how to define a 90 deg cone cutter in the tool table?
- jamby
- Thank you received: 6
10 Mar 2019 03:34 #128200
by jamby
how to define a 90 deg cone cutter in the tool table? was created by jamby
Well the subject say's it
I want to define a V-carve tool with a 90 deg end 1/2 dia.
Jim
Jim
- pl7i92
- Thank you received: 358
10 Mar 2019 07:59 #128205
by pl7i92
Replied by pl7i92 on topic how to define a 90 deg cone cutter in the tool table?
why woudt you define a cone cutter in the tool table
the Gcode is produced by a CAM system si it is to define there
only the Discribtion is to be enterd and the diameter
- Thank you received: 4652
11 Mar 2019 12:40 #128317
Sorry, but you can't.
(And LinuxCNC wouldn't know what to do with the data if you could)
The graphical preview only shows the tool centre point path anyway, so you don't lose much.
Replied by andypugh on topic how to define a 90 deg cone cutter in the tool table?
- jamby
11 Mar 2019 19:06 #128371
by jamby
Replied by jamby on topic how to define a 90 deg cone cutter in the tool table?
Thanks Guys
When I set back and think about it, it doesn't make any difference.
Thanks again
Jim
Thanks again
Jim
Time to create page: 0.158 seconds
