H36
S12000 M03
G01 X3.123 Y0.885 Z-0.750 F52.3Please Log in or Create an account to join the conversation.
- allenwg2005
09 Mar 2019 02:28 #128123
by allenwg2005
Replied by allenwg2005 on topic Writing a .pp - need explaination for error code
Thank you I got this working.
- pl7i92
- Thank you received: 358
09 Mar 2019 08:07 #128132
by pl7i92
Replied by pl7i92 on topic Writing a .pp - need explaination for error code
can you tell the community what system it is and how you did it
as there has not been a Toolchange at all in the first post only a Operation Tool Information
- allenwg2005
09 Mar 2019 14:32 #128163
by allenwg2005
As for system, this is for Vetric Asipre v8.0, running on LinuxCNC 2.7.14 .
How I did it was 'coding, by guess and by golly', I have no idea how to code or exactly how I did it, other than try and fail until it works.
Vetric has a set of instructions on how to add a ATC under the Help tab, if you don't know how to code the following threads might help.
I attached a working PP (at lest it works on my machine) at the end of "Post for Vetric W/ATC:
"Please explain error message"
"Post for Vectric W/ATC"
I hope this helps others
