LinuxCNC 2.7.14
- pachi_electronic
25 Apr 2019 06:21 #131839
by pachi_electronic
LinuxCNC 2.7.14 was created by pachi_electronic
hola si hay la iso de LinuxCNC 2.7.14 o hay que bajar la iso LinuxCNC 2.7.0 y despues actualizar.....soy novato en el sistema operativo linux...ayuda.....gracias a todo de este foro
- pl7i92
- Thank you received: 358
25 Apr 2019 06:51 - 25 Apr 2019 06:51 #131840
by pl7i92
Replied by pl7i92 on topic LinuxCNC 2.7.14
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install linuxcnc
apt-get update updates the list of available packages and their versions, but it does not install or upgrade any packages.
apt-get upgrade actually installs newer versions of the packages you have. After updating the lists, the package manager knows about available updates for the software you have installed.
ONLY Software no Kernal
Last edit: 25 Apr 2019 06:51 by pl7i92. Reason: typo
- Thank you received: 7471
25 Apr 2019 21:14 #131892
sudo apt-get dist-upgrade
Replied by tommylight on topic LinuxCNC 2.7.14
sudo apt-get updatesudo apt-get update
The following user(s) said Thank You: phillc54, AnnoyingMutt
- AnnoyingMutt
- Visitor
25 Apr 2019 23:06 #131901
by AnnoyingMutt
apt-get dist-upgrade is the smarter and safer way to upgrade packages, please, please recommend dist-upgrade over upgrade.
Replied by AnnoyingMutt on topic LinuxCNC 2.7.14
sudo apt-get update
Time to create page: 0.080 seconds
