Setting G43 in remap required?
- bevins
- Thank you received: 338
20 Mar 2019 12:21 - 20 Mar 2019 12:22 #129050
by bevins
Setting G43 in remap required? was created by bevins
IS it normal that I have to set G43 in the remap for offsets to work after a remap?
If I do not do this, then the offsets are wrong. When I set it in my python remap, the offsets are correct.
I have seen oword remaps with G43 in it so I guess it is not out of the norm, its just not what I suspected.
I dont find it in the docs anywhere if it is a requirement.
bob
bob
Last edit: 20 Mar 2019 12:22 by bevins.
- pl7i92
- Thank you received: 358
20 Mar 2019 13:35 #129060
by pl7i92
Replied by pl7i92 on topic Setting G43 in remap required?
it is better to do so
as you interfear the operator
but also do it in G-code after a Toolchange
Recall the G43 Hx
Recall the G43 Hx
- bevins
20 Mar 2019 15:15 - 20 Mar 2019 15:15 #129073
by bevins
Yeah, thats what I am doing but I would like to know why it doesnt set G43 correctly if I dont do it in the remap and just do it in Gcode outside the remap.
I asked the question in Machinekit hoping Michael H. will pop on in.
Replied by bevins on topic Setting G43 in remap required?
Recall the G43 Hx
Last edit: 20 Mar 2019 15:15 by bevins.
- Thank you received: 4652
21 Mar 2019 13:46 #129169
Replied by andypugh on topic Setting G43 in remap required?
Does the G43 do nothing, or does it "get" the wrong H-number value?
After the tool change, does the system have the correct tool number?
(if the remap has no actual M6 or M61 then the tool number might be be being updated)
Time to create page: 0.093 seconds
