question about offset
- Thank you received: 1476
18 Apr 2019 21:22 - 18 Apr 2019 21:22 #131194
Replied by Todd Zuercher on topic question about offset
Yes use the #
As to G10L20, yes I probably got it wrong (If your machine is located at the machine origin G53X0Y0, position, it would not matter the results would be the same.)
The P however needs to be P2, that will specify changing the G55 offsets.
When you said you tried to force the change them, did you manually edit the .var file and save it? That can actually work, but Linuxcnc must be closed when you make your change and save, because Linuxcnc only reads the file when opening, and will save over your changes when closing.
Last edit: 18 Apr 2019 21:22 by Todd Zuercher.
The following user(s) said Thank You: sm
- sm
18 Apr 2019 21:25 #131195
by sm
Replied by sm on topic question about offset
ah... that is probably the thing.
I was editing linuxcnc.var, while linuxcnc was running.
I made changes to vars. saved file. closed it.
then I bounced linuxcnc... those 5241 and 5242 came back like I never edited them.
ok. thank you. let me try to edit these values with CLOSED linuxcnc.
Thank you!
Thank you!
- sm
18 Apr 2019 21:42 #131197
by sm
Thank you, Todd - that worked. so, yes... it's right - linuxcnc starts and holds linuxcnc.var in the memory.
so, whatever changes I have made linuxcnc.var, while linuxcnc is running itself cannot be read.
Thank you.
at least this mystery is solved.
Thank you.
- pl7i92
- Thank you received: 358
19 Apr 2019 06:54 #131224
by pl7i92
Replied by pl7i92 on topic question about offset
The Gcode shoudt always load a TOOL
no tool is all tools
and no G53 G0 shoudt be inside
the G53 is MASHINE not workpice
only G54-G59 shoudt be present in Gcode
GET full controll
with your settings on the tooltable
and use the defaults in Preamble
GET full controll
20 Apr 2019 23:03 #131339
Replied by andypugh on topic question about offset
If things are half the size you expect then I would suspect that the problem is with the microstep settings.
You might not have noticed that the movement was wrong in Stepconf, as it travels +/- the set distance, and so the total distance is doubled.
(i, if you asked for a 10mm move you would have got a 10mm move, but should have been expecting a 20mm move)
- sm
21 Apr 2019 02:33 #131364
by sm
Thank you andypugh!
That was the one. turned out I incorrectly measured it while running stepconf.
it looks much better now.
Thank you all for your help and suggestions.
- sm
21 Apr 2019 22:19 #131424
by sm
turned out it was a bit too early to celebrate the victory.
Please, if anyone has any idea suggestion this happening.
What happened was:
I am cutting simple square 10 x 10 mm with cut offs each corner:
N0 ;(square1.ngc)
N1 G92.1(reset G92 and set values to zero)
N2 G17 (Plane Select. XY = default )
N3 G21 (use millimeters)
N4 ;G54 (select coordinate system. must be set before G42/G42)
N5 G90 (absolute distance mode)
N6 ;G40 (cancel cutter compensation)
N7 G61 (Exact path mode)
N8 F0.05 (set feed)
N9 ;G53 G0
N10 ;G54 X0.36 Y0.36
N11 G1 X1.40 Y1.00
N12 G1 X10.60 Y1.00
N13 G1 X11.00 Y1.40
N14 G1 X11.00 Y10.60
N15 G1 X10.60 Y11.00
N16 G1 X1.40 Y11.00
N17 G1 X1.00 Y10.60
N18 G1 X1.00 Y1.40
N19 G1 X1.40 Y1.00
N20 ;G40
N21 M2
cutting goes counterclockwise, so, bottom of this square is side #1.
it just finished cutting. side #1, side #2, side #4 are fine - good cut surface, all sides are in parallel, except somehow, side #3 was cut shorter. long sides of this square came out 9.40 mm(which is correct as I did not apply cutter compensation, because I wanted to get first simple cut and then figure out offsets). but, side #3 is 5.6mm.
linuxcnc reported during the cutting that it went all the way to the end of this side.
only thing I did was I paused last night the machine when side #2 and its corner were done and left it paused for overnight. this morning I resumed cutting. cutting finished at the point where it supposed to (well with certain precision about 0.1mm).
why only one side (#3) was cut shorter?
any ideas? suggestion?
PLEASE!
What happened was:
N0 ;(square1.ngc)
N8 F0.05 (set feed)
N9 ;G53 G0
N11 G1 X1.40 Y1.00
N12 G1 X10.60 Y1.00
N13 G1 X11.00 Y1.40
N16 G1 X1.40 Y11.00
N17 G1 X1.00 Y10.60
N18 G1 X1.00 Y1.40
N19 G1 X1.40 Y1.00
N20 ;G40
N21 M2
PLEASE!
- Thank you received: 7484
21 Apr 2019 22:22 #131425
Replied by tommylight on topic question about offset
Picture ?
- sm
21 Apr 2019 22:23 #131426
by sm
I am sorry, picture of what?
21 Apr 2019 22:34 #131428
Of the part.
Time to create page: 0.119 seconds
