invers rotation X
24 Apr 2019 05:35 #131735 by Retiere
invers rotation X was created by Retiere
Hello i have 2 moteur on the axis x, and i would to know if it's possible to do invers the rotation without connect 2 moteur on the breakboard ?
I want to do this in order to evaluate my machine in 5 axes and unplug the connector that i can.
thanks
24 Apr 2019 06:05 #131737 by pl7i92
Replied by pl7i92 on topic invers rotation X
YES
simply do change the WIRE on the motors
Motor 1 A+ A- B+ B-
Motor 2 A- A+ B- B+
24 Apr 2019 10:03 #131754 by Retiere
Replied by Retiere on topic invers rotation X
tanks !
24 Apr 2019 19:31 #131789 by andypugh
Replied by andypugh on topic invers rotation X
Doesn't swapping both phases leave the motor direction the same?
I think you need to swap only one phase.
But it's easy to try both.
But, whatever you do, never disconnect a stepper driver from the motor when it is powered up. Many of them blow up immediately.
Time to create page: 0.065 seconds
