Sourcing or Sinking
22 Apr 2019 21:23 #131550 by Firat
Sourcing or Sinking was created by Firat
Hello which version of 7i76e should be used for plasma cutting. sinking or sourcing output ?and why please
  • Moderator
  • Moderator
22 Apr 2019 21:40 #131555 by tommylight
Replied by tommylight on topic Sourcing or Sinking
That is not important at all if you already do not have the limit switches or sensors, and even if you do, they can be almost always used.
23 Apr 2019 10:10 #131621 by rodw
Replied by rodw on topic Sourcing or Sinking
I use a standard 7i76e becasue its so nice and simple to understand how things work. I don't think the 7i76ed was around when I bought. I would only use sinking inputs if trying to make something compatible with an existing wired up machine.
23 Apr 2019 13:52 #131634 by PCW
Replied by PCW on topic Sourcing or Sinking
Note that only the outputs are different between the 7I76,7I76E,7I77,7I84 and the -D versions of these cards, the inputs are always sinking.
SInking outputs are valuable if you are retrofiting a machine and has relays wired for sinking drivers or if you wish to mix output voltages or switch the common output power supply for a set of outputs for safety or other reasons.
23 Apr 2019 14:45 #131645 by pl7i92
Replied by pl7i92 on topic Sourcing or Sinking
sinking is mutch more interesting for divverent Voltiges on mashineng
and also you can use more wider range of items
Time to create page: 0.081 seconds
