Plasma with servos, Z axis stepper?
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 May 2019 12:30 #132524 by bevins
Plasma with servos, Z axis stepper? was created by bevins
Hi all,
I am working on building a Plasma 5x10. I am using AC servos with 5i25 and 7i77. Should I use stepper for Z axis to control with THC?
Can I get stepgens from 7i77 to control the Z?
02 May 2019 12:51 #132529 by PCW
Replied by PCW on topic Plasma with servos, Z axis stepper?
Not, directly but you can use a cheap Ebay breakout on the second 5I25 port
to add some buffered step/dir outputs
  • bevins
  • Platinum Member
  • Platinum Member
02 May 2019 13:03 #132531 by bevins
Replied by bevins on topic Plasma with servos, Z axis stepper?
I dont want to use a cheap breakouit board.
Can't I use a 7i78? Is there a bitfile for this combo? 5i25-7i77 and 7i78?
02 May 2019 22:00 #132569 by BigJohnT
Replied by BigJohnT on topic Plasma with servos, Z axis stepper?
Yes there is a 5i25_7i77_7i78.bit file.
JT
  • Moderator
  • Moderator
05 May 2019 02:06 #132798 by tommylight
Replied by tommylight on topic Plasma with servos, Z axis stepper?
Hi all,
You can use a stepper or a servo, there are already configs for all types of hardware, and there are two types of configs for plasma that are fully automated, the thc_toma one that i use (still) on all machines has separate configs depending on the hardware that need editing the IO pins and velocity and accelerations, and the PlasmaC made by Phill that works with all types of hardware, also needs a bit of editing.
I would recommend using the PlasmaC config, it is much more advanced.
