Error message "Radius to end of arc differs....etc etc"
7 years 5 months ago #132939 by pl7i92
can you upload a high reolution image of the Drawing we make you a near perfect G-code
7 years 5 months ago #132957 by Todd Zuercher
I took a closer look at your G-code and I now see your problem. The problem is that the arc centers are specified in incremental mode not absolute coordinates. Your code will run fine if you change the beginning line of your file from
G21 G40 G49 G90.1 G64 P0.03 M6 T1
to
G21 G40 G49 G90 G91.1 G64 P0.03 M6 T1
Then it should run fine.
7 years 5 months ago - 7 years 5 months ago #132958 by Jocman
Here you find a DWG of the catflap (with no graphics.)
Yesterday I made it by using my "no solution" code, and honestly the result is fine (my soulmate loves it and that makes my life easier :laugh: )
BTW I'd like to fix the problem of the G3 command in vectric/LinuxCNC, as I'm really thinking to get Aspire (or even the cheaper 2DCut), but if I can't fix the arc problem it will be almost useless to buy it, better keep using Inkscape with Gcode support (and the "no solution" method.....)
Andrea
Last edit: 7 years 5 months ago by Jocman.
7 years 5 months ago #132967 by Todd Zuercher
Your old G-code works fine if you change the first line.
7 years 5 months ago #132974 by pl7i92
he shoudt use a Fanuc postprocesor for the output
7 years 5 months ago #133129 by Jocman
Todd Zuercher wrote: Your old G-code works fine if you change the first line.
Do you mean to put:
instead of
(commands G90.0 and G91.1) ?
This case, If I modify my PP settings so to keep these changes, do you think I could have problems for other kind of jobs?
pl7i92 wrote: he shoudt use a Fanuc postprocesor for the output
Fanuc can work with LinuxCNC with no issues?
Time to create page: 0.282 seconds
