Setting digit input true in gcode
- bevins
- Thank you received: 338
14 Mar 2019 18:24 #128601
by bevins
Setting digit input true in gcode was created by bevins
Is it possible to set a digital input true via gcode?
I know I can M66 wait for input, but I want to set it true.
- Thank you received: 1480
14 Mar 2019 20:45 #128607
Replied by Todd Zuercher on topic Setting digit input true in gcode
Sounds like you want a digital output M62-M65.
linuxcnc.org/docs/html/gcode/m-code.html#mcode:m62-m65
You'd then connect the digital output pins (motion.digital-out-00...) to what ever inputs you need to change in hal.
- bevins
14 Mar 2019 21:42 - 14 Mar 2019 21:54 #128611
by bevins
I am trying to set iocontrol.0.tool-change to true. It is an out bit.
Not in HAL, need to use gcode so I can put it in a function in a remap.
nevermind. its in the epilog, self.tool_change_flag = True
its not getting to task though.
Replied by bevins on topic Setting digit input true in gcode
Last edit: 14 Mar 2019 21:54 by bevins.
16 Mar 2019 11:47 #128723
Replied by andypugh on topic Setting digit input true in gcode
I am sure that this can't be the "right" way, and in fact might not even work, but have you tried command.mdi("m6") in the remap?
Time to create page: 0.093 seconds
