Staring configuration without boards? GUI sensitive?
  • Type_Zero_Design
  • Premium Member
  • Premium Member
21 Mar 2019 14:49 #129179 by Type_Zero_Design
Hello everyone,
A few questions in regards to Linuxcnc.
I was wondering if I can start developing my configurations for my machine and hardware without having my Mesa boards? (7i76E is sold out for the next month) Obviously there will be some limits but I wasn't sure if it's a possibility.
Secondly if I start developing on one GUI can that carry over to another or is it a total loss?
21 Mar 2019 14:59 #129183 by tommylight
It is not a total loss, you can use that config with other GUI's.
You can also do all kinds of testing with no hardware, but i am not sure if there is a sim for 7i76E.
Anyway you look at it, it is quite simple to do a config when you get the Mesa board, in the mean time you can use a sim to get used to the GUI you want to use.
  • Type_Zero_Design
  • Premium Member
  • Premium Member
21 Mar 2019 17:40 #129204 by Type_Zero_Design
Replied by Type_Zero_Design on topic Staring configuration without boards? GUI sensitive?
Good to know, going to spend some tea learning about the config tonight.
21 Mar 2019 19:28 #129214 by Mike_Eitel
I was considering that it should be possible to write a .comp file with all inputs and outputs for a i776e. And insert that for sim. But never tried for time restrictions.
Isn't hat possible?
21 Mar 2019 19:40 #129216 by cmorley
It is possible. that is what stepconf does for hardware simulation option.
In stepconf's case the comp is actually a passthrough - you could conceivably connect some other hardware to it - tough i have never tried.
The problem (IMHO) with most Mesa hardware is the volume and combinations of I/O make it impractical for anything but standard-firmware-all-in-one cards (like the 7i76e)
Chris
21 Mar 2019 23:58 #129234 by andypugh
Isn't hat possible?
Absolutely. I even started one once.
Just a .comp file that creates the pins and then does nothing with them.
22 Mar 2019 00:15 #129236 by andypugh
Isn't hat possible?
Just a .comp file that creates the pins and then does nothing with them. You probably have to call the file and the component hm2_7i76e though.
The following user(s) said Thank You: Mike_Eitel
