Updating 2.7 without network?
23 Apr 2019 16:47 - 23 Apr 2019 16:47 #131666 by lukepighetti
Updating 2.7 without network? was created by lukepighetti
Hi all,
Installed 2.7 today on my machine, which does not have network access. Booted it up and it's running 2.7.0. What is the recommended method for upgrading it without network access?
Luke
Last edit: 23 Apr 2019 16:47 by lukepighetti.
23 Apr 2019 16:49 #131667 by tecno
Replied by tecno on topic Updating 2.7 without network?
2.7.14 is the latest
23 Apr 2019 17:01 #131670 by lukepighetti
Replied by lukepighetti on topic Updating 2.7 without network?
Thanks, just found the guide on how to do it linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
23 Apr 2019 17:06 #131671 by Todd Zuercher
Replied by Todd Zuercher on topic Updating 2.7 without network?
There are instructions in the doccumentation. It would probably be simplest to just follow those, but I'm sure there are other ways.
linuxcnc.org/docs/devel/html/getting-sta...ting_without_network
Basically you download the .deb file for the version you want, copy it to your machine PC then install it with the command sudo dpkg -i (file name).
The following user(s) said Thank You: lukepighetti
  • AnnoyingMutt
  • AnnoyingMutt's Avatar
  • Visitor
  • Visitor
23 Apr 2019 20:08 #131684 by AnnoyingMutt
Replied by AnnoyingMutt on topic Updating 2.7 without network?
If you waddle over to google and search for “apt offline” Debian has instructions on how to get packages onto a machine with no internet access, including any extra deps.
